Check engine light - Hyundai Forums : Hyundai Forum
post #1 of 8 Old 08-12-2013, 02:13 PM Thread Starter
2012 Hyundai Sonata Hybrid; 2003 Toyota Sequoia
tommypolo is an unknown quantity at this point
Check engine light
Yesterday (Sunday) morning, as I was leaving work, my check engine light came on. About a mile later I pulled off the road and checked the gas cap. I took it off and made sure it was re-installed correctly. CEL stayed on. Had to drive it back to work Sunday night. This morning I was in line at the service department when they opened at 7:30. It was caused by code P0455 Purge Evap Emission Leak. I spoke with the tech when he brought my car back around. He stated that I was a history code, not an active one. He performed a leak test and it passed. Also stated that if it came back in they would need the car longer to perform a more conclusive leak test. He also said that if it came back in solid that I could still drive the car without issue, that if the CEL was flashing it would mean there was eminent catalytic converter damage. Crossing my fingers it was a one time deal since I go on vacation this Friday.
tommypolo is offline
post #2 of 8 Old 08-12-2013, 02:49 PM
Fishnrib's Avatar
2011 Sonata Hybrid Premium 2003 Santa Fe, 2012 Kia Soul, 1997 Club Car EV
Quoted: 106 Post(s)
Fishnrib is an unknown quantity at this point
Before Oct 2011 P0455 Purge Evap Emission Leak was a common occurrence that most of us experienced until they came out with a better part. My wife drove from Memphis to San Diego with the CEL on steady without any problems. Make sure and get your ECU Update so your car will perform better when you get back from your vacation. Make sure you read how to get it here.
New Multi ECU update!
Tom
Wayne Gerdes and Tom
Fishnrib is offline
post #3 of 8 Old 08-12-2013, 03:10 PM
2011 Sonata Hybrid Base
Quoted: 20 Post(s)
vinnyg is an unknown quantity at this point
I realize you have a 2012 but that code was very common with the early 2011 buyers.
Browse through this thread when you get a chance:
Recall Notice All 2011 Sonata Hybrids
vinnyg is online now
post #4 of 8 Old 08-12-2013, 06:22 PM Thread Starter
Thanks for the link to the previous thread. Very helpful. I already got the ECU update performed in July. Took car on a trip from FLorida to Cleveland, OH and back after the update. Overall MPG (via fuelly without 3% correction) is 37.8 mpg. My current tank was averaging almost 46 mpg (via trip computer) for just over 1/4 tank. I have a 23 mile, mostly highway with 5 or 6 lights/stop signs, each way commute. Once the CEL/MIL came on my average has dropped to 44 with same driving habit and commute. Coincidence? Maybe.
post #5 of 8 Old 08-12-2013, 07:13 PM
2004 accent
Quoted: 120 Post(s)
zero_gravity is an unknown quantity at this point
indirectly possibly. the CEL flashing indicates imminent failure of the car itself. examples are misfires, electrical system failure, etc. its not really about the cat.
zero_gravity is online now
post #6 of 8 Old 08-13-2013, 05:26 AM Thread Starter
I think the tech was just refering to this particular evap leak issue.
post #7 of 8 Old 08-13-2013, 10:06 AM
Drives 2011 Hyundai Sonata Hybrid Premium Light Blue
Quoted: 20 Post(s)
reglee51 is an unknown quantity at this point
Same CEL and error code on my 2011. Replaced NVLD sensor 2X already in the past months (only happened since 55k miles for me; I never had the NVLD issue early on that some other early owners have had), it's in the shop this week for 48 hours for the hybrid tech to replace/diagnose further. Apparently our evap check system is unique since it only runs at night. This is why the CEL turns on in the morning. Ny hybrid tech states mine's not the only sonata hybrid with this issue. For me, it turns on whenever there's a very cool morning after a very hot day. Please let me know if your dealer finds a solution.
reglee51 is offline
post #8 of 8 Old 08-14-2013, 01:45 PM
jglopic's Avatar
Drives YF Sonata Hybrid
jglopic is an unknown quantity at this point
A not on EVAP CEL indicators - if the issue is an improperly sealed gas cap, the light will typically come on at the first indication of EVAP test failure. If you re-seal the gas cap, it can take 2 or 3 driving cycles on the engine for the light to clear. That may be why you had a "historical" code but still had the CEL on - you re-seated the gas cap, but hadn't put enough driving cycles on the ECU to clear the light. Service tech should have cleared the historical code which also resets the light. Hopefully that takes care of the issue!
Touring the greater Houston area and trying to save a little gas doing it!
jglopic is offline
User Tag List
