Fuelpump Removal Help - Hyundai Forums : Hyundai Forum
post #1 of 23 (permalink) Old 08-30-2011, 09:48 PM Thread Starter
fondew1
Question
My fuel pump is dyin and i need to replace it,but cant see how to remove it from tank. have the access panel off in trunk and am able to disconnect everything but cant seem to figure out how to pull it....Any help out there???
fondew1 is offline
post #2 of 23 (permalink) Old 08-30-2011, 09:59 PM
clc130's Avatar
07 Sonata GLS
clc130
This is from hmaservice, it references a special service tool for removing the fuel pump. I'll see if I can find info on it.
[attachment=29296:fuel_pump.png]
clc130 is offline
post #3 of 23 (permalink) Old 08-30-2011, 10:10 PM
clc130's Avatar
07 Sonata GLS
clc130
These are the associated special service tools:
[attachment=29297:sst.png]
clc130 is offline
post #4 of 23 (permalink) Old 08-31-2011, 12:22 AM
Quoted: 1183 Post(s)
QUOTE (CLC @ Aug 30 2011, 09:10 PM)
Fuel pressure test parts wont remove the lock ring for the fuel pump module..
There is a service tool that engages the ears of the ring to release it..
When you get module out, install new module in it place,, and there is new tube that goes along with it,, seperate part..
Look at connector on old module, see if lug burnt up/overheated -- see pics
sbr711 is offline
post #5 of 23 (permalink) Old 09-01-2011, 10:23 AM
Negative 1's Avatar
From my 2008 Sonata's manual:
"Running out of gasoline may cause the engine to misfire and result in damage to the catalytic converter."
Yet they still instruct:
"Start the engine and wait until fuel in fuel line is exhausted. After the engine stalls..."
I know, the argument will be that doing this once won't hurt anything. Uh-huh. I guess it's another case of "What you don't know won't hurt you".
Negative 1 is offline
post #6 of 23 (permalink) Old 09-01-2011, 01:36 PM
Here is the tool needed to remove the lock ring ---
sbr711 is offline
post #7 of 23 (permalink) Old 09-06-2011, 10:48 AM
CF7
2006 Sonata NF i4 @2014/02 odo -53k km
CF7
QUOTE (fondew1 @ Aug 30 2011, 08:48 PM)
Was there any code to indicate it was a pump failure? I am curious to learn how did you test it for the pump problem?
CF7 is offline
post #8 of 23 (permalink) Old 09-06-2011, 09:00 PM
QUOTE (CF7 @ Sep 6 2011, 09:48 AM)
First hint of the module going away is long crank time or constant crank with no fire.. have assistant wiggle connector around or hold it to one side to make better pin connect, and it may fire up and run, then die as connector wiggled.
Pump itself not been failure item, it is the poor connection that deliver needed power to the pump... see the pics above of the darkened terminals and burnt plastic.
sbr711 is offline
post #9 of 23 (permalink) Old 09-06-2011, 09:22 PM
ActionMan's Avatar
QUOTE (sbr711 @ Sep 6 2011, 06:00 PM)
Is this a problem with the later NFs or just the earlier ones?
Vehicles Owned:
  • 2009 Hyundai Sonata GLS
  • 2001 Saturn L200
  • 1986 Saab 900 Turbo
  • 1979 Datsun 210
  • 1973 Mercury Montego
ActionMan is offline
post #10 of 23 (permalink) Old 09-09-2011, 07:45 PM
CF7
CF7
thx sb711
Can I just clean the connectors? without changing the pump?
CF7 is offline
