Key Stuck In Ignition, Key Can't be Removed
| 1stHyundai |
Jun 15 2006, 12:14 PM
Drives: 2006 Hyundai Sonata LX 3.3L Status: OFFLINE
Same thing happened to me with a copy from the original. I thought I was going to break the d@*$ thing off in the ignition. The copy will unlock the doors but not lock them. Good thing I only had it made as a hide a key anyway.
| deepwater07 |
Jan 26 2007, 01:48 PM
Drives: 2007 Hyundai Sonata SE Status: OFFLINE
I'm resurrecting this thread from the past since I just had my key stuck in my ignition. I hope my experience can be transferred to others who may have the unforunate frustration of getting their key stuck in the ignition switch.
I took my '07 Sonata into the dealer to have this problem looked at. The key would not turn any further (counterclockwise) past the ACC position when the shift lever was in "P". The dealer's original assessment was that I was crazy since they were able to pull the key out. After I was able to re-create the problem, they retracted that statement.
They then proceeded to mention that they will "deburr" and grind down my key. It's a solution not to different from what was posted here earlier. I'm sure in many cases, it will help. For my case though, this was not the problem.
The reason I'm posting here is because my problem was unrelated to the key itself. It was the mechanism that connects the lock solenoid to the shift lever. When you put the lever into "P" and it slides completely left into the "P" position, if you listen carefully, you'll hear an slight "click" as the lever settles left. This "click" is what allows the ignition key to turn counterclockwise from ACC to LOCK. If the lever is not solidly in the "P" detent, you will NOT be able to turn the key from ACC to LOCK.
Apparently, the lever pivots and cable in my Sonata were not "lubed" enough. This caused the pivots in the shifting mechanism to not fully engage the switch in "P", thus preventing the lock solenoid from releasing.
The moral of this story is: if your key is stuck, and you're sure it's not something you did, slide the lever side to side in "P". If you don't hear that slight click as the lever moves all the way to the left, that may be the cause. (It could also be the lock solenoid itself, but that's a topic for another time that will hopefully never come.)
| janisutx |
Jul 3 2008, 01:12 PM
Drives: 2007 Sonata Limited 3.3 Status: OFFLINE
I have had the stuck key problem since Dec. 06. The ignition cylinder was replaced last week. That didn't help so it's back at the dealer today. Thanks for the information on the lubrication solution. I just faxed it to the service department. The worst part is that everyone thinks I'm crazy since the key always comes out at the dealer. I'm tired of having to leave the key stuck on ACC while I shop. For about 4 months the Sonata didn't have the problem but it's back with a vengeance.
For some reason I rarely have the problem in the morning when I drive to work but on the way home it's my lucky day if the key comes out of the ignition. Thanks for posting your information.
Track this topic
Subscribe to this forum
Download / Print this Topic
Link To Us
Similar Threads
Similar Threads
5th September 2008 - 06:20 PM |
