Front Lip Body Kit - Hyundai Forums : Hyundai Forum
post #1 of 38 Old 09-22-2013, 11:41 PM Thread Starter
Everythingelantra's Avatar
Drives 2012 Elantra
Quoted: 2 Post(s)
Everythingelantra is an unknown quantity at this point
Front Lip Body Kit
I know a good amount of members on here have the TUIX front lip kit but I found one just like it on eBay for only $100. Will this one be just as good? Or should I just spend a couple hundred more for the TUIX one? Thanks in advance.
http://item.mobileweb.ebay.com/viewi...d=181217934184
Everythingelantra is offline
post #2 of 38 Old 09-23-2013, 12:03 AM
OkieRich's Avatar
Quoted: 615 Post(s)
These guys have been around for a while. Seems mighty reasonable on the pricing. Only 2 things caught my attention:
1. No installation instruction and mounting hardware are included.
2. If in any case the lip became warped, simply lay it on a flat surface under the sun or use a heat gun gently heat up the warped area. The poly urethane material will restore back to its original shape when heated and stays that way after it cools down. I'm not competent or versed in this type of materials.
Could be great stuff for all I know.
Now, they claim to have a refund policy (with limits). $100 bucks and you can be our guinea pig. I'm wondering how it will hold up over time. Again, material composition. I defer to the pro's for comment.
Regardless, watch how you pull up in parking lots once you put that on. Those concrete curb blocks can undo a lot of love and labor!
BTW, welcome to the family.
Okie Rich
Forum Rules
OkieRich is offline
post #3 of 38 Old 09-23-2013, 12:31 AM
RomelM12's Avatar
Drives 2012 Hyundai Elantra LTD
RomelM12 is an unknown quantity at this point
Don't do it bro. It doesn't even come painted. You'll be spending another $200 just for paint. Secondly the genuine TUIX lip comes with a pretty sturdy mounting bracket that is held firmly in place with rivets.
It's less than $280 or so from the dealership. Buy the real thing. And install it yourself. Buy a rivet gun from Lowe's for $20 bucks.
ADD-ONS: TUIX Front/Side Skirts + EZ Lip, Rear Diffuser, SuperDrift Trunk/Technica Roof Spoiler, RoadRuns grille, OE Black S.View Mirror Covers
VINYL: Roof/Door Strip/Rear Bumper in Black. Fogs in Yellow
MISC: Concepto Badges, Red Calipers, Black Door Handles, Red Tow Hook, Husky Liners, PrecisionLED's
SUSPENSION: XXR 522 (Gold) 18x8.5+48 on 225/40, KSport Kontrol Pro Coilovers, Shark Racing Subframe Bushings, Pierce Rear Torsion Bar
ENGINE: MagnaFlow Muffler
RomelM12 is offline
post #4 of 38 Old 09-23-2013, 12:49 AM
OkieRich's Avatar
Quoted: 615 Post(s)
^ Voice of reason and common sense. Man, I love the pool of knowledge and talent in this forum.
Okie Rich
Forum Rules
OkieRich is offline
post #5 of 38 Old 09-23-2013, 02:31 AM
1badsr's Avatar
2013 elantra
Quoted: 29 Post(s)
1badsr is an unknown quantity at this point
Isnt this the same company Gamerguy got his kit from? I wonder if it's the same mounting process as the Tuix lip. Yes getting it painted will be a pain. The real Tuix kits come painted and match perfect. I got mine from hi-motors for 209 shipped and received in less than a week.
1badsr is offline
post #6 of 38 Old 09-23-2013, 09:56 AM
Petie1881's Avatar
2011 Hyundai Elantra Limited/2013 Hyundai Sante Fe (6 seater) Limited
Petie1881 is an unknown quantity at this point
Same lip I have, made great, comes with all hardware for installation, easy to install, on the other hand it is NOT painted....it will cost you, My car is N5S which is water based so it was pretty tricky.
Petie1881 is offline
post #7 of 38 Old 09-23-2013, 10:28 AM
Ghernandez019's Avatar
Drives 2011 Elantra
Quoted: 2 Post(s)
Ghernandez019 is an unknown quantity at this point
Petie, did yours come with the mounting bracket? I got mine from a forum member and I like how mine is installed now but it was a bit tricky to install without the bracket.
Ghernandez019 is offline
post #8 of 38 Old 09-23-2013, 12:29 PM
Drives 2013 Elantra Limited
Quoted: 27 Post(s)
Stresstest is an unknown quantity at this point
From the auction description:
I would NOT buy this
'13 Elantra Limited w/Tech
18x8 Niche Targa M131 Silver Machined
ExLED interior kit 6k w/ trunk and license plate
6000k HID all around, OEM Spoiler
Bumper reflector to LED mod
Infinity Reference 6030cs front/6032s rear
Soundstream SC-8F cap
AudioControl LC6i line converter
Fosgate P2D2-12 in a A-Trend E12SV box
JBL GTO-5EZ 5-channel Amp
CREE 5 watt 6k reverse projector lights
Stresstest is offline
post #9 of 38 Old 09-23-2013, 02:21 PM Thread Starter
Drives 2012 Elantra
Quoted: 2 Post(s)
Thanks for all the input. So from what I'm reading I should just purchase a TUIX front lip. And $209 shipped isn't bad, I'll definitely look on hi-motors. Is it hard to install yourself? I'm no where near a mechanic so is there a video anywhere on how to do this? Thanks again.
post #10 of 38 Old 09-23-2013, 03:10 PM
1badsr's Avatar
2013 elantra
Quoted: 29 Post(s)
The install is pretty simple. You will need a rivet gun, various drill bits, a center punch, some isopropyl alcohol/water mix, jack, jack stands. The Tuix kit is very well made and once it's on, its not goin anywhere. The instructions come in Korean. For the English instructions go to hmaservice.com
1badsr is offline
User Tag List
