Mass Air Flow check engine code - Hyundai Forums : Hyundai Forum
 2Likes
post #1 of 11 (permalink) Old 06-07-2017, 09:03 AM Thread Starter
2010 Hyundai Sonata GLS 2.4L
FstrungUCoutT is an unknown quantity at this point
First post on here and would appreciate any help I can get.
I'm getting a checking engine light and have been told that the code refers to an issue possibly with the mass air flow sensor. The car is a 2010 Sonata 2.4L engine and it has just over 102k miles on it so its not out of the realm of possibilities that the sensor needs some cleaning. Its never been cleaned to my knowledge unless the dealership did it at some point which I doubt. So two questions:
1) On the forum I've seen some posts that say a 2010 Sonata 2.4L has a MAF sensor and some that say it has a MAPS. Which is it?
2) If the car has a MAF sensor, where can I locate it?
Thanks in advance.
FstrungUCoutT is offline
post #2 of 11 (permalink) Old 06-07-2017, 09:33 AM
drives first 2016 elantra value edition, windy sea blue. 2016 elantra value edition, galactic gray
Quoted: 302 Post(s)
hochiinn is an unknown quantity at this point
first off, if you are getting a scan from a place like autozone, oreilly's, etc, NEVER have them interpolate the code. get the actual code, and look it up yourself.
Tiger-Heli likes this.
hochiinn is offline
post #3 of 11 (permalink) Old 06-07-2017, 09:38 AM
Tiger-Heli's Avatar
Drives 2016 Hyundai Accent
Quoted: 147 Post(s)
Tiger-Heli is on a distinguished road
https://www.rockauto.com/en/catalog/...)+sensor,11207
Rock Auto lists both a MAF and a MAP for it ...
Tiger-Heli is online now
post #4 of 11 (permalink) Old 06-07-2017, 09:47 AM Thread Starter
Thanks guys. I got it scanned by a friend of the family who is a mechanic and has a shop. We looked up the code together so I know I'm not getting bad info. I think the code was P0106.
I'm fairly certain at this point that the car has a MAPS. I think I've figured out the location (definitely not as easy or accessible as a MAF).
Wondering if anyone has had any luck using a MAF sensor cleaner of a MAPS. Thanks.
post #5 of 11 (permalink) Old 06-07-2017, 06:10 PM
AUTOSPARK's Avatar
Hyundai Getz 1.5 CRD (D4FA)
Quoted: 1069 Post(s)
Have you had the battery disconnected or a flat battery recently by any chance?
AUTOSPARK is offline
post #6 of 11 (permalink) Old 06-07-2017, 06:34 PM
Drives 2001 Elantra GLS 2.0L Auto
Quoted: 328 Post(s)
I looked up P0106
It says it is a MAPS fault.
MAF sensors can be found on the in take tube that comes from the air filter and goes to the engine's in take plenum
avisitor is offline
post #7 of 11 (permalink) Old 06-09-2017, 11:00 PM
Drives a 2009 Sonata Limited Nickname: Snowflake
2424Goldie is an unknown quantity at this point
Since your car is exactly like mine engine wise (I have an 09 Sonata with the 2.4) I can affirm that your car has a MAPS just like the code suggests is at fault. However, if your P0106 code only appeared after disconnecting the battery or having the battery die for one reason or another I would disregard it. The Check Engine light on my car lights up with that code if one of those two things happen. I did remove the sensor to inspect it and it's not hard to do. It is located after the throttle body and before the intake manifold. There is only one bolt holding it in that you can remove with a small ratchet before only pulling the sensor out after unplugging it. There was some oil or fuel of some sort on my sensor that I wiped off gently with some paper towels before putting it back in. The code comes back every time power is cut but there are no noticeable symptoms so I just delete it and it never comes back until I need to unplug the battery again.
2424Goldie is offline
post #8 of 11 (permalink) Old 06-09-2017, 11:15 PM
Quoted: 1424 Post(s)
Map not likely the fault....
Rash of them with YF Sonata and engine changes, had a go around with 1 that been passed around shop with upward of 8 visits for same code..
Time for visit to dealer,,,
Plug in GDS, I prefer the PC based, or laptop,,, I dont like tablet for older stuff
ID vehicle
Engine
Current Data
Select :
MAP volt
TPS volt I think it is
Graph......
stab throttle a number of times,, both trace should in effect "mirror" each other.
Yes
Select Software Management
Engine Adaptive
Follow prompts to reset engine values
ECU UPGRADE
Next
Select "Engine"
Next
Reads ROM.. offers whatever update (if anything available)
Update offered
UPGRADE
Follow prompts to do update
No update available,, we be done with GDS
sbr711 is online now
post #9 of 11 (permalink) Old 06-10-2017, 03:55 AM
AUTOSPARK's Avatar
Originally Posted by sbr711 View Post
Plug in GDS.....
So, what he's saying in Hyundaiese is you need the PCM adaptive values reset, which on the older models you could do yourself by just disconnecting the battery for a few minutes. I've not done much work on newer models so I'm not sure if that still works. Just be aware that disconnecting the battery usually causes P0106 on these engines, as 2424Goldie pointed out.
post #10 of 11 (permalink) Old 06-10-2017, 12:22 PM
Proper word is "Korr-English"... They make a Korr-English dictionary for translating Korean poor english to good english
