The manual 94 Lantra I have has done 200,000k. I rebuilt the gearbox at 170,000k. I burnt a valve going up a hill at 160,000k but that was because the exhaust flex section had disintegrated making the engine run hot which meant the head was reco'd. I replaced the HLAs at 185,000k in an attempt to get rid of cold engine lifter tick which didn't help all that much. The radiator is a little marginal at this point.
I have also replaced the shocks(KYB), springs(Lovells), front rotors, front wheel bearings, lower ball-joints, steering tie-rod ends and sway bar bushes. Also fixed oil leaks from the sump, cams, crank, oil pump and BS seals.
Things that need fixing are:
-dead AC clutch -lower timing cover needs replacing -hydraullic timing belt tensioner needs replacing -rear interior door handle needs replacing.
Pretty much normal things for a car of this age. Also, when I bought this car the balance shafts were WAY out of time making the engine seem harsh. The belt needed replacing in any case and once I fixed that up the engine is sweet and showing no signs of cylinder bore wear when I was in there. :thumbsup:
This post has been edited by xlr8_au: Aug 3 2006, 03:30 AM
