> Auto Transmission Probs
Eddo
post Nov 11 2004, 09:28 AM
Drives: '94 Excel LS
Hi everybody....just bought a '94 LS auto which runs well apart from a big jolt between gears sometimes. I read that this may be due to a 'missing or defective air exhaust plug' - I have no idea what this means or where to check it. Can anyone help or suggest any other cause please?
Dr. Hundi
post Nov 12 2004, 02:35 AM
Group: Mod Emeritus
Drives: Cressida
Is the thumping more predominant into a particular gear, say from fist into second, or second into third?
Or even downshifting?
Eddo
post Nov 12 2004, 05:43 AM
QUOTE(Dr. Hundi @ Nov 12 2004, 03:35 PM)
[right][snapback]2641[/snapback][/right]
It's on the up-shift, mainly from second to third, sometimes third to fourth. On a separate note, there is a lot of whining /roaring/ road noise which the mechanics tell me is either the front tyres or wheel bearings. Is this a common problem please?
duke
post Nov 12 2004, 10:51 AM
Community Advisor
Group: Community Advisor
Drives: 2007 NF Sonata 2.4L
QUOTE(Eddo @ Nov 12 2004, 02:43 AM)
[right][snapback]2649[/snapback][/right]
the tranny problem could be the Kick Down brake, which may need adjusting.
the roaring noise could be capped tires. Do you regularry rotate the wheels ??
Should be done every 24K km (rear ones over cross to front, and front straight to the back) If you rotate the wheels, and the "WHEEL BEARING" noise moves as well, then leave it alone, the tire will "decap" itself again in time.
801Excel
post Nov 12 2004, 07:43 PM
Drives: Hyundai Excel
Yeah, definatly try rotating the tires.
it's funny... the one I got has been sitting for years and years. I think it has around 64k Miles on it... It runs like a champ, except for the rear main seal is bad, as soon as you get oil pressure it just gushes out oil. Other than that the auto trans is solid and it'll fire up everytime, and run beautifully, it's even pretty zippy. But no worries it'll have a new motor/setup in a few.
markexcel
post Nov 29 2004, 03:49 PM
Drives: hyundai 91 excel
QUOTE(Eddo @ Nov 11 2004, 08:28 AM)
[right][snapback]2600[/snapback][/right]
I have a 91 excel and I experience a hard jolt accelerating in first gear going to second and also decelerating in low gear. It is an automatic. Have you found out what this problem may be?
duke
post Nov 29 2004, 07:48 PM
Community Advisor
a tranny fluid change might change a lot. BUT, use Hyundai ATF only
skyclone
post Dec 10 2004, 09:47 AM
Drives: 88 Hyundai excel
QUOTE(duke @ Nov 29 2004, 04:48 PM)
[right][snapback]3148[/snapback][/right]
What about ''dexron3'' or is the hyundai more like ford fluid? I am not sure if one can get ''Hyundai'' atf in many locations other than dealer of course.
duke
post Dec 10 2004, 11:07 AM
Community Advisor
QUOTE(skyclone @ Dec 10 2004, 06:47 AM)
[right][snapback]3516[/snapback][/right]
on the 1994 model, you could get away using DEXRON 3E, otherwise Hyundai ATF only (available at your dealer only).
Dr. Hundi
post Dec 12 2004, 08:15 PM
Group: Mod Emeritus
Drives: Cressida
Still want to know whether it shifts badly when shifted manually.
This will eliminate a fair few things if you can provide that information!!!!!
No New Posts Autolock
autolock at 20 MPH
4 whodathought 92 Today, 06:21 PM
Last post by: Pezman1
No new Topic has attachmentsTransmission Shift Quality In 2009 Sonata
42 dandaroy 1,441 Today, 06:04 PM
Last post by: i360
No New Posts Topic has attachmentsAuto Climate Control
Heat Settings Question
11 torscotty 124 1st December 2008 - 08:41 AM
Last post by: torscotty
No New Posts Transmission Fluid Castrol
7 SuperAman 612 28th November 2008 - 05:54 PM
Last post by: joey0309
No New Posts Topic has attachmentsTransmission Shift Quality
How does it compare for everyone?
11 torscotty 140 26th November 2008 - 10:32 PM
4th December 2008 - 08:53 PM
