QUOTE(cjbryan @ Apr 6 2007, 12:23 PM)
Hi, same thing happened to ours. In the end the car wouldn't start or move and was worthless. Then we found that there is a £150 kit to convert the semi-auto to manual, and off we go again. It takes about 3 hours for the dealer to fit and works fine.
Hope that helps/
[right][snapback]81264[/snapback][/right]
Hi i am having the usual semi auto problems and don't want to scrap the car because its engine is a superb low miles example.
Can you tell who the dealership was you used and where you purchased the conversian kit,cheers
