Rattle in Passenger Side Dash Area - Hyundai Forums : Hyundai Forum
post #1 of 11 (permalink) Old 10-21-2012, 07:23 PM Thread Starter
Drives 2012 Accent GLS (5 door)
2012 Canadian Accent GLS is an unknown quantity at this point
Angry Rattle in Passenger Side Dash Area
I'm starting to be a little annoyed with a rattle in the passenger side dash area. I looked around to check if there was anything obvious, but I couldn't find anything...
I sometimes get that noise while driving over bumps, but oddly, I usually tend to get it when I accelerate and get the engine at a specific RPM (like some sort of resonance frequency issue?!?).
Does anyone know what could cause this?
2012 Canadian Accent GLS is offline
post #2 of 11 (permalink) Old 10-21-2012, 11:27 PM
2012 Sonata Limited
dgreene4001 is an unknown quantity at this point
Same in my 2012 Accent SE.
Thought it might be the glovebox but not sure. Haven't asked the dealer about it yet.
2012 Hyundai Sonata Limited
2012 Hyundai Accent SE
dgreene4001 is offline
post #3 of 11 (permalink) Old 10-22-2012, 01:11 AM
krazeaznboy's Avatar
2013 Genesis Coupe 2.0T Premium
Quoted: 8 Post(s)
krazeaznboy
I had this issue before but it was around the back seat. Turns out my car had a loose hose and they tightened it up for me. Have your dealer fix it
2013 Hyundai Genesis Coupe 2.0T Mods:
Work Emotion Kiwami 19x9.5.10.5
Hankook V12
SFR Canned Tune
PBM Pro Coilovers
OEM Brembo 4P Calipers
CP-E Catback Exhaust
Synapse BOV
VIP VIS Rear Diffuser
2012 Hyundai Accent GLS (R.I.P May 2014)
17X7 Enkei FLC-01 w/ Falken FK 452
2014 OEM Projector LED Headlights
Infinity 1200W Amp & Basslink Sub
7" UNAVI Touchscreen Headunit
6k HID Headlights & Fog Lights
Custom Black Leather Seats
EagleEyes LED Taillights
HSD Coilovers
Injen CAI
krazeaznboy is offline
post #4 of 11 (permalink) Old 10-22-2012, 11:12 AM
jwt873's Avatar
Quoted: 71 Post(s)
A rattle or squeak would drive me crazy.. I'd be banging my fist in that area trying to make it stop
On the passenger side dash area, I'd suspect the glove compartment.. Perhaps the hinges? I think the only thing you can do is pull everything apart and see what's loose or rubbing. If all else fails, as krazeaznboy suggests, take it to the dealer. It's covered by warranty.
jwt873 is offline
post #5 of 11 (permalink) Old 10-22-2012, 03:50 PM
Drives Accent SE
duncomatic is an unknown quantity at this point
It may be the passenger side seat belt buckle hitting the plastic by the seat.
duncomatic is offline
post #6 of 11 (permalink) Old 10-22-2012, 06:36 PM
Drives 2012 Accent
jamiem is an unknown quantity at this point
I had the same problem, it turned out to be a loose clip on a plastic guard/tray that you have to remove to access the cabin filter.
jamiem is offline
post #7 of 11 (permalink) Old 12-09-2012, 06:13 AM
ttc
Drives 2013 I30 active Crdi Previous 2012 Accent Crdi
ttc is an unknown quantity at this point
Any update I have one too, around the vent?
ttc is offline
post #8 of 11 (permalink) Old 12-16-2012, 09:15 PM
2012 Sonata Limited
Agreed. I removed one of the two glovebox "stoppers" and most of the rattle has gone away. One will hold the glovebox in place just fine, but I'm going to ask the dealer for a replacement the next time I'm there.
post #9 of 11 (permalink) Old 12-19-2012, 01:44 AM
Drives Accent 2013 SE 5 door; Previous cars: 2010 Accent; Prizm; Volvo 240, Ford LTD, Volare, Hornet
Badvibration is an unknown quantity at this point
Thanks for posts. Haven't had rattles yet. Worse cannot get 2013 Accent SE inspected at all since buying it in August 2012. The dealer I went to LA Hyundai at LAX, Inglewood, California refused me service and called the police to get me and the car off the lot. See youtube channel legaladvocate71. Corporate would not help either. I sued the dealer and HMA for "concerted failure to provide warranty service and public accommodation; no anti-discrimination policy" and "did not honor [warranty] rights." I had also included a previous 2010 Accent which had a vibration that the dealer refused to fix. The court Inglewood Small Claims California case 12S01314 agreed and awarded me $724 not because I actually got the mounts fixed but for the money I spent trying to diagnose the problem. Hopefully this case will help others. I would stay away from the Better Business Bureau Auto line because they are paid for by the automakers and therefore will not be neutral and unbiased. I still have to get the 2013 inspected because the idle seems not smooth to me; too much motor mount play; vibration in steering wheel with AC turned on, and of course bad gas mileage. Very rough road feel with the low profile tires at 70 psi so I reduced PSI to 35 and much better. Perfect though at 25 psi so I will replace the tires. Hyundai has very bad customer service.
Badvibration is offline
post #10 of 11 (permalink) Old 12-19-2012, 09:46 AM
2013 Hyundai Accent SE Automatic
Quoted: 20 Post(s)
2old2rocknroll is an unknown quantity at this point
The recommended tire pressure is 32 psi and max pressure is 44 psi. Why did you have it at 70 psi?
2old2rocknroll is offline
