3.3l V6 Valve Adjustment........ - Hyundai Forums : Hyundai Forum
post #1 of 11 (permalink) Old 03-11-2011, 01:57 PM Thread Starter
theiceage05's Avatar
07 V6 3.3 Sonata GLS; 15 L4 1.6L Accent SE; and the Vantage 2005 Accent GS!
Quoted: 6 Post(s)
theiceage05 is an unknown quantity at this point
Thumbs up
Hello there, fellows HF members;
I just read in the Haynes Repair Manual (#43055) page 2B-11 that the 3.3L V6 engine use bucket-style lifters that must be replaced with ones of the proper thickness in order to adjust valve clearances.
Has anybody here ever heard of this? Have you ever had it done?
I'm just looking for info as to cost and reasons why the service technician gave you to get to this result.
Thank You
TheIceAge05
theiceage05 is offline
post #2 of 11 (permalink) Old 03-12-2011, 07:25 PM
2006 Sonata V6 GLS - 165k
Quoted: 3 Post(s)
Byron007 is an unknown quantity at this point
It does say to adjust the valves in the owners manual, but ehh the cost to do it....
<<<<Update your vehicle here so others know what you drive when you post. Makes it easier to help you if you have a problem.
Byron007 is offline
post #3 of 11 (permalink) Old 03-12-2011, 07:48 PM
Quoted: 1282 Post(s)
Unless it is pecking....... dont even think about it..
Cost,,, no number value, but to start the measure process, remove upper plenum, both cam cover, and obtain clearance values...
How do want to play the game?? you want to play the range of adjustment, or you want them all set evenly to 1 value for intake and 1 value for exhaust .....
If adjustments need to be made,,,, remove oil and lower oil pan, cut some of the engine mounts loose to tip the engine, dump the cooling system, remove drive belt/crank pulley/water pump, then go after the front cover. Now you can see the chains and tensioners... Hmmm, maybe replace chains upon re-assembly, maybe tensioners too, how about the guides ??
Mark everything real well, remove chains, then remove cams.... now remove the bucket, and micrometer inspect the thickness, then firgure the +/- amount into your known value, then replace with correct thickness bucket... they'll be special order too, so figure out what you need to have.. dont forget all the other gaskets, oil filter, coolant, RTV, chains, guides, tensioners..
I set my TOYOTA head up at 65,000 mile, new valve seals and valve adjust to 1 value at intake and exhaust... 336,600+ mile currently, still quiet.... needs valve seals though.
Cost, figure maybe $2200 as a wild guess to start...
sbr711 is offline
post #4 of 11 (permalink) Old 03-12-2011, 10:20 PM
Quoted: 3 Post(s)
Holy smokes! Thanks for the detailed right up. I will not be getting a valve adjustment, I'd be getting a new car before that happened!
Byron007 is offline
post #5 of 11 (permalink) Old 03-13-2011, 11:43 AM
Propflux01's Avatar
2014 Elantra Limited, Desert Bronze; 2014 Elantra GT, Shimmering Silver
Quoted: 13 Post(s)
Propflux01 is an unknown quantity at this point
instead of all that, can you not just use a depression tool to depress the bucket and remove the shim with tweezers like you would a motorcycle?
A Shovel, and a 55-Gallon drum, can solve many of life's little "irritants"..
Propflux01 is offline
post #6 of 11 (permalink) Old 03-13-2011, 02:41 PM
QUOTE (Propflux01 @ Mar 13 2011, 11:43 AM)
Fast answer --- NO
This is a 1 piece part.... the bucket is whole adjustment..
Use micrometer to measure the thickness of follower surface to bump on underside of the bucket.. ad/subtract accordingly to get desired clearance.
Kinda nice having an AZERA manual here at home.
sbr711 is offline
post #7 of 11 (permalink) Old 03-13-2011, 06:51 PM
Dennis the Mennis's Avatar
Quoted: 19 Post(s)
Just out of curiousity, does the 2.4L four also have solid/bucket lifters?
Dennis the Mennis is offline
post #8 of 11 (permalink) Old 03-13-2011, 09:01 PM
QUOTE (Dennis the Mennis @ Mar 13 2011, 06:51 PM)
I want to say yes,,, I'll have to look at paper manual tomorrow.
sbr711 is offline
post #9 of 11 (permalink) Old 03-14-2011, 12:18 PM
Service manual and related for valve clearance inspect/adjust shows same MLA system as the V6,,, measure all clearances, remove cams and MLA, micrometer check MLA and add/subtract as needed to get desired valve clearance.
sbr711 is offline
post #10 of 11 (permalink) Old 03-14-2011, 12:57 PM
ActionMan's Avatar
QUOTE (sbr711 @ Mar 14 2011, 10:18 AM)
I'm assuming that this is not a regular maintenance procedure. What are the symptons that one looks for to help determine when a valve adjustment needs to be performed?
Vehicles Owned:
  • 2009 Hyundai Sonata GLS
  • 2001 Saturn L200
  • 1986 Saab 900 Turbo
  • 1979 Datsun 210
  • 1973 Mercury Montego
ActionMan is offline
