Help With Code Po421 - Hyundai Forums : Hyundai Forum
post #1 of 7 (permalink) Old 05-20-2010, 12:17 PM Thread Starter
Santafe 2004 2.4l Automatic
snake52
Hi guys
i used code reader in my 2004 santa fe 2.4l engine and i got P0421 about the catalyst i think what should i do Please help is't dangerous or not ?
thank you
snake52 is offline
post #2 of 7 (permalink) Old 05-20-2010, 01:43 PM
Spawn's Avatar
2015 Sonata Sport Tech 2.4 aka the Stormtrooper 2013 Veloster NA Tech, aka Darth Veloster
Quoted: 9 Post(s)
Spawn is an unknown quantity at this point
According to OBDII-Codes.com
Symptoms
You will likely not notice any drivability problems, although there may be symptoms. The code may be more likely to occur after the engine has had numerous cold starts in the past 1-2 days.
Causes
A code P0421 may mean that one or more of the following has happened:
The catalytic converter is no longer functioning properly
An oxygen sensor is not reading (functioning) properly
A sparkplug is fouled up
Possible Solutions
Measure the voltage at the oxygen sensor on Bank 1 (the rear sensor, or the sensor after the converter). In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
One thing to note is that many vehicle manufacturers offer a longer warranty on emissions-related parts. So if you have a newer car but it's out of it's bumper-to-bumper warranty, there still may be warranty on this type of problem. Many manufacturers give a five year, unlimited mileage warranty on these items. It's worth checking into.
"the universe has a way of balancing itself"
Spawn is offline
post #3 of 7 (permalink) Old 05-20-2010, 01:48 PM
Quoted: 1184 Post(s)
Plan on a catalyst, should be an 8/80 part I think..
28530-38780 CASE ASSY-CATALYST $ 937.13
28535-38150 GASKET-CATALYST CASE $9.41
Add local shop labor, and possible bolts/studs/nuts as required, and gasket ot bottom of catalyst to front pipe..
sbr711 is offline
post #4 of 7 (permalink) Old 05-20-2010, 05:40 PM Thread Starter
snake52
QUOTE (sbr711 @ May 20 2010, 11:48 AM)
Thank you (Spawn and sbr771) is there any pictures to show me how to change it and if there is any other solution because it seems expensive i have change my spark plugs from a month ago, dose spark plugs wires can cause that as well.
snake52 is offline
post #5 of 7 (permalink) Old 05-20-2010, 06:05 PM
Cat does not die on its' own, something killed the cat..
You mention plugs & wires, extended mis-fire will kill a catalyst, overheat and meltdown.
sbr711 is offline
post #6 of 7 (permalink) Old 05-20-2010, 09:48 PM Thread Starter
snake52
But i have checked with the code reader about mis-fire it was ok no mis-fire over heat i haven't experience that before with my vehicle
Meltdown i dont know what you mean with that !!
thank you
snake52 is offline
post #7 of 7 (permalink) Old 05-20-2010, 11:15 PM
QUOTE (snake52 @ May 20 2010, 08:48 PM)
thank you
You stated in previous post you replaced plugs a month ago... was the engine running bad/bucking/jerking/MIL flashing ??
Misfire will kill a cat.. what happens is the raw fuel from cylinder gets dumped into cat, and burn there,, this in turn overheats the cat element, and it melts down... it is a ceramic honeycomb in a sense with precious metal to aid the reaction of the cat.. when the honeycomb overheats and melts down, it can clog the exhaust.
sbr711 is offline
