2002 Santa Fe running poor - Hyundai Forums : Hyundai Forum
post #1 of 4 (permalink) Old 02-18-2013, 02:26 PM Thread Starter
2002 Hyundai Santa Fe V6 2wd
davidgriswold is an unknown quantity at this point
I just completed repairing bent valves and a broken timing belt in a 2002 Santa Fe. It started up immediately, but it appears to be not firing or bad compression on at least one cylinder and had low power. Even when I put my foot in it and it shifts down/revs up, power is still low.
A little history. I have never driven this car before the repair. I picked it up for $1000 knowing it had at least bent valves. This is not my first head/valve/timing belt replacement, but my first time with a V6 with dual cams, so there was a little learning on this, but I never felt uncomfortable with it. It IS possible that I got chains or belts off by a tooth one way or another, but I suspect i would have much worse performance if that was the case and not just the dead sound I am hearing from what sounds like a missing cylinder.
Also, the check engine light has come on since I first started it, so I need to get the codes checked.
What are my first steps to troubleshoot this? Any thoughts are welcome.
David Griswold
davidgriswold is offline
post #2 of 4 (permalink) Old 02-18-2013, 07:36 PM
pattyd's Avatar
Drives '02 Santa Fe GLS 2.7L 4WD "Haylee"
pattyd is an unknown quantity at this point
Have you tried pulling the plug wires while it's running? If its a cyl not firing, that'll tell you which one it is.
But go ahead and get the DTCs to point you in the right direction.
It might not have been something you did, it might have been some other problem caused by the timing belt break.
pattyd is offline
post #3 of 4 (permalink) Old 02-21-2013, 08:04 PM
Drives a Santa Fe 2.0L diesel, 4WD, year 2004
Quoted: 9 Post(s)
paul03 is an unknown quantity at this point
You might check in at the service site https://www.hyundaitechinfo.com/ .
It has lots/loads of servicing information and manuals etc on the car.
You need to simply log in to enter.
Maybe you missed something in the procedures.
Good luck,
Paul
paul03 is offline
post #4 of 4 (permalink) Old 02-22-2013, 10:40 AM
pattyd's Avatar
paul03 is right. I created an account there not too long ago, its free of charge, and it provides the entire shop manual, owner's manual, and all TSB's for every hyundai make, model, and year.
pattyd is offline
