Mirror-ectomy complete! - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 04-06-2013, 12:44 AM Thread Starter
Drives 2009 Santa Fe Limited and 2013 Accent SE.
Quoted: 13 Post(s)
neile is an unknown quantity at this point
Well, it took two nights but I just finished up replacing the stock mirror on my 2013 SE Accent with a
Gentex replacement Gentex replacement
that includes auto-dimming, compass, Homelink, and temperature display.
I was going to do a full DIY but it turns out that Hyundai's service site already has detailed install instructions for the factory auto-dimming mirror. I can't figure out how to direct link to the PDF, but if you go to www.hmaservice.com and click on Technical Training > Install Instructions and filter by 2013 Hyundai Accent you'll easily find it.
Here's a few photos of notable things along the way.
The mirror, temperature sensor, and wiring harness that came in the kit. The pack of t-taps on the right were ones I bought from O'Reilly, but they weren't the right size so I didn't use them.
The A pillar trim removed prior to running the mirror wiring. Unfortunately on the 2013 Accents to get the trim off you have to cut a retaining clip that keeps the trim from going flying when the airbag deploys. It's a $3.60 part, so not too expensive, but none of the dealers in town stocked it. I'm hoping it arrives on Monday. Make sure you replace this clip. If you don't have it and the airbag goes off that trim piece is going FLYING.
The fuse panel with the completed wiring. While the Hyundai instructions say to use t-tap connectors I couldn't find any the right size and honestly wasn't wild about cutting into the factory wiring harness. Instead I used Add-a-Circuits, tapping into the cigarette lighter circuit (just like the Hyundai instructions) and a spare 10A constant circuit from the fuse diagram. I initially used wire nuts to connect the AACs to the mirror wires, and then when I was happy it worked I took off the wire nuts and soldered then heat-shrinked the connections properly.
Note that if you're using Add-a-Circuit orientation matters. If you find the mirror isn't working (like I did when trying to program Homelink) it means you have the thingy in upside down.
Note that while I was doing this I also installed a cigarette lighter outlet up under the dash and wired it into the same switched circuit, and then jammed a USB charger for my phone into it and routed the cable out to the dash via the gap between the door weather stripping and A pillar.
Wiring the temperature sensor was the hardest part because I completely screwed up on my first attempt. I figured I could get through the firewall up high, just behind the battery. Turns out that hole only goes to the windshield washer motor. I found this out after I got my fish tape completely stuck back there. I had to take the wiper arms and windshield cowl off so I could get the fish tape free. Minor heart attack. Guh. The right place to go through is farther down the firewall:
I used a skewer from the kitchen to poke a small hole in the grommet and then my wife helped feed a starter piece of wire through while I grabbed it from under the dash. Then we taped the temperature sensor wire to it and pulled through. After that it was easy enough to zip tie the wiring harness to other wire runs in the engine bay and then route down to the front bumper:
I just have to remember this sucker is attached when I take the bumper off to do a horn-ectomy tomorrow
The completed mirror! Hopefully this inspires others to do this and if you have questions let me know.
Neil
neile is offline
post #2 of 12 (permalink) Old 04-06-2013, 04:48 AM
Drives Accent GLS
erik93203 is an unknown quantity at this point
looks like a lot of work to do.
erik93203 is offline
post #3 of 12 (permalink) Old 04-06-2013, 07:47 AM
NAMoosedog's Avatar
Drives 2012 Accent SE Mocha Bronze Automatic
Quoted: 8 Post(s)
Thanks ! Looks more "time consuming" than "hard".
NAMoosedog is offline
post #4 of 12 (permalink) Old 04-06-2013, 10:55 AM
KDM
KDM's Avatar
Hyundai Accent SE/MT/1600CVVT
Quoted: 20 Post(s)
KDM is an unknown quantity at this point
I thought mirrors had the temperature sensor built, but wired the sensor is hard. BTW is looks very nice, excellent work congratulations
Plasti Dip Wheels, Heated mirrors, Black edge Fog Light, Engine cover, 205/50/16 tires, Shark fin Antenna, Remote trunk release opening, Smart rele windows, K&N filter.
KDM is offline
post #5 of 12 (permalink) Old 04-06-2013, 11:48 AM
northey87's Avatar
When I did mine I attached the temp sensor to the black plastic cowling in front of the radiator and ac condisensor on the passenger side. Two advantages here, 1. It's not attached to the bumper and 2. It's harder for direct sunlight to hit it and throw off your temp reading but still maintain great air flow at this location. Just my 2cents.
"The Mouse"
Mods
northey87 is offline
post #6 of 12 (permalink) Old 04-06-2013, 11:52 AM Thread Starter
Quoted: 13 Post(s)
Thanks Northey! I wasn't thrilled with where I stuck the sensor, and will look at the location you suggest when I have the bumper off today to replace the horn.
This definitely isn't a hard install, nor is it particularly time consuming... once you've done it once before Most of my time (easily 45 minutes) was spent trying to figure out how to get my fish tape unstuck from under the hood. If you know what firewall hole to use this is probably a 2-3 hour install max.
Neil
neile is offline
post #7 of 12 (permalink) Old 04-06-2013, 12:06 PM
northey87's Avatar
I agree, my mirror only took about an hour to install including running the temp sensor.
"The Mouse"
Mods
post #8 of 12 (permalink) Old 04-07-2013, 07:54 AM
Toy Accent's Avatar
Quoted: 4 Post(s)
Toy Accent is on a distinguished road
Neile/Northey did you have to do anything with your windshield mount for the mirror to fit? I assume you both have the Gentex mirror. Thanks for the great info guys
2012 Accent SE,1.6L GDi I4, Auto, Ironman Silver, 35% Front,15% Rear Tint, OEM Mud Guards, WeatherTech Liners, OEM Cargo Tray, Red GDi Badge, Rear Bumper Appliqué, LED Turn Signal Mirrors, OEM Aluminum Sports Pedals, Webasto Deluxe Sunroof, Painted Calipers in Red, VG Shark Fin Antenna.
Toy Accent is offline
post #9 of 12 (permalink) Old 04-07-2013, 09:48 AM
2013 Accent GS 6MT & 1996 Miata 5MT
2013AccentGS6MT is an unknown quantity at this point
Doesn't the SE come with the auto-dimming Homelink mirror as standard equipment? Luckily my GS has it.
PrecisionLED 6000K interior + license plate bulbs
SE leather/chrome shift knob (came scratched!)
Debadged 'Accent' letters
OEM cargo tray and cargo net
Weathertech Digital Fit front mats
XenonSupply 4300k HID headlights
Injen SP1340BLK CAI + Hydroshield
2013AccentGS6MT is offline
post #10 of 12 (permalink) Old 04-07-2013, 10:39 AM
northey87's Avatar
No, as long as the mirror has a wedge base mounting style then you are fine and don't have to replace the metal mounting plate.
No, the homelink mirror is and extra on all Accent models.
"The Mouse"
Mods
