06 Sonata Rotor Removal - Help! - Hyundai Forums : Hyundai Forum
post #1 of 13 (permalink) Old 05-13-2010, 09:23 AM Thread Starter
wnbklb
Hi:
I'm new to this forum, so I hope this is posted in the right place.
I'm in the process of replacing all 4 rotors and all brake pads on my wife's 06 Sonata (6 cycl.). Removal of the front calipers is easy enough, but I can't get the rotors off. I haven't had any success in loosening the philips screws that I assume need to come out in order to pull the rotors away from the hub. Is there something I'm missing or is there a trick to doing this? I'd greatly appreciate any tips/help on this. Thanks so much!
wnbklb is offline
post #2 of 13 (permalink) Old 05-14-2010, 09:08 PM
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
Quoted: 65 Post(s)
I moved your topic to the 4G Sonata forum....these are the guys most likely to have the answers to your question.
Andrew
Titanium Gray / Gray Leather
lovemysantafe is offline
post #3 of 13 (permalink) Old 05-14-2010, 09:23 PM
sonata33
From all of my experience, the best way to get the rotors off is with pure force. Take a wooden block and a mallet and give it your best shot from behind the rotor. Don't be shy, these things are strong!
sonata33 is offline
post #4 of 13 (permalink) Old 05-14-2010, 09:25 PM
sonata33
Sorry, I missed the part about the phillips head screw. I didn't encounter that problem. I'm sure others in this forum will be able to help
sonata33 is offline
post #5 of 13 (permalink) Old 05-14-2010, 10:37 PM
Kent2406
Instead of beating on your car, watch this youtube video, it works very well. http://www.youtube.com/watch?v=mtsTJCRljAs
Kent2406 is offline
post #6 of 13 (permalink) Old 05-14-2010, 11:24 PM
2006 Sonata V6 GLS - 165k
Quoted: 3 Post(s)
Byron007 is an unknown quantity at this point
The problem he is having is with the philips screws, same problem I had. You try to remove them, they strip out. My dad helped me remove them, he had a screw extractor kit. Using a drill bit, drill into the head of the screw, then insert(or hammer????) screw extractor, then using plyers loosen screw extractor which has bonded itself to screw.
The rotors were stubborn to come off, a hammer was useless. One whack with a sledge hammer and they came right off.
http://www.youtube.com/watch?v=YmfzwCobIJE...feature=related There is a vid for removing stripped screws.
<<<<Update your vehicle here so others know what you drive when you post. Makes it easier to help you if you have a problem.
Byron007 is offline
post #7 of 13 (permalink) Old 05-17-2010, 08:52 AM
skycomag's Avatar
2011 elantra gls
skycomag
those philip heads can round out easily. i
have you tried soaking with a lot of penertating oil first. then get a impcat driver with a heavy hammer.
i wouldn't use a impact wrench of any tpye. if you strip the philips head you'll have a hella of a time removing them.
jusy mt 2cents worth.
skycomag is offline
post #8 of 13 (permalink) Old 05-17-2010, 09:05 AM
Dennis the Mennis's Avatar
Quoted: 19 Post(s)
I've used PB Blaster and waited overnight. It usually works with corroded/rusted screws/bolts.
Dennis the Mennis is offline
post #9 of 13 (permalink) Old 05-17-2010, 05:24 PM
edge183
all you need is a impact driver you can purchase these very cheap at a local auto parts store for about $20 and it will take about 10 seconds to remove those screws
http://www.google.com/products/catalog?hl=...ed=0CFMQ8wIwBg#
what you do is hit the tool with a hammer and the force from the hammer pushes in a and the tool spins at the same time. its a tool anyone who does brakes should have. those screw are anti-chadder screws
edge183 is offline
post #10 of 13 (permalink) Old 05-17-2010, 05:56 PM
Quoted: 1183 Post(s)
Stop wasting your time with them phillip screws... Take a #3 phillips, place in screw, RAP driver handle a few time to shock the screws. If they still stubborn, I take a die grinder and cut the head right off in the rotor, leaving the small portion of stud.. knock rotor off, and grind stud off, or leave it..
sbr711 is offline
