Traction control, do you use it? - Hyundai Forums : Hyundai Forum
 2Likes
post #1 of 42 (permalink) Old 08-08-2012, 02:30 AM Thread Starter
Accent 2013
krosap is an unknown quantity at this point
Hello, I'm just wondering how often people use traction control button.
I tried having both on and off and I didn't feel any difference.
I guess I will have it on for sure when the road is slippery
but I'm curious if others have it on all the time.
krosap is offline
post #2 of 42 (permalink) Old 08-08-2012, 04:56 AM
Drives 2012 Accent RB Active 1.6 CRDI Manual Transmission 1988 Toyota 2WD Twincab diesel ute
Quoted: 37 Post(s)
RoadTrash is an unknown quantity at this point
Many years ago I was quite competitive in car rallies. I tried hard to get my Accent out of shape on a nasty, twisty, rough, badly cambered dirt road and although the EBS light on the dashboard was blinking like crazy the car held on extremely well. Very impressive indeed. I have it switched on all the time.
RoadTrash is offline
post #3 of 42 (permalink) Old 08-08-2012, 08:33 AM
NAMoosedog's Avatar
Drives 2012 Accent SE Mocha Bronze Automatic
Quoted: 8 Post(s)
I use it almost all of the time. Never know when it will be needed in an emergency. It works a lot better than earlier versions from the 1990s and is mostly "transparent".
I have found that it can interfere with spirited driving on dry, paved roads when trail braking. With FWD, the fast way around some corners, i.e. a high speed on ramp, is to drag the brakes, reducing traction to the rear end and allowing a drift. If TC is engaged the engine will bog.
Not done all the time, we're on public roads here.
NAMoosedog is offline
post #4 of 42 (permalink) Old 08-08-2012, 08:41 AM
2013 Hyundai Accent SE Automatic
Quoted: 20 Post(s)
2old2rocknroll is an unknown quantity at this point
I had trouble driving up my brothers steep gravel driveway pulling a trailer.
I turned the traction control switch off and got past the rough spot!
Mostly, I have the traction control on.
2old2rocknroll is offline
post #5 of 42 (permalink) Old 08-08-2012, 05:28 PM
2013 6M Accent 5DR
Quoted: 5 Post(s)
drakon is an unknown quantity at this point
i leave my Traction Control on with 1 exception, pulling into my driveway during rush hour.
i had my traction control on once when i did this, if i accelerate "too quickly" to take a hole in traffic off the main road into to my driveway and a wheel squeaks the car pulls all power away from me for a couple seconds and i run the risk of getting t-boned, so i shut it off before i make the turn and all is OK.
drakon is offline
post #6 of 42 (permalink) Old 08-08-2012, 05:36 PM
2013 Accent GS 6MT & 1996 Miata 5MT
2013AccentGS6MT is an unknown quantity at this point
Can someone explain how to turn off traction control? I can't find the answer anywhere. I thought I saw everything there is to see on the dashboard.
2013AccentGS6MT is offline
post #7 of 42 (permalink) Old 08-08-2012, 05:42 PM
2013 6M Accent 5DR
Quoted: 5 Post(s)
i don't know if it is the same on the US model as it is on the canadian model, but to the left of the steering wheel on the dash you should have a pane of boxes allowing up to 6 buttons to be there (depending on features that came with your car) one of these will be a picture of a car with squiggly lines coming out behind it. push that button, a light will light up on your HUD in between the engine temp & gas level with the same picture and the word "OFF" under it. your traction control is now off.
i noticed the car only allows me to enable / disable traction control if the car is fully stopped so do this when the car isn't moving otherwise it likely wont do anything at all.
push again to enable traction control once again.
drakon is offline
post #8 of 42 (permalink) Old 08-08-2012, 05:43 PM
krazeaznboy's Avatar
2013 Genesis Coupe 2.0T Premium
Quoted: 8 Post(s)
krazeaznboy
It will be the button right of your eco button.
2013 Hyundai Genesis Coupe 2.0T Mods:
Work Emotion Kiwami 19x9.5.10.5
Hankook V12
SFR Canned Tune
PBM Pro Coilovers
OEM Brembo 4P Calipers
CP-E Catback Exhaust
Synapse BOV
VIP VIS Rear Diffuser
2012 Hyundai Accent GLS (R.I.P May 2014)
17X7 Enkei FLC-01 w/ Falken FK 452
2014 OEM Projector LED Headlights
Infinity 1200W Amp & Basslink Sub
7" UNAVI Touchscreen Headunit
6k HID Headlights & Fog Lights
Custom Black Leather Seats
EagleEyes LED Taillights
HSD Coilovers
Injen CAI
krazeaznboy is offline
post #9 of 42 (permalink) Old 08-08-2012, 05:43 PM
Oh okay, that's the Electronic Stability Control. I guess it's the same thing as Traction Control. I turn it off when I start the car
The manual says to hold the button for half a second when starting the car to turn it off. I guess it'll work as long as you're stopped. Don't see a reason to turn it off in motion.
And manual-equipped Accents don't have the eco button.
sleepingaccent13 likes this.
post #10 of 42 (permalink) Old 08-08-2012, 05:44 PM
Quoted: 8 Post(s)
krazeaznboy
Strange... I can enable/disable traction control when my car is in motion.
Hankook V12
SFR Canned Tune
PBM Pro Coilovers
Synapse BOV
HSD Coilovers
Injen CAI
