Windshield washer doesn't work - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 10-10-2011, 05:59 PM Thread Starter
Hyundai Sonata 2006 GL 2.4
tom_zhouxy
Angry Windshield washer doesn't work
Hello everyone, all in sudden I found that the windshield washer of my Hyundai Sonata 2006 GL doesn't work. When I pulled back the control bar, the wippers were swapping but no water came out. I was pretty sure that the water tank was full, and I didn't hear any motor working sound when I did that. Is there any way I can replace it by myself? Or how much does it cost if I go to a Hyundai dealer? This is the very first time that my car had an issue. In the past years I never went to a repair shop except for oild change and other maintenance. Thanks.
tom_zhouxy is offline
post #2 of 12 (permalink) Old 10-10-2011, 06:50 PM
Quoted: 1287 Post(s)
Visit Hyundai dealer parts dept (Kia too) for the washer pump assembly..
Swap the pump yourself..flip lower panel out of way and have at it.
sbr711 is offline
post #3 of 12 (permalink) Old 10-10-2011, 06:53 PM
Drives: impala conv. 1966 maxima SE 1997 altima GLE 1999 Elantra Touring 2010
mytouring
Hi,
the pump it self shouldn't be more then $25, and you should change it your self, but first check the fuses or the water tubes for leak.
hope it helps.
mytouring is offline
post #4 of 12 (permalink) Old 10-10-2011, 07:31 PM Thread Starter
tom_zhouxy
Hi friend, what do you mean by "lower panel"? BTW do I have to get to under the car?? Thanks!
post #5 of 12 (permalink) Old 10-10-2011, 07:33 PM Thread Starter
tom_zhouxy
Originally Posted by mytouring View Post
Hi,
hope it helps.
Hello, I checked out user manual and think wippers and washer are sharing the same fuse, somehow the wippers do work. I also looked into water tube and there is a lot of water in there. That's why I though the pump is broken. Thanks!
post #6 of 12 (permalink) Old 10-10-2011, 07:40 PM
mytouring
if there's liquid ..., maybe the tube has broken in a connector, make someone start the pump and check if it leaks somewhere.
sometimes it's the hood connector that get blocked with deposits.
post #7 of 12 (permalink) Old 11-23-2011, 10:00 PM
Drives 2007 Santa Fe
karl-with-a-k is an unknown quantity at this point
Repaired my windshield washer today. Take an analytical approach and don't waste money replacing parts until you determine they are faulty. My manual has a step by step electrical diagnostic procedure which is where I think problem usually is. They have you checking for power all the way back to the source. In my case, everything checked just fine but still no washer spray. Finally, I took the pump out of the reservoir and found that it was clogged with blue goo. I used compressed air to reverse flush the pump and then it worked perfectly. Keep an open to anything. Good luck to you.
karl-with-a-k is offline
post #8 of 12 (permalink) Old 11-23-2011, 10:30 PM Thread Starter
tom_zhouxy
Hey Karl, thanks for your reply. It has been raining for quite a while in Seattle so I didn't get a chance looking into it yet. Can you tell me where those steps are in the manual? I didn't see anything about it.
post #9 of 12 (permalink) Old 02-11-2012, 07:56 PM
Sonata
Tim06sonata is an unknown quantity at this point
Wind shield washer
Thanks everyone for all the input....since I could hear the pump running I disconnected the hose at the hood and blew in, it cleared the blockage and now it works. note..open the resivor cap to relieve pressure when you blow in.
Tim06sonata is offline
post #10 of 12 (permalink) Old 02-11-2012, 08:16 PM
2006 Sonata 2.4L GLS
Bimbo is an unknown quantity at this point
The windshield washer pump is the NUMBER ONE part that has been going bad on early NF cars..... Mine is the same '06 2.4 car, but KNOCK ON WOOD it hasn't gone bad YET. But it should be under warranty, if any left.
Bimbo is offline
