321mm Big Brake Kit!! - Hyundai Forums : Hyundai Forum
#1 Old 03-25-2012, 04:47 PM
riceR's Avatar
09 Sonata 3.3, 06 Saab 9-3 Aero
riceR is an unknown quantity at this point
"OEM" BBK!!
So I heard 04-05 XG 350 calipers and caliper mount fit the NF. I took the plunge a while back, buying junkyard XG calipers w/mount for $60. Cleaned them up and rebuilt them with new pistons. I also painted them silver. I bought some EBC greenstuff - they don't sell redstuff for the XG - and 07-08 Tib SE rotors (303mm). After thinking about it for a while - and also seeing that sharkracing had a 12.6" bbk for the YF - I decided to also buy Veracruz rotors (321mm).
Test fitted the Tib rotors... too small - would've been nice since they're cross drilled - oh well. Anyways, Veracruz rotors fit just perfect! Everything bolts up. The only thing I had issues with - shout out to sbr711 for helping - was with the brake pedal dropping to the floor. Turns out I mounted the caliper wrong - the bleeder was supposed to be on top. I installed them on the bottom. After re-installing them, brake pedal is nice and firm and they bite really good. So in the end - if you don't count the extra Tib rotors - I paid roughly $260 for the parts. Also ~$150 for misc items like new caliper pistons/rebuild kit/guide pins/paint.
So here's the rundown on what you need...
04-05 XG calipers and mount
04-05 XG pads
Veracruz rotors
17"+ wheels
pics...
XG junkyard calipers
cleaned
rebuilt
mounted
doesn't bite all of the rotor surface ~ 1/4"?
about even on top of rotor/pad
bottom clearance on dust shield (it's pretty much flush, but doesn't touch the rotor)
top/side dust shield clearance
behind the wheel
also wanted to point out that the brake line to the banjo mount is a bit off since I had to mount the right caliper on the left side of the vehicle and the left caliper on the right side of the vehicle in order for the bleed screws to be at the top.
Overall, I like them. It has really good bite compared to the stock setup. If I installed them correctly the first time around it would have only taken about 1 hour to install. The only thing that I don't like is that I'll have to get 17" or bigger wheels - I have to sell my 16" snow wheels/tires now The dual piston caliper is also quite heavier than the OEM single piston. Also, you could barely tell they are behind the OEM 17s. I'll take better pics once I put on the 19" gen coupe wheels.
riceR is offline
#2 Old 03-25-2012, 06:05 PM
Supernova88642's Avatar
2007 NF Sonata I4
Supernova88642
I say sticky this. Awsome job man.
Supernova88642 is offline
#3 Old 03-25-2012, 07:22 PM
NubR1
very nice, makes me just a bit jealous hah so did you leave the rears all stock too?
NubR1 is offline
#4 Old 03-25-2012, 07:44 PM
riceR's Avatar
No, rears are stock.
riceR is offline
#5 Old 03-25-2012, 09:41 PM
NUMBER NYC's Avatar
WHITE WING NF
NUMBER NYC is an unknown quantity at this point
Send a message via AIM to NUMBER NYC
Yeah I agree. Stick this on the board. Great job playboy.
NUMBER NYC is offline
#6 Old 03-26-2012, 08:57 PM
TeamRF's Avatar
09 Sonata 2.4l
TeamRF
Thumbs UP looks great
Retrofitted FX-R 2.0 Projector
18" Gen Coupe Wheels
Added oem Spoiler
upgraded power supply
Freaking LOUD
TeamRF is offline
#7 Old 03-26-2012, 09:02 PM
v33sonata's Avatar
Drives: 06 Hyundai Sonata V6, 13 Kia Rio, 85 AE86 20v BT, 02 GSF1200, 04 SV650, 95 GMC Sierra 4x4
Quoted: 2 Post(s)
Nice job! Linked posted in Performance Parts For The Sonata
v33sonata is offline
#8 Old 03-26-2012, 10:39 PM
hmr1979's Avatar
2006 Sonata - 3.3 L 2006 Azera Ultimate
hmr1979 is an unknown quantity at this point
Great job man, now I assume you can always get Veracruz aftermarket cross drilled and slotted if you really wanted the look to add to it.
hmr1979 is offline
#9 Old 03-26-2012, 10:57 PM
hmr1979's Avatar
I am wondering if this will work for the Azera. I still have stock brakes on that car and it's pretty much a joke trying to stop that boat with the tiny stock rotors.
hmr1979 is offline
#10 Old 03-26-2012, 11:44 PM
riceR's Avatar
Yeah, I saw a few, but I initially bought these to test fit, but turns out it was the Tib rotors that don't fit.
It should work. The TG and NF share a lot of similar parts. But if you want something bigger, you can see if the V8 Genesis/Equus 4pot calipers will bolt up... I'm tempted to try this
FYI: The 11+ Optima SX has 12.6" rotors as well. They probably fit the NF, but I can't find any aftermarket ones... yet
riceR is offline
User Tag List
