How To Replace Oil Control Valve on 2.4L Sonata - with pics - Page 7 - Hyundai Forums : Hyundai Forum
 13Likes
post #61 of 66 (permalink) Old 03-29-2016, 06:58 PM
Quoted: 1331 Post(s)
I want to say -2G500 is current part,, it is shorter than the old part, and slight smaller body than original removed from cylinder head..
Hyundai dont have sense to pull old parts and toss in scrap..
Karaoke Kop likes this.
sbr711 is offline
post #62 of 66 (permalink) Old 04-24-2016, 02:29 PM Thread Starter
Former Hyundai owner. Good riddance.
stephen9666 is an unknown quantity at this point
In case some of you didn't know, here's a youtube video on this job.
https://www.youtube.com/watch?v=m3WsFb00Fik
stephen9666 is offline
post #63 of 66 (permalink) Old 01-11-2017, 01:37 PM
janakisri is an unknown quantity at this point
I have a Sonata 2.4 L 2007 with 84 k miles. Been struggling with P0011 for two months on and off , now very consistent , code comes within 20 miles of driving , every day
The pictures and YouTube were very helpful , thanks!
I successfully changed the OCV ( new design part , about $43 total from Ebay) two days ago ,and everything was good for a whole day , but this morning , after only 5 miles of driving , when starting out from a light , check engine ( P0011) is back again.
Any thoughts of what I can do?
I need to change oil and the filter which are about 4 months old now, topped off recently
janakisri is offline
post #64 of 66 (permalink) Old 03-08-2017, 03:20 PM
bobsingh's Avatar
Quoted: 61 Post(s)
bobsingh is an unknown quantity at this point
i have 2015 LF sonata with 70000 kms, engine light came on after getting oil change code says : P0010.
does LF has OCV too ?
and will this cover in my 5 year/100000kms power train warranty ?
2015 White Sonata GL, Canada
bobsingh is offline
post #65 of 66 (permalink) Old 03-12-2017, 03:11 AM
07 Santa fe ltd 07 Dodge 1500 std. cab 8 ft bed.
Quoted: 41 Post(s)
Mycrossover is an unknown quantity at this point
Originally Posted by mashyundai View Post
stephen9666,
Is your original OCV shows bad resistance reading. I am having same error code and I did check my OCV, its shows good resistance reading and functioning when I applied power to it. The CEL drives me nut.
It is a solenoid. Voltage is applied to the coil and it opens the valve.The problem is generally not a burned out or shorted coil ( bad resistance reading) but a plunger that is stuck from oil gunk. The bulletin actually suggested trying to clean it first. Spray with brake cleaner or carb cleaner. Avoid spraying the electrical contact area. Apply 12 volts and see if plunger moves freely.
Sent from my SM-G900V using Tapatalk
Mycrossover is offline
post #66 of 66 (permalink) Old 03-12-2017, 10:57 AM
Warranty....
Dont know to what speed Canada is up to, but was recall in USA when chassis first come out,, we have SST to seat rubber plug to depth in nose of CVVT unit....
Down road here the rubber plug is popping out, we reset, and they pop out again.. when the plug pop out, it fills cover with oil, and oil can squirt out the vent hole of plug at cover..
Hyundai has a new part number on the rubber plug,, it is also black in color.. need to remover CVVT cover that has the electric plug, clean the inside and brush box of motor oil,, clean front of CVVT unit, start rubber plug in hole, assemble cover to the front of engine,, use SST and seat plug to correct depth..
When done, use GDS to clear codes,, go to SOFTWARE MANAGEMENT,, reset engine adaptive,, and do the E-CVVT thing,, couple spaces down the menu in Software Management screen..
Start engine,, it'll take a little longer crank time to fire up, that normal after reset.. fine from there on out
sbr711 is offline
