Roaring Coming From A Tire. - Hyundai Forums : Hyundai Forum
post #1 of 13 (permalink) Old 08-22-2010, 07:02 PM Thread Starter
jessestylex
Wife just had 2 new tires put on. the front tires were pretty worn out and the rear tires still looked good. anyways they put the new tires on the rear and put the rear used tires on the front. now she said she is hearing a roaring noise that goes away after she drives a littler bit. i took it for a test drive and i kinda hear a roaring noise coming from the front of the car. almost sounds like a large truck tire going down the highway. but i dont think these small stock tires should sound like that right? could the tire be bad even though they look decent? broken belt of something inside them?
jessestylex is offline
post #2 of 13 (permalink) Old 08-22-2010, 07:22 PM
NFV6
I would have put the new Tires on the front, being it is a Front Wheel drive Car. Plus you are not supposed to mix sizes and brands.
And once a Sonata becomes unbalanced it can sound like a 747 while applying the brakes. But whatever it was, you need to go back to
the tire people!
NFV6 is offline
post #3 of 13 (permalink) Old 08-23-2010, 05:59 PM
Klute's Avatar
2007 Sonata Limited
Klute
Usually the new tires always go on the back, not the front. Something to do with handling thru turns...(according the poster on the wall last time I got new tires).
I am not to high on just replacing 2 tires at a time, especially with ESC.
I am guessing there isn't much life in the old tires moved to the front...which makes alot of noise.
You didn't buy Uniroyal 'Tiger Paws"? That might explain the 'roar'...
If you ain't first...you are last...
Klute is offline
post #4 of 13 (permalink) Old 08-23-2010, 07:03 PM
NFV6
QUOTE (Klute @ Aug 23 2010, 04:59 PM)
You might be right, but I also read to have the same type of Tires on the Sonata. I will say it sounds like whatever the Tire shop did messed it up,
and also the Sonata has a super sensitive front end and prone to problems. I wonder if they even balanced the Tires?
NFV6 is offline
post #5 of 13 (permalink) Old 08-24-2010, 08:36 AM
Klute's Avatar
2007 Sonata Limited
Klute
QUOTE (NFV6 @ Aug 23 2010, 06:03 PM)
Which is why I paid for lifetime alignment for the Sonata...they align it every rotation...
Klute is offline
post #6 of 13 (permalink) Old 09-20-2010, 07:53 PM
agengler
I have Cooper CS4 Touring and mine make that nasty noise too.
agengler is offline
post #7 of 13 (permalink) Old 09-21-2010, 12:00 AM
Drives 2016 Ruby Wine Tucson Limited Ultimate, build date 12/15. Also drives 2014 Chevy Sonic LT HB
Quoted: 348 Post(s)
rmissourimule is an unknown quantity at this point
Some tires are noisy. What kind did you get? So long as they are on the same axle they shouldn't cause undue noise.
I once bought a set of off brand tires from a local dealer. I wound up having the dealer taking them off and put a set of Toyos on and the problem went away.
I vote for bad tires, personally. And I always replace the full set of tires. Last tires I bought were Kumhos and they ride like a carpet and in my view are quieter than the Michelins that came off the car.
And one more thing. Make sure where they are manufactured. I am not at all keen on tires made in China. Japan, Korea, the U.S. and other countries are OK, but I think they cut corners over in China. Just my personal observation.
Richard
rmissourimule is offline
post #8 of 13 (permalink) Old 10-09-2010, 12:10 AM
2006 Sonata V6 GLS - 165k
Quoted: 3 Post(s)
Byron007 is an unknown quantity at this point
What a crock of poo. I always put new tires on front, I guess its opinion do what you want. If you want to get EXTRA life out your old tires, than put new tires on back and the olds up front. Rear tires don't really wear as much as the front tires. Front tires do 70 percent of braking, are responsible for traction on accelerating and turning, PLUS if you put new tires up front and the car pulls you may have an alignment issue. New tires are straight and true and shouldn't pull, used worn tires can. The Michelins are quiet, the Sumitomo's I bought make a humming noise, some times make noise so don't worry about it too much.
<<<<Update your vehicle here so others know what you drive when you post. Makes it easier to help you if you have a problem.
Byron007 is offline
post #9 of 13 (permalink) Old 10-09-2010, 12:35 AM
ActionMan's Avatar
While at Firestone for 30K Service, they had a pamphlet explaing that if only buying 2 new tires for a FWD vehicle, that the new tires should be mounted on rear to avoid oversteering and loss of control. Pamphlet said that mounting new tires on front can cause the older tires in back to loose traction much easier and spin out, while mounting them on the back allows them to maintain traction better thus reducing oversteer. Made sense to me, however I always purchase 4 new tires when old ones need replacing to avoid this exact problem.
Vehicles Owned:
  • 2009 Hyundai Sonata GLS
  • 2001 Saturn L200
  • 1986 Saab 900 Turbo
  • 1979 Datsun 210
  • 1973 Mercury Montego
ActionMan is offline
post #10 of 13 (permalink) Old 10-09-2010, 12:46 AM
Accent & Sportster
RoosterSauce
QUOTE (ActionMan @ Oct 8 2010, 11:35 PM)
This is a liability issue for the tire manufactureres; I suppose they figure it's easier to get off the hook if someone crashes due to understeer, because that just means they were going too fast for conditions, right? But if someone crashes due to oversteer, that must be the fault of the tires for not handling "properly". It really comes down to whether or not you feel safer being able to accelerate, turn and stop at the risk of the rear end sliding around a bit. Oversteer is very easy to control in a FWD car if you have good traction up front.
RoosterSauce is offline
