High Idle Speed - Hyundai Forums : Hyundai Forum
post #1 of 3 (permalink) Old 01-07-2013, 11:30 PM Thread Starter
Drives 2004 Hyundai Santa FE 5 speed transmission
cajunbob1220 is an unknown quantity at this point
High Idle Speed
2004 2.4l engine has high idle speed aprrox. 1000rpm. any ideas?
cajunbob1220 is offline
post #2 of 3 (permalink) Old 01-08-2013, 05:29 PM
Drives a Santa Fe 2.0L diesel, 4WD, year 2004
Quoted: 9 Post(s)
paul03 is an unknown quantity at this point
Hi Bob,
Well, maybe your throttle pedal sensor is giving too high voltage signal when idling.
You could check by undoing the pedal sensor connector at the throttle pedal.
When revs fall back then it's that pedal sensor. Could then also be a grounding wiring problem for at idle those are very low voltages.
When revs stay high, something else is going on.
However, the EMU will not like it and throw the check engine light, but when you put back the connector the light will go out by itself after some rides.
It will also write some error codes in memory but they can be discarded when you check for error codes.
So, when revs stay high, maybe a bit stuck throttle valve at the air intake or a foreign object inside.
It all is EMU controlled voltages so cure of EMu is a bit difficult.
In some post about idling I read about a throttle valve learn, so maybe that is the case. Check other earlier threads about idling.
Good luck,
Paul
paul03 is offline
post #3 of 3 (permalink) Old 01-08-2013, 09:14 PM
lifeblows10's Avatar
Drives '16 Sonata Hybrid Limited
Quoted: 61 Post(s)
lifeblows10 is an unknown quantity at this point
Cold? Hot? Considering it is winter that is not at all a high idle. My V6 will run at 1500rpm for about 30 seconds before going to around 1100 rpm until the car (engine and tranny) are warmed up. Then she idles at less than 750 rpm.
lifeblows10 is offline
