Recommended Coolant - Hyundai Forums : Hyundai Forum
post #1 of 11 (permalink) Old 06-17-2007, 10:30 AM Thread Starter
Aerostar_ca's Avatar
2006 Sonata I4 ______ 2014 Sonata GLS
Quoted: 9 Post(s)
Aerostar_ca
I would like to change the coolant in my 2006 I4. What is the recommended coolant? Do we need Hyundai coolant or could I use Prestone?
Aerostar_ca is offline
post #2 of 11 (permalink) Old 06-17-2007, 11:00 AM
Brazzel's Avatar
Brazzel
Originally posted by Aerostar_ca@Jun 17 2007, 08:30 AM
[b]I would like to change the coolant in my 2006 I4.* What is the recommended coolant?* Do we need Hyundai coolant or could I use Prestone?
[snapback]93142[/snapback]
PEAK® Global LifeTime™ Select Another ProductPEAK AntifreezePEAK Ready UsePEAK Global LifeTimePEAK Global LifeTime 50/50PEAK LongLifePEAK LongLife 50/50PEAK Ext. Life CF-EXLAll WeatherSierraPortable JumpstarterDeicer CleanerWindshield WashRV & Marine AntifreezeUltra MeltAdvance AntifreezeFull ForceFleet ChargeFleet Charge 50/50Final Charge Ext. LifePEAK All Season WipersPEAK Max-Vision WipersPEAK Winter WipersMr Clean Windshield WashMr Clean Wiper BladesMr Clean Appearance ChemicalsMr Clean AutodryFebreze
One Gallon (US)
Four Litre and Two Litre (Canada)
PEAK Global® LifeTime™ Antifreeze & Coolant - Antigel/Réfrigerant features a patented, advanced organic acid technology that provides guaranteed LifeTime protection - for as long as you own your vehicle!* Its patented inhibitors will provide maximum protection against damaging rust and corrosion in all automobiles and light trucks worldwide, regardless of make, model, year or original antifreeze color.
Provides guaranteed LifeTime protection - for as long as you own your vehicle - when a complete cooling system flush and fill is performed and specified maintenance followed
Formulated for use in all American, Asian and European automobiles
Features a patented non 2-EH formula that is phosphate-free and silicate-free
Can be used to top-off any color of automotive antifreeze including green, yellow, orange, fuschia, blue and red
Amber color will not change the current antifreeze color when used for topping off
Meets ASTM D-3306 and ASTM D-4340
Brazzel is offline
post #3 of 11 (permalink) Old 06-17-2007, 06:14 PM
ants
Coolant is (in my opinion) a disposable fluid and should be changed regularly - the two year interval stated in the service notes is about right in my opinion.
It's cheap, readily available, and a simple job to change.
But to answer your question - any known-brand of coolant will be perfectly fine.
(Out of interest, I just changed my coolant yesterday. I had a lot of aluminium in mine which I strongly suspect to be left over from inadequate cleaning of the machined block prior to engine assembly at the factory.)
Cheers,
Anthony
ants is offline
post #4 of 11 (permalink) Old 06-17-2007, 07:22 PM
motd's Avatar
motd
Was changing coolant as easy as opening the valve at the bottom of the rad, or is there an air vent release valve on the block, like some cars have? (To prevent an air-lock.)
motd is offline
post #5 of 11 (permalink) Old 06-17-2007, 07:40 PM Thread Starter
Quoted: 9 Post(s)
Aerostar_ca
I plan to disconnect the lower Rad hose to drain the rad and part of the block.
post #6 of 11 (permalink) Old 06-17-2007, 07:51 PM
ants
Originally posted by motd@Jun 18 2007, 08:22 AM
[b]Was changing coolant as easy as opening the valve at the bottom of the rad, or is there an air vent release valve on the block, like some cars have? (To prevent an air-lock.)
[snapback]93225[/snapback]
There's no air vent on the engine (which makes life a little simpler).
Open the tap (low on the radiator side-tank, right hand side of the vehicle). Remove the radiator cap, and let the coolant drain. I then removed the top hose a the radiator, and the bottom hose at the water pump. The bottom hose is virtually inaccessible (easily) at the radiator end. I drained the system, then flushed with tap water. I pushed the bottom hose down so it would drain as much as possible. I should note too - I had the vehicle positioned "nose down" in order to assist with draining as much as reasonably possible from the block. Then I reconnected everything and refilled the system, moved it onto a flat surface, then continued to top-up. I pumped the top hose a few times to help dislodge any air. When the system appeared full, I re-installed the radiator cap, made sure the overflow bottle was topped off, and went for a short drive. Checked it again and it was fine. I'll check it again tonight once the wife gets home from work to make sure the system is full.
Cheers,
Anthony
ants is offline
post #7 of 11 (permalink) Old 06-17-2007, 07:58 PM
Brazzel's Avatar
Brazzel
If you do just a drain......you will only loose about a 3rd of the fluid. You need to take it and have it flushed. Much more of a pay off.
Brazzel is offline
post #8 of 11 (permalink) Old 06-17-2007, 09:11 PM
MikeNH's Avatar
MikeNH
if you pull a hose off the block like ants did you'll get most of the coolant out, there will always be come that will stay in with this method, but I personally don't believe (after using the coolant flush machine when I was at the dealer) that it is much better than a complete drain and fill.
MikeNH is offline
post #9 of 11 (permalink) Old 06-17-2007, 09:17 PM
Brazzel's Avatar
Brazzel
Originally posted by MikeNH@Jun 17 2007, 07:11 PM
[b]if you pull a hose off the block like ants did you'll get most of the coolant out, there will always be come that will stay in with this method, but I personally don't believe (after using the coolant flush machine when I was at the dealer) that it is much better than a complete drain and fill.
[snapback]93243[/snapback]
You may be right.
Brazzel is offline
post #10 of 11 (permalink) Old 06-17-2007, 09:51 PM
motd's Avatar
motd
Cool. How fussy are they with USED coolant in your parts of the world. I think we now have recycle depots. Back 20 years ago, we used to walk across the road, and just dump used oil and rad fluid out onto some tall grass. Does wonders for your drinking water!!! Most folks used water wells back.
motd is offline
