P0320 Code - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 08-06-2010, 05:14 PM Thread Starter
keymanrick
2004 Santa Fe tac is not working properly. I get a P0320 Code.Cold someone tell me how to repair this and where the part or sensor is located for this problem.
keymanrick is offline
post #2 of 12 (permalink) Old 08-06-2010, 05:17 PM
Mr Pogle's Avatar
Drives an i10 style
Mr Pogle
Send a message via MSN to Mr Pogle
Hi and to the forums.
I'm moving this over to the Santa Fe forums where you'll get more help.
Dave
Mr Pogle is offline
post #3 of 12 (permalink) Old 08-07-2010, 09:26 AM
Quoted: 1232 Post(s)
QUOTE (keymanrick @ Aug 6 2010, 04:14 PM)
0320 is applicable to both the 2.4 & 3.5......... Which engine you got ??
sbr711 is offline
post #4 of 12 (permalink) Old 08-07-2010, 02:05 PM Thread Starter
keymanrick
QUOTE (sbr711 @ Aug 7 2010, 08:26 AM)
2.4
post #5 of 12 (permalink) Old 08-07-2010, 11:22 PM
QUOTE (keymanrick @ Aug 7 2010, 01:05 PM)
2.4
General Description
Ignition failure sensor is used to check whether the spark ignition is occurred correctly or not and also used to tachometer drive. The sensor monitors the voltage difference between a resistance which is on the battery circuit for ignition coil. When the ignition coil works properly, the electric current through the resistance is detected as voltage drop. This is confirmed for every ignition event with the crankshaft sensor and the camshaft sensor. If PCM detects a malfunction, no ignition is possible, so the engine would not start. If there is no ignition signal for a predetermined cycle for one or two ignition coils, an ignition coil circuit failure exists.
sbr711 is offline
post #6 of 12 (permalink) Old 08-09-2010, 05:05 PM Thread Starter
keymanrick
QUOTE (sbr711 @ Aug 7 2010, 10:22 PM)
General Description
I can not find the IG Failure sensor at any auto parts stores. Could this part also be called a Camshaft sensor? It seems to look and be in the same place/ Thanks
post #7 of 12 (permalink) Old 08-09-2010, 05:13 PM
QUOTE (keymanrick @ Aug 9 2010, 04:05 PM)
Part number is : 27370-38000 (new part number) -- $80 and change, available at Hyundai and Kia dealer... spot on our shelf is currently empty this afternoon
sbr711 is offline
post #8 of 12 (permalink) Old 08-14-2010, 03:31 PM Thread Starter
keymanrick
QUOTE (sbr711 @ Aug 9 2010, 04:13 PM)
That part worked Thank You Very Much
post #9 of 12 (permalink) Old 05-20-2015, 08:37 PM
drh750 is an unknown quantity at this point
Ignition Failure Sensor. I had the exact same issue. Kind of hard to believe as my OBD reader was directing me to a speed sensor, but, Ignition Failure Sensor is the one to replace. Very easy top of engine 2 screws. Worked on my GX350 part number 2737038010
drh750 is offline
post #10 of 12 (permalink) Old 06-03-2015, 03:57 PM
2003 Santa Fe 2.7 2003 Santa Fe 2.4
Danmcc is an unknown quantity at this point
Does anyone know if the IG failure sensor on a 2.4 Santa Fe is interchangeable with an IG failure sensor on a 2.7?
Danmcc is offline
