2002 Santa Fe Speaker Problem - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 03-15-2009, 04:03 PM Thread Starter
limitedsr
I am having speaker problems in the drivers door of my 2002 Santa Fe. There is no volume at all in either of the 2 speakers. All of the speakers in the passanger door work and both rear speakers work. Does anyone have any ideas for me. Thank you very much for your help.
limitedsr is offline
post #2 of 12 (permalink) Old 03-19-2009, 08:32 AM
pm0080's Avatar
pm0080
mine is the same... 2002 RHD 2.0 Diesel
pm0080 is offline
post #3 of 12 (permalink) Old 03-19-2009, 09:58 AM Thread Starter
limitedsr
QUOTE (Paul_NI @ Mar 19 2009, 07:32 AM)
Paul, it is really baffeling, I don't know if it is a problem with both speakers in the driver door, a loose connection somewhere or a problem in the radio. I am not sure how to get the door panel off or how to get the radio out or what to check. Thanks.
post #4 of 12 (permalink) Old 03-20-2009, 10:00 AM
pm0080's Avatar
pm0080
Check here for how to take the door panel off: Speakers and Alarm
I must get around to check what is wrong with it as well as the draft from the passenger side foot well. I presume your SF is Left hand Drive, Mine is Right hand Drive strange they both have the same issues, just different side
pm0080 is offline
post #5 of 12 (permalink) Old 03-20-2009, 04:14 PM Thread Starter
limitedsr
I sure wish that someone who has had a similar problem with their speakers in a Santa Fe or other Huyandi (speaker problems in the drivers door of my 2002 Santa Fe --- no volume at all in either of the 2 speakers --- and all of the speakers in the passanger door work and both rear speakers work) and who has fixed the problem would let us know what was wrong.......... SPEAKERS ..... RADIO ....... or WIRING. Thanks.
post #6 of 12 (permalink) Old 03-21-2009, 07:01 PM Thread Starter
limitedsr
In the 2002 SantA Fe in the speakers in the doors, is there an amplifer or transformer on the speaker in each door or at each speaker. Thank you
post #7 of 12 (permalink) Old 03-21-2009, 07:02 PM Thread Starter
limitedsr
In the 2002 Santa Fe in the speakers in the doors, is there an amplifer or transformer on the speaker in each door or at each speaker. Thank you
post #8 of 12 (permalink) Old 03-23-2009, 07:46 PM
Santa Fe 08 Limited AWD Santa Fe 02 GLS (Traded In) 2013 Sonata GLS w/ Popular pkg. (Traded In) 2
ItalianM87
im having the same problem on my 02 santa fe v6 also, driver's side speakers (both) are not working.. others are fine
2013 Sonata GLS w/ Popular pkg - Mods: LED Cup mod - F2.4 GDI Emblem - LED DRLs Fogs - 3M Clear film Protector for Bumper, hood, fenders - LED license plate bulbs 6000k - More to come.
ItalianM87 is offline
post #9 of 12 (permalink) Old 03-25-2009, 03:00 PM
SYLrules88's Avatar
2005 Santa Fe 2.7L
Quoted: 5 Post(s)
SYLrules88
ill be right back up here with some photos and instructions for removing the door panels. give me 30-60 minutes
SYLrules88 is offline
post #10 of 12 (permalink) Old 03-25-2009, 05:31 PM
SYLrules88's Avatar
2005 Santa Fe 2.7L
Quoted: 5 Post(s)
SYLrules88
first, pull out the ash tray and remove by pressing the release lever.
remove the two screws. grab the lip firmly and pull toward you and the bottom half should release. one side of the top should release too.
grab the top towards the center and pull until the other side releases. ive done this several times over the past few days so both sides usually release at the same time.
disconect these three clips
from these sockets. this might be a pain in the **** the first few times.
remove the two screws as indicated by the arrows. they are facing upward.
check your wiring harness to make sure theres a solid connection.
make sure the harness plugging into your stereo is connected.
just so you all know, the green, violet, white, and gray wires are for each of the 4 speakers. the blue wire is the remote turn on. the two orange wires are some kind of dimmer and illumination but i havent figured out exactly what they do. the black is the h/u ground, the black/white is the stock amp ground, and the yellow and red are constant power and one of em turns on your stereo when you turn your key to the accessory position but i forget which one.
funny that since sunday i havent been getting any sound from my speakers either but that was after i put in my aftermarket head unit that you see in the photos. i have one idea that im going to try later tonight that involves me removing my passenger seat and looking at the tiny stock amplifier underneath to check for a blown fuse. check your fuse box for the audio and amplifier fuses. i forget off the top of my head where they are but just look at the diagram on the back of the fuse panel cover. beyond that i dont know what else to say. hope i helped at least a little?
