help santa fe died - Hyundai Forums : Hyundai Forum
post #1 of 3 (permalink) Old 05-29-2012, 04:05 PM Thread Starter
hyundai 2.o d santafe
bigmal1340 is an unknown quantity at this point
Unhappy help santa fe died
hello there 2.0 crdi santa fe stopped and engine management came on took it to dealer and they said no code to read ..got second opinion and the guy read the code and came up with 001 ..p1181 int.air var ctl.sol (open gnd) help what is this ..he also said that he thinks it a injector problem rather than this ...the car will start with a tow and drive a short distance and stop again any ideas would be welcome thanks in advance
bigmal1340 is offline
post #2 of 3 (permalink) Old 05-29-2012, 07:36 PM
Drives a Santa Fe 2.0L diesel, 4WD, year 2004
Quoted: 9 Post(s)
paul03 is an unknown quantity at this point
To my info P1181 is problem with fuel pressure on the common fuelrail.
It could mean you do not have enough fuel pressure on the rail giving bad performance by the injectors. They could not inject enough fuel given the compression pressure of the cylinders.
You would have to look at your high pressure fuel pump, or you might even have only a clogged fuel filter.
Or it could mean the pressure sensor on the rail is faulty. Then you must check it (variation of signal when starting, giving pressure) or the electric connections.
Good luck,
Paul
paul03 is offline
post #3 of 3 (permalink) Old 05-30-2012, 03:41 AM Thread Starter
thanks for the info high presure pump was done up last year and one injector new filter fitted new presure swith fitted going for the other three injectors
