Winter tire downsizing? - Hyundai Forums : Hyundai Forum
#1 Old 11-11-2012, 10:02 AM
Londonguy
I know there have been other threads on this somewhere but I have stock Contintental 205/55/16 and want to get a new set of winter tires. Question is can I downsize this safely to 195/65/15? Will the tire shop know the exact 15" rims I should get as well, paying attention to offset etc. Has anyone done this with their 16s down to 15's for winter? Thanks.
Londonguy is offline
#2 Old 11-11-2012, 10:24 AM
Aaron.H
Guest
Posts: n/a
Quoted: Post(s)
Doing so right now. I have the 16" steelies that came with the elantra but neede winters and trying to reduce bit of cost to downgrade to 15" tires for winter. The base model comes with 15x6 steelies. Also keep in mind center bore size when ordering steelies or aftermarket rims if not oem as may not be the elantras 67.1mm otherwise you'll likely need hub centric rings. Luckily for me the steelies were that size. I bought set of continental extreme winter contacts(195/65/r15) on 15x6(67.1 center bore)
#3 Old 11-11-2012, 10:51 AM
Londonguy
Thanks. Did you go with OEM rims?
#4 Old 11-11-2012, 11:13 AM
TurboLed's Avatar
Drives Elantra GT GL 2013
You save about 100$ or more going 15" instead of 16", way enough to save on the price of the rims. That's a smart move I think.
TurboLed is offline
#5 Old 11-11-2012, 03:00 PM
drives Elantra GLS
HamRadio is an unknown quantity at this point
I just placed my order with the dealer. He recommended that I downsize with the 195/65/15 winter tires. The Elantra GLS came with the Continental tire as described by you. I bought Yokohama winter tires. Dealer matched the cost from a Tire shop in town.
Installation will be on the 21st. I bought his steel rims although they were more expensive. In the long run it evens irself out. At least I am sure of the quality with the Hyundai rim.
HamRadio is offline
#6 Old 11-11-2012, 11:06 PM
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
Quoted: 3 Post(s)
I have the 17" Limited wheels and tires and for the snow tires I downsized to the 16" size from the GLS for...you guessed it...cost.
- Andrew
Titanium Gray / Gray Leather
lovemysantafe is online now
#7 Old 11-12-2012, 07:56 AM
Xion's Avatar
Quoted: 2 Post(s)
15'' is better in winter, more rubber = smooth ride over pothholes. I negotiated mine with stellies when I bought the car. I got them for free.
Xion is offline
#8 Old 11-12-2012, 09:24 AM
Krzysiek2011's Avatar
2011 Elantra GLS
Krzysiek2011
Same here, I have 15" for winter and 16" for summer.
Krzysiek2011 is offline
#9 Old 11-12-2012, 05:49 PM
Don67's Avatar
Quoted: 2 Post(s)
I downsized to 195/65R15... piece of cake. It's the standard size for base model Elantras here in Canada.
Skinny and high profile is definitely the way to go in winter.
Don67 is offline
#10 Old 11-12-2012, 06:46 PM
Aaron.H
Guest
Posts: n/a
Quoted: Post(s)
no still aftermarket multi miles or something they are called but the center bore was still 67.1. i could have got the Hyundai steelies but that was $5 more each
User Tag List
