Alignment issue - Hyundai Forums : Hyundai Forum
post #1 of 9 Old 11-16-2012, 11:18 AM Thread Starter
2012 Black Elantra Limited
Quoted: 2 Post(s)
blackelantra is an unknown quantity at this point
Alignment issue
Happy Friday!
So I went to the dealership last night to get my steering wheel replaced, oil change and get my tires rotated. They mentioned I needed an alignment done because they asked me I rode a lot in the city with potholes. While I don't drive much in DC, I did run across a few potholes/manholes here and there but my alignment has always been fine so I declined to get it. On the ride home, I felt when I was going straight on the roads, my steering wheel was tilted a few degrees to the left so I am a bit concerned. How much are alignments usually? the dealer wanted to charge me 100 bucks. I feel they may have messed it a bit for me to come back and get it done because I swear it was fine before I got there but I don't want to point fingers when I don't have legitimate proof.
blackelantra is offline
post #2 of 9 Old 11-16-2012, 11:32 AM
pare_john's Avatar
Quoted: 36 Post(s)
Alignment issues are not always noted by the driver. Even if it is slightly off it could cause premature tire wear.
Sent from my iPhone using AutoGuide.com App
pare_john is offline
post #3 of 9 Old 11-16-2012, 01:06 PM
new2013's Avatar
Drive's 2013 Elantra Manual, Sparkling Ruby!
new2013 is an unknown quantity at this point
Send a message via Skype™ to new2013
I bought my E in June it was a 2013 so brand new and no previous test drivers as it had 2km on it, so I took it for my test drive and decided I wanted it at the end and since it was the only stick they had it was the car I ended up with! So about a month or so ago I noticed my steering wheel was aimed to the left enough that if it was straight the car should be turning at that point but it went straight, took it in and they did an alignment they said said it was off a bit. To this day it's still turned a little to the left its almost like they need to remove the wheel and aim it straight and remount it then tighten?!. My car drives straight so the alignment seems fine the only thing I notice now is when I drive over a swing bridge that's metal grating in town here the front tires just start to wonder on they're own(no idea why but it does), so i figured I'd wait until my second oil change at 12,000 kms I'll be hitting close to 6,000kms by Monday when they do my first service so I figured I'd drive it more and see what happens!?
2013 Elantra Sparkling Ruby, Stick, (aka 'Ruby')led driving lights,
Chrome RSA 17" Rims, Tinted 15%,Plast-Dipped front grills, plasti dipped rear emblem & bumper section, Removed 'H' off trunk, 6000k hids, Flowtech Muffler w/Custom Stainless Tip (mellow sound), Powerbass 2 way 6.5s x4 with 600watts Sony Amp
2-12" Infinitys, ported box w/Powerbass 2000.1d
Custom made chrome cai, white interior led panel's, led license plate bulbs, dash & backup cams
The start of my list.
new2013 is offline
post #4 of 9 Old 11-16-2012, 02:40 PM
someguy's Avatar
Quoted: 194 Post(s)
I think the steering wheel slightly left is an optical illusion for some people. The dash is all curvy and swoops down to the left and sometimes mine seems off when its really not. I am not saying your case is the same, just sharing mine.
someguy is offline
post #5 of 9 Old 11-16-2012, 07:43 PM
new2013's Avatar
That is true though, if you sit back and get the full view it does sit slightly to the left to follow the curves of the dash etc.
new2013 is offline
post #6 of 9 Old 11-19-2012, 10:26 PM Thread Starter
Quoted: 2 Post(s)
Luckily, my uncle is owns a mechanic/body shop so I gave him my car to fix for tomorrow, he doesn't think its an alignment issue. It is fairly a new car with only 13k miles and it didnt go through any collision of any sort. He just thinks its the service department at the dealer trying to rip me off by installing the steering wheel slightly off so they can charge me 100 bucks by re-fixing the wheel placement. We'll see what he says tomorrow.
post #7 of 9 Old 11-19-2012, 10:41 PM
Em-squared's Avatar
I hope that is not true, but if it is, that's awfully slimy.
Fashionista.
Em-squared is offline
post #8 of 9 Old 11-19-2012, 11:11 PM
jepank's Avatar
Drives 2013 Boston Red VT. 2014 SantaFe Sport Limited.
jepank is an unknown quantity at this point
go to some shop with free alignment check.
and in canada, they will fix the alignment under 20k kms/1 year under warranty.
jepank is offline
post #9 of 9 Old 11-20-2012, 02:30 AM
Spiffyguitar's Avatar
2013 Sonata Limited 2.0T w/nav 2014 Elantra Limited w/nav 2014 Ducati M1200S
Quoted: 2 Post(s)
Spiffyguitar
When a car is aligned, the steering wheel needs to be pointing perfectly straight. If it's not... the car will be aligned with the wheel tilted however it was when the alignment was completed. If the car was aligned properly it will still track straight, but will be annoying to look at the wheel. Haha
2013 Sonata Limited 2.0T w/ nav
2014 Ducati M1200S
Spiffyguitar is offline
User Tag List
