 Hyundai-Forums.com > Hyundai Models > Tiburon Forum > GK Tiburon (2003-2008)
> Please Help--noise In Engine, Only first 5min after started
tuscani16
post Nov 10 2004, 08:57 PM
Drives: Tuscani 2.7V6
I have a TUSCANI(tiburon) 1.6doch (in europe also sales 1.6L)
When i started my engine this have a noisy from timin belt zone(or FRONT engine zone).
This noise is only in first 5min, after the noise disapear.
I have a record of this noise, i attached this.
Some hyundai dealers says this noise is tipic in this engines.... and no problem for engine.
TRY DOWNLOAD THIS RECORD:
http://213.227.18.165/sonidos/ruidohyundai.zip
This post has been edited by tuscani16: Mar 1 2006, 07:00 PM
Attached File(s)
VALKYRIE YB70
post Nov 10 2004, 09:40 PM
Mod Emeritus
Drives: Modified (180 b.h.p.) `95 Hyundai S-Coupe Turbo SE ....Sadly now sold & replaced with an `04 Alfa Romeo 156 2-litre Veloce! :-http://aol.photobox.co.uk/album/thumbnails.html?c_album=7089276&page=all
Hi!........the Dealers are correct, the tapping sound from under the valve cover when the engine is idling, immediately following a cold start, is typical of Hyundai engines.
The sound is made by the HLA`s (hydraulic lash adjusters). The oil inside these can drain back into your sump (oilpan) overnight & they take a few minutes to re-fill themselves when you start up in the morning.
This effect can be mimimised by using flushing oil, then draining & re-filling with a good quality pure synthetic oil such as Mobil 1.
It is important to ALWAYS keep the oil-level topped up to MAX on your dipstick!.
Cheers,
Nick. :)
tuscani16
post Nov 10 2004, 09:46 PM
Thanks.
Some mechanics says this is a "piston clearance" but other mechanics says "timing chain noise".
I dont think this noise is "timing chain" , but timing chain is in rear engine... and the noise sound in Front engine (timing belt zone)
jeremythewicked
post Nov 11 2004, 07:34 AM
Drives: 2001 Hyundai Accent Gsi
QUOTE(tuscani16 @ Nov 10 2004, 10:46 PM)
Thanks.
[right][snapback]2574[/snapback][/right]
I have the same problem in my Accent with the 1.6L. I have been told it is a piston clearance problem. See the thread in the Accent Forum under Engine Noise.
tuscani16
post Nov 11 2004, 10:44 AM
I correct LINK for download this rec of noise:
http://www.radiomania.net/tienda/ruidohyundai.zip
Its ZIP file, unzip and you have a MP3 file.
duke
post Nov 12 2004, 03:49 PM
Community Advisor
Group: Community Advisor
Drives: 2007 NF Sonata 2.4L
QUOTE(tuscani16 @ Nov 11 2004, 07:44 AM)
[right][snapback]2608[/snapback][/right]
file won't work with windows
tuscani16
post Nov 12 2004, 05:18 PM
QUOTE(duke @ Nov 12 2004, 09:49 PM)
[right][snapback]2678[/snapback][/right]
Hello Duke, is file problem, ZIP or MP3???? unzip or playing MP3???
I want that you listen to the noise :)
PD: Try this link, is a Unziped MP3 file:
http://www.radiomania.net/tienda/ruidohyundai.mp3
This post has been edited by tuscani16: Nov 12 2004, 05:24 PM
duke
post Nov 13 2004, 02:28 PM
Community Advisor
QUOTE(tuscani16 @ Nov 12 2004, 02:18 PM)
[right][snapback]2681[/snapback][/right]
wow, that sounds like a chain to me
o3gttiburon
post Nov 13 2004, 07:32 PM
Drives: Hyundai Tiburon GT
Well I have the problem with valvetrain noise upon startup but only on hot days, and I use Mobil 1 Synthetic 5W-30. But it only does it when you first start up. But if it continues to do that then you have a problem in your head. When I wrote service at a local Hyundai dealership with had a Tiburon with a similar problem and we had to get it fixed. But that noise sounds like it's pretty bad. Definately need to get that fixed at the dealer.
Good luck with it.
Vince.
HCUKTHETA
post Feb 19 2005, 05:20 PM
Drives: 2005 HYUNDAI SONATACDX
HCUK
Hi i would like to assure you all that this is an inherant noise. the piston rattles up the bore. this is piaston slap. this will go when the car is warm because the piston becomes the right size in the bore. We have no cure for this.
tuscani16
post Feb 22 2005, 04:06 PM
Post #11
QUOTE(HCUKTHETA @ Feb 19 2005, 11:20 PM)
[right][snapback]7282[/snapback][/right]
Hi!
dealer has fix my problem, it has changed the pistons, but the noise has returned, very reduced...
Is a piston slap a problem? is it bad for engine??
Cure is a new engine?
Note: my car have only 40.000KMS, and noise apears with only 10.000KMS :(
No New Posts Engine Damper
Is it worth it?
11 bloodninja 104 Today, 08:58 PM
Last post by: LePapirrikY
No New Posts Please, Please Help Need Assistance With Error Codes
1999 elantra, did engine swap getting error codes
0 jyoung1z 6 Yesterday, 01:40 PM
Last post by: jyoung1z
No New Posts Instrument Panel Lights
4 rcacs 49 Yesterday, 04:53 AM
Last post by: gbajosh
No New Posts Engine Shut Off
What's going on?
20 penguin_hash 681 1st December 2008 - 09:58 AM
Last post by: wagsmachine
No New Posts Engine Wont Start When Hot
4 kev f 126 28th November 2008 - 12:56 AM
Last post by: Madogi
4th December 2008 - 09:22 PM
