2.7 Spark Plug Change - Hyundai Forums : Hyundai Forum
 1Likes
post #1 of 13 (permalink) Old 10-19-2010, 03:21 PM Thread Starter
johnaauld's Avatar
2003 2.7 Santa Fe 2001 3.0 Z3 1996 Lexus ls400
Quoted: 275 Post(s)
I found this on the internet with a picture guide on changing the spark plugs on a 2.7 santa fe. Any thoughts from anyone who has done this as to how good a guide this is? My local dealer wants $500 to change the plugs and I'm thinking about doing it myself. Here is the site:
http://santafemods.com/Mods/SparkPlugReplacement.htm
affane78 likes this.
johnaauld is offline
post #2 of 13 (permalink) Old 10-19-2010, 04:17 PM
Quoted: 1422 Post(s)
NGK Platinum or NGK IRIDIUM (upgrade) and new set of Hyundai plug wires since intake already off and mileage... bad to have a misfire code next week and have to do it all over again..
sbr711 is offline
post #3 of 13 (permalink) Old 10-19-2010, 06:53 PM
pemdas1972's Avatar
Drives 2002 Santa Fe LX 2.7 4wd 250,000 miles
Quoted: 14 Post(s)
pemdas1972 is an unknown quantity at this point
Yes, I used this guide to do my plugs and it was accurate for me. It took me about an hour to do the job. Just make sure you put a new plenum gasket and as sbr711 stated to replace the wires and use NGK spark plugs.
pemdas1972 is offline
post #4 of 13 (permalink) Old 10-19-2010, 08:14 PM Thread Starter
johnaauld's Avatar
Quoted: 275 Post(s)
QUOTE (pemdas1972 @ Oct 19 2010, 04:53 PM)
Thanks, I was wondering if anyone had done this as a guide. I'll try it this month.
post #5 of 13 (permalink) Old 10-19-2010, 08:50 PM
audiracer88
If you're going to replace the spark plug wires, I recommend Magnecor KV85 wires. They're the best you can get and you won't have to replace them for a very long time!
NGK iridium plug are the way to go too. They don't need to be replaced for a long time either. Saving you needless repeats of this job.
audiracer88 is offline
post #6 of 13 (permalink) Old 10-20-2010, 06:25 PM Thread Starter
johnaauld's Avatar
Quoted: 275 Post(s)
QUOTE (johnaauld @ Oct 19 2010, 06:14 PM)
Just got done changing the spark plugs. Have to say up front that I used the champions that the dealership sold me last year and they cost around $60 if I remember right. I had changed the three up front last year so just changed the back three today. I would have to say there is one tool missing on the list. I think a magnetic wand to pick up dropped tools(for me it was a 12mm on a stubby extender that I managed to drop. It was also good for fishing out the spark plugs(my spark plug remover doesn't have any rubber insert). The only other thing I had a problem with is when it said to lift plenum off studs. I yanked and pulled and tugged for a good long while without budging it a bit. Finally I carefully pried the sides with a flat blade to get it started to move. I also saw some aluminum shavings around the stud and bolt holes that I carefully brushed to the outside before I put the cloth on the intake side. Took me two hours but I'm not the worlds greatest mechanic and some of the problems stated above where a good part of my time. Thanks again to whoever put that post together. I wouldn't have done it without it and the dealership would be $500 richer.
post #7 of 13 (permalink) Old 11-16-2010, 03:09 PM
bdh
2002 & 2003 Santa Fe 2.7s FWD
Quoted: 27 Post(s)
bdh
Thumbs up
The link provided for the spark plug replacement seems straight forward enougn...but shouldn't I be concerned with the torque values for reinstalling everything?
Does anyone know the proper torque values for the plenum bolts?
Thanks,
Bruce
bdh is offline
post #8 of 13 (permalink) Old 12-08-2010, 09:13 AM
techjpc
QUOTE (pemdas1972 @ Oct 19 2010, 06:53 PM)
What is a plenum gasket and where does it go ? Also, he mentions a Metal Crush Gasket, what is that ?
He never says what to do with these two items.
Joe
techjpc is offline
post #9 of 13 (permalink) Old 12-08-2010, 11:25 AM Thread Starter
johnaauld's Avatar
Quoted: 275 Post(s)
QUOTE (techjpc @ Dec 8 2010, 07:13 AM)
Joe
If you go to step 16 and look at the picture- you will see the black gasket that runs the length of the intake. I'm not sure what the metal crush gasket was for as I did not notice it while doing this repair. I reused the original gasket on the intake when I did my spark plugs and had no trouble after the job was finished- the car started right up with no air leaks in the intake. As to the poster above you, it took a fair amount of torque to get the bolts and nuts off the intake and I used a fair amount putting it back on. Didn't use a torque wrench. Hope that helps.
post #10 of 13 (permalink) Old 12-08-2010, 07:28 PM
Plenum gasket -- see picture.
Tighten plenum bolts to 17 lb-ft, same for rear bolts at support bracket.
sbr711 is offline
