2 Pages V   1 2 >
> Data Trouble Codes, Trouble code retrieval for Alpha Engines
Dr. Hundi
post Nov 9 2004, 07:08 AM
Group: Mod Emeritus
Drives: Cressida
Data Trouble Code Retrieval for Alpha Engines
With the increasing rate of people wanting to know the process of carrying out their own "code checking" precoedures, I have developed an article which will tell you step by step, what to do when trying to eliminate problems, using the on board diagnostic system.
Data Link connectors:
Accent 95-99 - above the right most switch panel
Accent 00-Current - below the lower dash shroud
Getz - below the lower dash shroud
Data Link connector configuration:
(IMG:http://img124.exs.cx/img124/2267/DLC1.jpg)
Data Trouble Code Retrieval (using M alfunction I ndicator L amp):
1. Ignition switch on (do not start)
2. Ground the L-wire (bridge No. 15 pin and No. 4 pin) in the Data Link Connector for 2.5-7 seconds.
3. If there is no fault, code "4444" will be indicated.
4. Each code is repeated infinitely until the next step is ordered.
5. To order the next code to apper, you are required to ground the L-wire again for 2.5-7seconds, after that the next code follows.
The last output consists of the code for end of "code output" which is "3333". After grounding the L-wire again for 2.5-7 seconds, the diagnostic mode is left.
Remember: There will always be four digits in each code output.
Code List is as follows:
1.3L SOHC TYPE 1
MIL_________________Check Items
1122________________ ECM or Harness
1234________________ MFI control relay or harness
3128________________ O2 Sensor
5111________________ MAP sensor
5112________________ Air temp sensor
3153________________ Throttle position sensor
3144________________ Idle speed actuator
3112________________
3145________________ Engine Temperature Sensor
3147________________ Camshaft position sensor
3159________________ Vehicle speed sensor
1169________________ Ignition system, cylinder 1&4 A output
3135________________ Evap. purge control solenoid valve
3138________________ Air/Con relay
1169________________ Ignition system, cylinder 2&3 B output
4151________________ Air/Fuel correction
3112________________ Injector No.1
3116________________ Injector No.2
3235________________ Injector No.3
3234________________ Injector No.4
2222________________ Start of output
3333________________ End of output
4444________________ No fault
1.5L (SOHC/DOHC) TYPE 2 & 3
MIL__________ Comment____________________Component
1234____________ECM RAM malfunction_____________ ECM
1233____________ECM ROM malfunction_____________ ECM
3145____________ECT sensor circuit malfunction______ ECT Sensor
3146____________IAT sensor circuit malfunction______ IAT Sensor
3153____________TPS sensor circuit malfunction______ TPS Sensor
3112____________Injector #1 circuit malfunction______ Injector #1
3234____________Injector #2 circuit malfunction______ Injector #2
3116____________Injector #3 circuit malfunction______ Injector #3
3235____________Injector #4 circuit malfunction______ Injector #4
3117____________MAF sensor circuit malfunction______ MAF sensor
5111(TYPE3 ONLY) MAP sensor circuit malfunction______ MAP sensor
3114____________Idle control valve opening coil______ ISC actuator
_________________circuit malfunction
3122____________Idle control valve closing coil_______ ISC actuator
3128____________Oxygen sensor circuit malfunction___ Heated O2 sensor
4151___________________________________________Air/Fuel ratio
4153____________Air/Fuel leaking or injector clogging__Air/Fuel ratio
4154___________________________________________Air/Fuel ratio
3135____________EVAP canister purge solenoid valve__EVAP Can. purge sol.
________________circuit malfunction____________solenoid
3211____________Knock sensor circuit malfunction____ Knock sensor
3232____________CKP sensor circuit malfunction______Crankshaft pos. sensor
3222____________CMP sensor circuit malfunction______Camshaft pos. sensor
3159____________VSS circuit malfunction____________Vehicle speed sensor
3137____________Battery voltage incorrect___________Battery
4133____________Fuel pump relay malfunction________Fuel pump relay
3149____________A/C compressor switch or relay_____Air Conditioner
________________malfunction
3221____________A/C fan malfunction_______________Air Conditioner
3133____________A/C Cooling fan malfuction_________Air Conditioner
Type 1__1.3L SOHC
Type 2__1.5L SOHC
Type 3__1.5L DOHC
Remember: These are only guidelines to aid you in your diagnosis. They will not provide a definite answer as to what component you should replace, but moreso, identify in which area you are experiencing problems.
I will personally hold no responsibility for any failures that may occur to user carelessness!
Actuation Test
There is also an actuation test which can be carried out in order for you to determine whether your actuators are operating correctly.
Actuator Control Sequence Procedure
1. The L-wire (No. 15 pin) in the data link connector has to be grounded before turning the ignition key on (DO NOT START).
2. Turn the ignition key on (DO NOT START) and then disconnect the grounded wire from pin No. 15, then the actuator activation sequence will begin, starting from the fuel pump relay.
NOTE: Each actuator will be stopped after activating 6 times
3. Once the actuator has activated 6 times, you will then be required to ground the No. 15 pin again to follow on to the next actuator in the sequence, which will be listed below:
Test Item__________________Fault Code
1. Evap can. purge valve solenoid_______________1322
2. ISC vAlve solenoid_________________________1321
3. No. 2 injector _____________________________1315
4. No. 3 injector _____________________________1314
5. No. 4 injector _____________________________1313
6. No. 1 injector _____________________________1312
4. If the actuator responds normally, code "4444" (No Fault Code) will be indicated by the MIL.
If there is any faults, the relevant trouble code will be displayed via the MIL.
This post has been edited by Dr. Hundi: Nov 9 2004, 07:47 AM
jhager
post Feb 14 2005, 10:20 PM
Drives: accent '04
Can you use this method to troubleshoot the air bag circuit?
CanadAccent
post Mar 18 2005, 07:37 PM
Drives: Accent
I tried this procedure on my '98 and got no response from the CEL. :(
Car is a "L'' model, Canada, 1.5L SOHC, manual trans.
So, either the procedure isn't valid, or my car doesn't have this feature, maybe because it's manual transmission.
I guess I need a code reader after all. :|
I hope my ECU DLC interface isn't fried - Mr. Hundi.
Dr. Hundi
post Mar 26 2005, 05:04 PM
Group: Mod Emeritus
Drives: Cressida
DO NOT ATTEMPT AT ANY TIME TO EXTRACT CODES FOR, OR ATTEMPT TO REPAIR YOUR SELF, ANY AIRBAG UNIT!!!!!!!!!
pUT A DOLLAR SIGN ON YOUR HEAD AND YOU WILL SEE THAT IT WILL ALWAYS END UP MORE THAN THE BILL YOU WILL GET FROM HYUNDAI!!!!
foxtony90
post Oct 8 2005, 09:17 PM
Drives: 2000 hyundai accent si 1341
Hi,i have a british 2000 accent 1.3 12v which has got the OBD11 16 pin socket,could you tell me if this procedure works on mine thanks.
laflega
post Nov 2 2005, 07:37 AM
Drives: 1999 accent
I have a 1999 Accent (Canada). Could not locate the DLC connector? Any idea where it is?
99AccentGL
post Nov 30 2005, 10:27 PM
Drives: 99 Accent GL
^I have the same question.
nate1366
post Feb 6 2006, 07:33 PM
Drives: 99 hyundai accent
its right above the dimmer switch,
This post has been edited by nate1366: Feb 7 2006, 05:06 PM
Attached File(s)
jaaribear
post Apr 6 2006, 06:11 PM
Drives: 1999 Hyundai Accent 5 spd
on ur left u know that lil square deep cubby hole on dash by drivers door?
its thyere inner upper lip of cubby hole
hostilesmoker
post Apr 8 2006, 09:15 AM
Drives: 2000 Hyundai Accent
Hi guys,
We have a 2000 Hyundai Accent (UK model) and I have found the data link connector below the lower dash shroud.
I tried the above method but there doesn't appear to actually be a connection in pin no. 15 (no. 4 is there)
Is this because it's a manual as someone posted above?
Any ideas what else I might try?
I also foolishly grounded pin 16 (marked B* above) - and it gave off a tiny little spark. There's no chance I've shorted anything is there? :?
Thanks.
VALKYRIE YB70
post Apr 12 2006, 05:22 AM
Post #11
Mod Emeritus
Drives: Modified (180 b.h.p.) `95 Hyundai S-Coupe Turbo SE ....Sadly now sold & replaced with an `04 Alfa Romeo 156 2-litre Veloce! :-http://aol.photobox.co.uk/album/thumbnails.html?c_album=7089276&page=all
I think the only OBDII reader which will `plug & play` directly into the data port is Hyundai`s own Hi-Scan Pro device.
This is also used by techs at the Dealerships to upload software revision packages issued by Hyundai.
Despite the fact that Hyundai electronic engine management consists of commercially available Bosch/Siemans components, the programming is via Hyundai`s own coding........& no-one has managed to re-write tuning modifications directly (as can be done with VAG Group cars).
The nearest tuners have got so far, is to mount an additional EPROM into the ECU & program that!.
If your car is running normally, I doubt that your accidental short has done any damage.
Cheers,
Nick.
usherly
post Sep 5 2006, 10:51 PM
Post #12
Drives: 1997 Hyundai Excel Sprint Sport 1.5 SOHC
so how do i no what code is being displayed?
will the mil flash will it
ie code 1234: one flash, solid, 2 flashes, solid, 3 flashes, solid, 4 flashes?
is that what will happen?
shippyt
post Sep 19 2006, 05:27 PM
Post #13
Drives: Hyundai Coupe 2.0
Does the MIL flash the codes? Does anyone know if this works on the original shape Coupe's?
Any help greatly appreciated.
Sil
post Oct 17 2006, 03:41 PM
Post #14
Drives: 99 Accent Gsi
so what to do if this procedure doesnt give codes :|
99 accent from canada
the light just stays solid :S
Jakkals
post Jan 13 2007, 11:35 AM
Post #15
Drives: 1995 Hyundai Accent 1.5
First of all, this is an excellent guide for retrieving the diagnostic information.
I've located some problems and fixed them using this guide. There are however one thing that is bugging me about my ECU/ECM's diagnostics.
When I'm testing the actuators I get error codes for all of them. If this were correct then it would mean that none of my injectors and so forth is functional. But this doesn't seem to be the case since I'm still able to start my car.
I assume that when the ECU is entering the actuator diagnostic unit, one should actually hear the injectors operating if the ECU/ECM is testing them, isn't this the case?
When doing the normal diagnostic routine, there are no error codes given that my ECU/ECM is faulty.
Any ideas why this scenario is happening?
Rob from Brum
post Jan 20 2007, 09:19 AM
Post #16
Drives: Accent 15. mvi
Hi All
I get the same readings as Jakkals but my car is not working. Any ideas out there??
96 Accent Auto
post Dec 15 2007, 11:02 AM
Post #17
Drives: 1996 Hyundai Accent GSI 1.5 Automatic
I'm probably being really stupid asking this, not for the first time, but I'll ask anyway. The codes you all speak of, (1234, 4444, etc.), is there a special device which I need to buy to read them, or are they indicated by a light flashing somewhere? :whistling: :whistling: :whistling:
soullink
post Jan 5 2008, 02:07 PM
Post #18
Drives: Hyundai Accent MVI - 1999, 1.5i, 16 valve - www.soulaccent.com
QUOTE(96 Accent Auto @ Dec 15 2007, 05:02 PM)
[right][snapback]124487[/snapback][/right]
The code is indicated by the engine check light flashing. I believe it will flash for example 5 times for "5" followed by a pause before the next digit ;)
purple-accent
post Jan 18 2008, 04:43 PM
Post #19
Drives: 1995 hyundai accent 1.3i 3dr
hi there.
every now and then the 'check engine' light comes on on my 1995 1.3i accent. i have followed the instructions and brought up the flashing MIL to get the fault code. the problem is if i am reading the flashes correctly it doesn’t correspond to any of the fault codes i have (those on autodata and this site). i am getting 1 long flash followed by 4 groups of 2 short flashes. there are only 3 codes that start with '1' but the rest of the flashes dont follow for the rest of the code. am i reading this correctly? another point is, do i need to bridge the data link connector each time to get each part of the fault code, so i could read the flashing i get as '18' which then doesn't correspond with any fault code! thank you.
blueaccent
post Feb 4 2008, 05:32 PM
Post #20
Drives: 2001 Hyundai Accent
Hi. I have a 2001 Accent 1.3 UK model. The engine check light has been on and off for the last two years, now it's just on! I was going to buy a ODB2 reader to diagnose the problem and clear the check light, but from what VALKYRIE YB70 says, it sounds like an off-the-shelf ODB2 reader will not work. Is this the case?
Also, can anyone tell me exactly where the DLC is on a Right-Hand Drive 2001 Accent?
Thanks very much.
2 Pages V   1 2 >
No New Posts Trouble Codes From Obd-diag
Anybody knows this codes?
1 Loif 101 9th February 2010 - 05:42 PM
Last post by: jsinton
No New Posts Topic has attachmentsTrouble With 08 Sonata Shift Lock Release (and Possibly Esc)
19 MamaBear 405 27th January 2010 - 07:55 PM
Last post by: mamamia
No New Posts Topic has attachmentsCodes For "check Engine Light"
9 quintain 1,636 9th January 2010 - 03:30 PM
Last post by: skaterjoe
No New Posts Troublecode P0110 - Iat Circuit
2 cdr 429 31st December 2009 - 12:34 AM
Last post by: LordByron
No New Posts Trouble Codes: U0d00, P0711, P2300
Help with diagnosis
0 mubai 723 22nd November 2009 - 09:19 PM
Last post by: mubai
20th March 2010 - 01:28 AM
Privacy Statement
