 Hyundai-Forums.com > Technical > Interiors and Exteriors > Removal Of Door Panel On Accent 2000
Kingfisher
post Nov 8 2004, 07:12 AM
Drives: Accent 2000
Status: OFFLINE
Does anyone know how to remove the door panel from
Accent 2000? (Door lock sticking).
User is offlineProfile CardPM
QuoteReply
Dr. Hundi
post Nov 8 2004, 07:24 AM
Group: Mod Emeritus
Drives: Cressida
Status: OFFLINE
Yes, it is just a few screws and some pop-clips.
The screw positions are:
2 at the very bottom of the door panel
2 at the front of the door panel
1 in the inner door handle
1 inside the front rubber cap on the grab handle on the door pannel.
Then slide your fingers underneath the bottom of the door panel and pull outwards.
Once you have popped the door trim completely off the door, then you can swing the door trim around 90' and pop the door handle through the hole.
Then this is your door trim off.
Then there is the inner trim which is fastened to the door by sticka-flex, which makes a mess of your skin and your clothes!
Good luck with the job :)
QuoteReply
Kingfisher
post Nov 8 2004, 08:47 AM
Drives: Accent 2000
Status: OFFLINE
QUOTE(Dr. Hundi @ Nov 8 2004, 04:24 AM)
Many Thanks!
QuoteReply
cslsxpistol
post Nov 27 2005, 11:16 PM
Drives: 2000 hyundai accent HB
Status: OFFLINE
hey how do u get the window knob off?
QuoteReply
montego
post Nov 28 2005, 01:33 PM
GLOBAL MODERATOR
Group Icon
Group Icon
Group: Super Mod
Drives: XG's (2001&2002)
Status: OFFLINE
there is a wire clip that is fiited behind the window winder, if you push the door panel away from the back of the winder and look directly behind the winder you will see the clip, this can be pushed off with a small screwdriver (it is a bit tricky if you are not used to doing it)
QuoteReply
cslsxpistol
post Nov 28 2005, 09:17 PM
Status: OFFLINE
ok thanks the book was wrong.....hmm
also i got a questiong about the front seatbelts how to you get the top part off?
QuoteReply
Leni
post Sep 12 2006, 01:55 AM
Drives: Hyundai Excel Sprint 1997
Status: OFFLINE
Is this the same for the Excel Sprint 1997? The window doesn't go up or down anymore. It seems the mechanism is rusty (or sounds that way). Also the exterior door handle no longer works thanks to an incompetant car thief! I have managed to remove the interior panel bar the window winder and speaker.
QuoteReply
MikeNH
post Sep 17 2006, 08:16 PM
Group Icon
Group Icon
Group: Super Mod
Drives: 2003 Silverado
Status: OFFLINE
QUOTE(cslsxpistol @ Nov 28 2005, 10:17 PM)
seperate the trim at the top anchor with a small screwdriver, it will likely be a Torx (star) bolt you have to remove to take it off.
QuoteReply
ImOscar
post Jul 3 2007, 10:52 AM
Drives: 2002 Hyundai Accent GSI
Status: OFFLINE
QUOTE(Dr. Hundi @ Nov 8 2004, 07:24 AM)
I'm looking to upgrade the speakers in my 2002 Accent (2-door hatch) and this is the step that I'm on. I've taken off the window crank and removed the 6 screws, including the door handle and grab handle on the door panel. The clips are off and the whole panel is loose - except around the door handle. It's a rectangular shape so it won't rotate, and the plastic piece around the handle itself won't come off even though I removed the screw. Am I missing something here? Also the front speakers are 5 1/4", not 4" as widely reported online. Could the 2-door hatch have differences from most Accents that aren't accounted for in your instructions?
On a slightly unrelated note, I was wondering if there's room to put a 6 1/2" speaker in the back (5 1/4" there now) with the mounting adapter that comes with the speakers. It looks simple to do.
QuoteReply
> Link To Us
> Similar Threads
Autoweek Review Of 08 Accent Se
Forum : 3G (2006+) Accent
crayb 24 2 Yesterday, 11:48 PM
By: mrblank
Hyundai Accent '01 Starting Problems
Forum : 2G (2000-2005) Accent
Palin 12 0 Yesterday, 10:15 PM
By: Palin
2000 Hyundai Grandeur - Power Window Fuse
Forum : Grandeur & XG Forum
emsah7 5 0 Yesterday, 07:15 PM
By: emsah7
Engine Cover Removal
Forum : Genesis
acroplt 77 2 Yesterday, 05:40 PM
By: acroplt
3rd Brake Light Housing - Removal
Forum : 4G (2006+) Sonata
dd716ted 55 3 Yesterday, 05:33 PM
By: MiamiLX
8th September 2008 - 03:48 AM
