> Lambda Engine Maintenance, Lambda engine maintenance
jpanozzo1
post Jul 18 2006, 08:11 PM
Drives: 2000 Camry XLE
I have read elsewhere that high cost maintenance is required on the Lambda engine each 60K as it does not have hydraulic lifters. Anyone know the approximate cost in US dollars for the maintenance. :whistling:
tyguy
post Jul 24 2006, 05:51 PM
Drives: Former 06 Sonata LX owner
As far as my knowledge goes the 3.3 lambda does NOT have a timing BELT, instead a timing CHAIN is used which is service free over the lifetime of an engine.
jpanozzo1
post Jul 24 2006, 07:51 PM
You are right referring to the timing chain, I am referring to the lifters in the valve train. The Lambda has something like solid lifters that are not easily adjusted.
tyguy
post Jul 25 2006, 12:53 AM
A valve job is a valve job. Most hydraulic lifters do not even require one.
Using either the plates (like VW does since over 20 years) or adjust them by tensioning doesn't matter nowadays.
jpanozzo1
post Jul 25 2006, 01:50 PM
I have read shims or plates cannot be used; that is partially what makes the adjustment expensive. I am not a mechanic, but do a lot of reading on this and other forums. I read this adjustment is rather involved and was inquiring if anybody had a handle on the expense.
I am under the impression the Lambda does not have hydraulic lifters.
This post has been edited by jpanozzo1: Jul 25 2006, 01:51 PM
Ed MacArthur
post Feb 14 2007, 05:17 PM
Drives: 2007 Hyundai Santa Fe
It's been many months since there was a posting to this thread but I thought I would add my 2 cents. When I got my 07 SF 3.3L in December one of the first things I did was peruse the maintenance schedule, something I always do with a new car. The Maintenance Log that comes with the car shows all of the things that must be done and when. The required action is indicated with either an "R", which means "Replace", or an "I", which means "inspect, clean, adjust, repair or replace". Among the usual items requiring attention, such as oil and filter, air cleaner filter, and spark plugs, is "Valve clearance", which shows an "I" at 60,000 miles. This made me nervous because I knew this could be an expensive proposition, so I asked the Hyundai service manager what it meant. His answer was, essentially, "don't worry about it. The lifters will probably never need service, but if they do you will know it because they will start tapping. When you bring it in for the 60000 mile service we'll listen and if we don't hear anything we check this item off as 'inspected'." I just hope he knew what he was talking about.
No New Posts Engine Damper
Is it worth it?
10 bloodninja 98 Today, 07:53 AM
Last post by: Glock23
No New Posts Engine Shut Off
What's going on?
20 penguin_hash 681 1st December 2008 - 09:58 AM
Last post by: wagsmachine
No New Posts Engine Wont Start When Hot
4 kev f 126 28th November 2008 - 12:56 AM
Last post by: Madogi
No New Posts Engine Ticking
1600 kms
13 Pinto_Siftbean 756 25th November 2008 - 05:19 PM
Last post by: david-paul-1
No New Posts Engine Oild Change Interval ?
23 montclare 489 23rd November 2008 - 07:49 PM
Last post by: Propflux01
4th December 2008 - 08:37 PM
