 Hyundai-Forums.com > Hyundai Models > Terracan Forum
> Front Indicator/sidelight Unit, How do I replace the bulbs?
KevinDunne
post Jun 27 2006, 12:53 PM
Drives: 2004 Hyundai Terracan CRTD
How do I remove the front indicator/sidelight (parking light unit) so that I can replace a blown bulb?
If I take out the screw on the top of the indicator/sidelight unit, it comes slightly loose, but there's no obvious way to remove it to replace either of the bulbs. If I also remove the 3 bolts securing the headlamp unit, both plastic units move together, I can just see the connectors for the indicator and sidelight (parking light) bulbs, but can't work out how to remove the unit?
Surely this can't be a main dealer job?
icon
post Jul 18 2006, 02:17 AM
Drives: 2004 Hyundai Terracan CRT 2.9
Hi Kevin,
If you find out, please let me know as I have the same problem, and I have taken exactly the same steps as you... :)
As you say surely it’s not a main dealer job for a bulb replacement?
andyradka
post Nov 5 2006, 06:45 AM
Drives: 2005 Hyundai terracan
Have you managed to find out yet - I have same problem!!!
Edin
post Nov 5 2006, 10:39 AM
Drives: 2003 Terracan 2.9CRDi
Remove top screw and just pull it gently!
Removing the headlamps bolts - not necessary.
This post has been edited by Edin: Nov 5 2006, 10:42 AM
sardus
post Apr 10 2007, 09:03 AM
Drives: Hyundai Terracan CRDI 2005
Hello,
I faced the same problem a few weeks ago, when I wanted to replace a blown parking light bulb on the front/right of a 2005 model Terracan.
After removing the screw on the top, the indicator/sidelight unit would come slightly loose. I tried to pull it, gently at first, more forcefully later, but it still wouldn't come free. So I also removed the top three bolts of the main-headlight unit. Now the whole assembly was slightly loose, but it still would not come free.
I guessed that the underside of the main-headlight unit might still be attached to the car body. So I crawled under the car with my trusty MagLite lamp, and after a bit of squinting I saw the culprit: A fourth bolt on the bottom of the main headlight unit!
As that bolt is hard to reach from under the car, but in close proximity of the wheel housing, I decided to get to it in an unorthodox way:
I removed some of the bolts holding the plastic fender to the wheel housing, until I could lift the fender and squeeze my arm through it. After some fumbling with a wrench the bolt was loose, and I could remove the whole headlight assembly, and finally replace that troublesome 30-cent bulb!
Well, that's also when I saw that the indicator/sidelight unit is not only held to the main-headlight unit by the top screw, but also by a conical metal rod that clips (!) into a plastic receptacle on the main unit.
Yes, by removing the top screw and pulling *very* hard, you might succeed in unclipping the sidelight from the main unit - but I doubt you will do so without damaging it! The problem is that, after only two years, that metal rod is so corroded that it just won't unclip without risking to break its brittle-looking plastic receptacle...
Hope this helps.
Ah yes, I was forgetting the credits:
Thank you, Hyundai, for sticking to the current car-maker trend of making changing bulbs such a royal pain in the **** for us valued customers!
But to be fair, blown bulbs (4 to date) are the only gripe I've had with the Terracan for the past two years. I'm happy with that car in every other respect!
No new Topic has attachmentsFront Abs Sensor Rings
Help, getting nowhere fast!
24 Mickishere 2,093 Today, 05:07 AM
Last post by: mazen
No New Posts Front Washer Pump Where Is It?
front washer pump not working
2 volrider 17 22nd November 2008 - 10:35 AM
Last post by: volrider
No New Posts Front Passenger Wheel Bearing Replacement
2 protegechris 225 21st October 2008 - 10:32 PM
Last post by: ken2400
No New Posts Front Turn Signal Bulb Replacement
1 nds 79 15th October 2008 - 07:46 PM
Last post by: nds
No New Posts Front Suspension Noise
SE 3.3
15 AnthonyNY 1,791 7th October 2008 - 08:54 PM
Last post by: Tazman66
4th December 2008 - 08:56 PM
