2007 Sonata Gls Tpms Is On - Hyundai Forums : Hyundai Forum
post #1 of 13 (permalink) Old 07-04-2010, 11:13 AM Thread Starter
ven333
Hi,
I have installed new tires around 2K miles ago and TPMS is light on yesterday. What should I do? Why the TPMS light is on?
Is it safe to drive when this light is on?
Is it covered under factory warranty? I have 33K miles on my sonata. If it is not covered, how much it is going to cost me?
Any help is appreciated...
Thanks,
Venkata
ven333 is offline
post #2 of 13 (permalink) Old 07-04-2010, 11:22 AM
Drives 2015 Sonata Sport 2.0T Ultimate 47,000 kms
Quoted: 2 Post(s)
rallyman
Did you check the tire pressures? I think it is telling you that one or more of the tires has low pressure. If it is not that and it's a problem with the system itself you should still be covered under the 5 year/60,000 mile warranty.
rallyman is offline
post #3 of 13 (permalink) Old 07-04-2010, 11:34 AM
Supernova88642's Avatar
2007 NF Sonata I4
Quoted: 4 Post(s)
Supernova88642
Your sensors might need to be reprogramed when you get new tires put in the sensors need to be put back in the same order if not the TPMS light will come on if you have the little (!) light on that means that the air is low in the tires if the actual TPMS light is on then its probably the sensors weren’t put back in the right order.
Supernova88642 is offline
post #4 of 13 (permalink) Old 07-04-2010, 12:35 PM
hatesmith's Avatar
hatesmith
Don't forget to make sure there's sufficient pressure in your spare tire.
One would think that in a life where no two snowflakes are alike one would have a brilliant rhyme for each and every bit of time.
hatesmith is offline
post #5 of 13 (permalink) Old 07-04-2010, 12:35 PM
hatesmith's Avatar
hatesmith
Sorry! Accidental multiple post! Please don't hunt down my family one by one and slowly torture them to death! I promise I'll never do it again! ...At least not on purpose...
post #6 of 13 (permalink) Old 07-04-2010, 12:51 PM
ADMINISTRATOR
Montego's Avatar
Quoted: 105 Post(s)
QUOTE (hatesmith @ Jul 4 2010, 05:35 PM)
that's one of our softer options
MONTEGO
Montego is offline
post #7 of 13 (permalink) Old 07-04-2010, 02:28 PM
Quoted: 1433 Post(s)
QUOTE (venkata @ Jul 4 2010, 11:13 AM)
Hi,
Ok, is it " [b]TPMS " or the low tire indicator (yellow tire outline with [b]! inside)
What should I do?
Do what you need to do, [b]TPMS --> some sort of electrical malfunction/sensor fault... [b](!) illuminated, correct the air in the tires.. read your owner manual, it is explained in there..
[b]TPMS --> sensor or module/wiring malfunction
[b](!) --> tire pressure low/high, excessive pressure difference somewhere
[b]TPMS --> drive it till the cows come home
[b](!) --> correct the air in the tires, not good to drive on flat tire(s)
Fault of material and workmanship, yes, broken sensor when remove/install new tires, no.
Depends on what the actual problem/part found is, and its cost to repair or replace, you'll have diag/scan time, parts and labor..
Thanks,
Venkata
sbr711 is offline
post #8 of 13 (permalink) Old 07-04-2010, 02:58 PM
2007 NF Sonata I4
Quoted: 4 Post(s)
Supernova88642
I have 3 extra sensors and the tpms moduel i took out of my car is if thats whats wrong with your car ill sell them real cheap if you need them
post #9 of 13 (permalink) Old 07-08-2010, 10:12 PM Thread Starter
ven333
Thanks to all of you for your replies. I took my car to oil-change today and they reset the TPMS sensor and now it is off. They did not say any reason why it is ON.
My steering wheel is vibrating little bit when I go at 70-80 MPH in freeways, so they have asked me to re balance the tires as the tires are recently installed. I will have to take it to the tire shop tomorrow.
Thanks,
Venkata
ven333 is offline
post #10 of 13 (permalink) Old 07-08-2010, 10:25 PM
QUOTE (venkata @ Jul 8 2010, 10:12 PM)
Thanks,
Venkata
Who is they ?
70-80 MPH.... I be looking at RFV concern if the tires indeed balanced correctly..
sbr711 is offline
