Help with subwoofer - Hyundai Forums : Hyundai Forum
post #1 of 11 (permalink) Old 11-17-2012, 10:14 AM Thread Starter
Drives Hyundai Accent 2013
Shoes20 is an unknown quantity at this point
Help with subwoofer
How did you guys get the power line through the fire wall a photo would be nice.
Shoes20 is offline
post #2 of 11 (permalink) Old 11-17-2012, 11:52 AM
IronmanRB201257's Avatar
2012 Accent GLS A/T Ironman 2012 Accent GS A/T Electrolyte Green
IronmanRB201257 is an unknown quantity at this point
The main harness that goes through the firewall behind the dash right above where the steering column goes through. Fish it through the rubber grommet then electrical tape a ways up the cabin side and engine side to keep the sealing properties. Yes, it was a PITA to do.
Do our cars have any form of theft deterent?
Other than saying "accent" on the back? What else do you need? Hahaha.
IronmanRB201257 is offline
post #3 of 11 (permalink) Old 11-18-2012, 08:12 AM Thread Starter
Where did you end up wiring the remote wire to?
Shoes20 is offline
post #4 of 11 (permalink) Old 11-18-2012, 07:49 PM
mmathison's Avatar
2011 Hyundai Accent Premium in Ocean Blue
Quoted: 2 Post(s)
mmathison
the remote wire can be run off a wire from the back of the head unit. I cannot remember now exactly what it does but from memory mine was a small solid yellow wire. This provided power from the ACC switch onwards which in turn told the amp to power up. If your not sure, best thing you can do is get a circuit test (small pen looking thing with a light on the end of it) plug the ground clip onto the cigarette light socket and poke around till you find a switched wire. I can take a look later this evening if you would like and post photos of which wire it is... This is presuming that the wiring is the same across countries
mmathison is offline
post #5 of 11 (permalink) Old 11-18-2012, 10:06 PM Thread Starter
Yes please could you and also can you explain your technique for taking off the paneling to get to the radio because I seem to do more damage each and every time I try to access it.
Shoes20 is offline
post #6 of 11 (permalink) Old 11-19-2012, 06:03 AM
mmathison's Avatar
Quoted: 2 Post(s)
mmathison
Thats really easy. If you get down low under the bottom of the fascia, there are 2 small holes there big enough for you to put a flat blade screwdriver in there. It takes a little force to get it off. I will take many photos for you
post #7 of 11 (permalink) Old 11-19-2012, 06:19 AM
rattlecanned's Avatar
'13 genesis coupe
rattlecanned is an unknown quantity at this point
you can also go the mcgyver way and run a length of speaker wire to a toggle switch to mimic a remote signal. put one side in the remote spot on the amp and the other with power.
rattlecanned is offline
post #8 of 11 (permalink) Old 11-19-2012, 07:37 AM Thread Starter
Thanks these pictures will be really helpful and end this long process for me.
Shoes20 is offline
post #9 of 11 (permalink) Old 11-19-2012, 09:56 PM
mmathison's Avatar
Quoted: 2 Post(s)
mmathison
Apologies for the delay as I have been held back at work. I will be taking the photos when I get home shortly and uploading them for you.
post #10 of 11 (permalink) Old 11-20-2012, 12:50 AM
mmathison's Avatar
Quoted: 2 Post(s)
mmathison
Here are the two images I promised
User Tag List
