V6 - 3.3l - Spark Plugs Removal! - Page 2 - Hyundai Forums : Hyundai Forum
post #11 of 35 (permalink) Old 10-15-2007, 11:09 PM
..MiamiLX..
The Voice of reason. Really!. I was just
kidding about Points...
I would like to know more though about his
WARRANTY CLAIM REFUSAL ISSUES?
..MiamiLX.. is offline
post #12 of 35 (permalink) Old 10-20-2007, 11:33 PM
solomix
I was on a quest to find out the same question. The gap on my 2003 sonata is.044 when I pulled the first three they was at .055. So at 51,000 miles on the car and being the second owner of it... It did change alot robbing me of alot of things. I also want to know about the correct way to get to the back 3 plugs. thanks
solomix is offline
post #13 of 35 (permalink) Old 10-21-2007, 07:39 PM
MikeNH's Avatar
MikeNH
I doubt you'll find anything but I pulled off a 3.3 manifold last summer so I'm a bit rusty on it-
Its pretty straight forward, starting off its a matter of disconnecting any hoses or connections to the manifold, as well as temporarily re-routing some hoses that go across the manifold. Most of the bolts are in plain sight, however there are 2 along the back side of the manifold that I seem top remember being a tad tricky to get to. Once everything is disconnected and the bolts removed I used a long extension to prop up the manifold as I didn't want to bother with disconnecting the fuel lines, this should allow you to access the rear plugs. For safety's sake, cover the now open lower intake with a rag or something to avoid dropping anything in there. But with the manifold propped up you should be able to access the back plugs.
MikeNH is offline
post #14 of 35 (permalink) Old 10-21-2007, 09:02 PM
madderhatter
Guest
Posts: n/a
Quoted: Post(s)
Originally posted by MikeNH@Oct 21 2007, 07:39 PM
[b]I doubt you'll find anything but I pulled off a 3.3 manifold last summer so I'm a bit rusty on it-
[snapback]115000[/snapback]
Ohhh for the days of the good 'ol Edelbrock manifolds, or even the VW Bug with two bolts on each side and they're off.
post #15 of 35 (permalink) Old 10-22-2007, 05:48 PM Thread Starter
theiceage05's Avatar
07 V6 3.3 Sonata GLS; 15 L4 1.6L Accent SE; and the Vantage 2005 Accent GS!
Quoted: 6 Post(s)
theiceage05 is an unknown quantity at this point
Hello "MikeNH"
TheIceAge05
TheIceAge05
theiceage05 is offline
post #16 of 35 (permalink) Old 07-17-2008, 07:30 PM Thread Starter
Quoted: 6 Post(s)
Hello there, fellows HF members
I now have pictures for this..........
[attachmentid=8802]
[attachmentid=8803]
[attachmentid=8804]
[attachmentid=8805]
[attachmentid=8806]
[attachmentid=8807]
[attachmentid=8808]
[attachmentid=8809]
[attachmentid=8810]
[attachmentid=8811]
[attachmentid=8812]
[attachmentid=8813]
[attachmentid=8814]
TheIceAge05
post #17 of 35 (permalink) Old 07-18-2008, 07:21 AM
morrjr's Avatar
morrjr
I once owned a car with a V6 that you had to remove the intake manifold to get to the rear plugs. Cost of a tuneup? Around $250 because of the requirement to remove the manifold. And the plugs had to be changed every 60,000 miles to keep the powertrain warranty in effect.
After reading this topic I'm glad my new 09 Sonata has an I4.
morrjr is offline
post #18 of 35 (permalink) Old 07-18-2008, 07:54 AM
ddix1026's Avatar
ddix1026
well, to be fair, the V6's have Iridium plugs that arent scheduled to be changed until 95,000 miles (unless something goes wrong with them of course)..
but not looking forward to having to have them replaced, not by any means... even in my old V6 Beretta, the plugs were "sort of" a PITA, but not nearly like this...
ddix1026 is offline
post #19 of 35 (permalink) Old 07-18-2008, 09:17 AM
Drives 2015 Sonata Sport 2.0T Ultimate 47,000 kms
Quoted: 2 Post(s)
rallyman
So what was the result of this? Were there any problems with your spark plugs?
rallyman is offline
post #20 of 35 (permalink) Old 07-18-2008, 09:57 AM
wymi's Avatar
Quoted: 18 Post(s)
Originally posted by rallyman@Jul 18 2008, 08:17 AM
[b]So what was the result of this?* Were there any problems with your spark plugs?
[snapback]176991[/snapback]
Yes, I'd like to know the results of changing the plugs, did the idle improve?
wymi is offline
