Tune up cost? - Hyundai Forums : Hyundai Forum
post #1 of 11 (permalink) Old 03-27-2013, 11:25 AM Thread Starter
2004 Sante Fe
Dadvball is an unknown quantity at this point
Tune up cost?
I have a 2004 with the 3.5 engine, 4WD,, automatic, 180,000 miles. Anyone have an idea what a tuneup might cost? I tried asking the dealer and was told it would be around $700.00 or so. The guy told me the plugs and wires are expensive and it's a few man hours because of the plug location. I can't imagine it would be that high but what do I know.
Dadvball is offline
post #2 of 11 (permalink) Old 03-27-2013, 11:54 AM
Quoted: 54 Post(s)
A "tuneup" is one of the most undefined terms used for cars so you need to define which items are faulty and need replacing.
2016 VW Touareg 3.0TDi
Ruperts Trooper is offline
post #3 of 11 (permalink) Old 03-27-2013, 12:20 PM Thread Starter
2004 Sante Fe
I forgot that a tune up on today's cars isn't the same as a tune up on cars with distributors, points, and condenser that I had years and years ago. I'm curious on what anyone has paid a dealer to replace plugs and wires and if the amount I was quoted is realistic.
Dadvball is offline
post #4 of 11 (permalink) Old 03-27-2013, 12:31 PM
Quoted: 1428 Post(s)
(6) - 18817-11051 PLUG 81.48
(1) - 29215-37100 GASKET SURGE TANK 18.48
PARTS: $ 99.96
LABOR: $ 225.00
SHOP SUPPLIES: $ 15.00
TAX: $ 23.80
TOTAL: $ 363.76
Add plug wire set - 27501-39A70 CABLE Set 89.94
Add coils if burn - 27300-39700 COIL -IGNITION 93.42 each
sbr711 is offline
post #5 of 11 (permalink) Old 03-27-2013, 12:39 PM Thread Starter
2004 Sante Fe
Excuse my ignorance, but what is a gasket surge tank, and how many coils are there? Thanks!
Dadvball is offline
post #6 of 11 (permalink) Old 03-27-2013, 01:09 PM
1966 Mustang Coupe (Resto project) 1999 Toyota Camry LE 2002 Hyundai Santa Fe LX (2.7L V6)
TXMAG is an unknown quantity at this point
I would assume the gasket SBR711 is quoting is the plenum gasket. This should be replaced since the intake manifold needs to be removed to access the plugs in the rear.
Your Santa Fe would have (6) coils, although these should be replaced on an "as-needed" basis.
I'd suggest changing the plug wires at the same time as the plugs since it would be a real kick in the balls to have to take everything back down to get them done later.
TXMAG is offline
post #7 of 11 (permalink) Old 03-27-2013, 01:59 PM
johnaauld's Avatar
2003 2.7 Santa Fe 2001 3.0 Z3 1996 Lexus ls400
Quoted: 275 Post(s)
I believe there are 3 coils(each coil handling two spark plugs). Could be wrong though, but that is how it is with a 2.7. $700 sounds a little high to me, I think the local Hyundai shop wanted around $500 when I did my own spark plugs on my 2.7. With your high mileage, you should really do the wires at the same time you do your plugs. If you use iridium plugs, they should last you the life of your car.
johnaauld is offline
post #8 of 11 (permalink) Old 03-27-2013, 02:29 PM
I think you're right John. I probably mixed it up with something else I do maintenance on.
TXMAG is offline
post #9 of 11 (permalink) Old 03-27-2013, 09:20 PM
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
Quoted: 73 Post(s)
If you're at 180K and the timing belt has been changed at 60 and 120, you'll be due again. Something to consider....
Andrew
Titanium Gray / Gray Leather
lovemysantafe is offline
post #10 of 11 (permalink) Old 03-27-2013, 09:50 PM
The 3.5 used in the Santa Fe and XG uses (3) ignition coil located at Bank 2,, then we have 3 spark plug that fire the 3 plugs at Bank 1.. waste spark system --> Use NGK Platinum as installed from factory, or upgrade to NGK IRIDIUM, they wont burn like Platinum, they'll last longer (100,000 mile common replacement call out)
The "gasket" is for the plenum to lower intake mating surface,, we have to remove the plenum to access the plugs and wires at Bank 1.
sbr711 is offline
