2002 santa fe v6 alternator serpentine belt question - Hyundai Forums : Hyundai Forum
post #1 of 5 (permalink) Old 09-09-2012, 12:37 AM Thread Starter
2002 santa fe
Quoted: 6 Post(s)
jay2000 is an unknown quantity at this point
Hello all, Im about to replace my failed alternator on my 2002 v6 santa fe with a new one. According to the hyundai service website the newer alternators are rated at 110 amp, (vs 95 amp for the original alternator) which is what my new after market alternator is rated at, 110 amp. Addiionaly, the web site specifies that the newer alternators also have with a smaller pulley 58 mm vs 62mm. However, I measured the pulley on the new after market alternator and the pulley diamter measures approx 62mm. My question, has anyone replaced a 95 amp with a 110 and if so, can they recommend a belt or belt length? i want to make sure i use the correct legth belt.
Jerry
jay2000 is offline
post #2 of 5 (permalink) Old 09-09-2012, 12:51 AM
Drives 2003 Santa Fe
mario349 is an unknown quantity at this point
If the pulley is indeed a 62mm one then the old belt should fit fine, although I would recommend a new one. All else should mount the same.
mario349 is offline
post #3 of 5 (permalink) Old 09-09-2012, 01:09 AM
Quoted: 1236 Post(s)
2003 got a new alternator, part covers earlier models, uses shorter belt..
Part numbers valid ay Hyundai and Kia dealers
A new generator is available for the 2.7L V6 Engine. The changes to the generator are:
1 - The generator pulley size (as measured to the top of the belt grooves) has been decreased from 62mm (2.44") to 58mm (2.28"). This results in higher generator speed and output at engine idle.
2 - The voltage regulator's temperature compensation has been changed to lessen the drop in generator performance as the temperature increases
3 - The part number of the generator has changed
These changes result in improved generator performance at low engine speeds
Other than the different labels and pulleys, the generators look the same.
As a result of the change in the pulley size of the generator, the serpentine belt has also been changed, as outlined in the table below.
The new belt is approximately 5mm (0.2") shorter than the previous belt.
OLD:
NEW: (current 37182)
sbr711 is offline
post #4 of 5 (permalink) Old 09-10-2012, 01:02 AM Thread Starter
2002 santa fe
Quoted: 6 Post(s)
thanks for the detail feedback!! Since the after market alternator has the original size pulley 62 vs 58 i decided to order an OEM belt. I will keep everyone posted on teh progress may try this weekend or next weekend. Thanks again!
jay2000 is offline
post #5 of 5 (permalink) Old 04-30-2014, 09:43 AM
happygolucky is an unknown quantity at this point
Okay, this is what happen when I put in a 110 alt compared to a 95amp. the tranny will not shift right and the radio will keep coming on by itself.. make Shure u put a 95amp alt back in it. I was ask for the ID number inside the door or on the dashboard, also the year the truck was made. the belt must be the right size also..
happygolucky is offline
