Problems with 2013 Elantra bluetooth and Galaxy S - Hyundai Forums : Hyundai Forum
#1 Old 05-25-2012, 03:03 PM
Drive 2013 Elantra Limited
Barb is an unknown quantity at this point
Hello,
First time posting to the forum. I just bought a Elantra 2013 Limited. I like the car but I am having problems with the Bluetooth and my Samsung Fascinate Galaxy S phone from Verizon.
I am able to pair the phone with the Bluetooth but it works intermittently. It will disconnect after a call or sometime not connect when I turn the car on. I am not able to reconnect unless I restart the car and sometimes I have to turn off and back on the Bluetooth on my phone.
Does anyone else have a Galaxy Fascinate with the same problems? Any suggestions on how I might fix this problem?
Thank you for your help,
Barb
Barb is offline
#2 Old 05-25-2012, 03:11 PM
Em-squared's Avatar
Hi and welcome to the forum!
I have the Galaxy S for Tmobile, and encounter similar issues. A good example is, the phone works fine with the bluetooth when I've just turned the car on and enabled the bluetooth on my phone, but if I were to hang up and try another call, sometimes it won't work. I can't leave the bluetooth on my phone on for long amounts of time, as the phone battery power greatly diminishes and the phone freezes up, runs slowly, and occasionally overheats and shuts off by itself. The overheating occurs when it's on the car charger mostly.
Personally, I dislike my Galaxy S for this and other reasons, but I'm stuck on contract till 2013, because my husband and I were on the same plan, but he dropped off when his work offered to pay for his own phone plan with an iPhone. Long story short, when he dropped off, it re-set my contract, so now I'm stuck with the Galaxy S even longer.
Fashionista.
Em-squared is offline
#3 Old 05-25-2012, 03:54 PM
someguy's Avatar
Quoted: 163 Post(s)
Welcome to the forum several of us are from the Austin area. Check out my garage and if you see me on the road make sure you wave. From your issues it sounds like it may be the phone.
Some things to try are rebooting phone, its a little computer and has to be rebooted sometimes and this is a very easy fix.
Delete phone from stereo and start fresh. You can even go into phone and change the name of the phone in bluetooth settings so car thinks its a totally different phone.
Update android software if not on current version. Not sure how Verizon does it but you might have to go into store or call. You can even go as far as doing a full factory reset but backup your data and apps because this wipes the phone clean.
As mentioned bluetooth eats battery so I use a widget and toggle mine on when I get in car. Good luck
someguy is online now
#4 Old 05-29-2012, 12:19 AM
Perpetuous Dreamer's Avatar
Drives 2012 Ford Mustang GT, 2012 Accent GLS, 2012 Elantra LTD.
Perpetuous Dreamer is an unknown quantity at this point
We both have a Samsung Galaxy from Tmobile. I have the S, she has the S2. We have both had issues with Bluetoof connectivity when driving her Elantra. Wont connect, freezes up, bla bla bla.
However, I picked up a 2012 Accent GLS a couple of months ago and I have very few issues connecting to this car with my Galaxy S. She does not drive this car so I don't know if her's would work fine with it or not. About the only issue I have is about once a week I have to go and re-pair the phone with the car.
Perpetuous Dreamer is offline
#5 Old 06-07-2012, 04:30 PM
Drives 2012 Hyundai Elantra
help_u@@yahoo.com is an unknown quantity at this point
Unhappy Bluetooth not working
I took my Elantra Limited back to the dealer because if someone called in while I was bluetoothed it would knock my call off. The salesman said my phone did not have call waiting capabilities. After that my contacts would no longer download into the phone for hands free calling. I took it back to the dealer & they said it was my phone (which had been working perfectly hands free for 3 months). The whole reason I picked the car I did was for the hands free bluetooth...HELP!
help_u@@yahoo.com is offline
#6 Old 06-07-2012, 05:06 PM
Don67's Avatar
Drives 2012 Veracruz GL FWD, 2011 Elantra GLS Auto, 2012 Volvo S80.
Quoted: 45 Post(s)
I have the Galaxy II Infuse, and maybe once or twice a month it fails to connect automatically when I start the car. I've never noticed it dropping the connection after a call, however it is possible that I've just never noticed because I don't use it regularly enough.
Don67 is offline
#7 Old 06-07-2012, 08:30 PM
someguy's Avatar
Quoted: 163 Post(s)
Next try your cell phone provider for support. Might have to reset something in the phone.
Sent from my SPH-D710 using AutoGuide.Com Free App
#8 Old 06-08-2012, 02:21 PM
TunedOut's Avatar
2013 Accent 5dr Hatch L 2011 Elantra Limited w/Nav - traded 2002 Elantra VE - Sold
TunedOut
I had the Galaxy S up until a few months ago, same issues with no fix, easiest thing to do is just turn off Bluetooth and turn on again from the phone end.
I just upgraded to a Motorola razor xt910 and have zero issues, works like a charm......when somebody texts me while I am linked to my car, it send an auto reply stating that I am driving and will get back to them when I am done
TunedOut is offline
#9 Old 10-28-2012, 01:44 PM
2012 Hyundai Elantra GT
lwj01998 is an unknown quantity at this point
Wink
I have a 2012 Elantra GT with large GPS guidance screen and bluetooth built in. It was great---for a short time. At first it loaded all of my contacts on my iphone 4 and they were very handy there.
Then it lost all but 17 contacts, and shortly after it lost them all.
My local dealer has a report to Hyundai Canada on this but so far this has not been resolved. I could get a ticket due to a malfunctioning system I paid good money for if I don't pull over and park to see on the phone who i wish to phone. I upgraded the iphone software to 6. Cleared the phone, reset the car system--no luck. Last I heard Hyundai and Apple were working to find a solution. This has been months now. --Frustrated in Winnipeg.
lwj01998 is offline
#10 Old 10-28-2012, 08:50 PM
Gray229's Avatar
2012 Elantra GLS
Gray229 is an unknown quantity at this point
I had the same issues, (owned a vibrant which is the tmobile version.) I will just say the phone itself is garbage. Plagued with software issues and terrible GPS. Applies to all carrier variants of gs1's. (I even rooted and installed custom ROMs to make it the best it could be.)
I got a gs3 on tmobile now and all problems regarding bluetooth disappeared. This is the phone I wish I had two years ago. Works perfectly.
Now if only the car would understand my voice commands. >_>
edit: Hory crap didn't notice this thread was necro'd.
2012 Black Elantra GLS
Mods: 8000k Xenon HID - Retrofit Bi-xenon Morimoto Mini Projectors - exLED Angel Eyes - exLED SF-Block LED DRL - Black Turn Signal Reflectors - Factory Style Spoiler w/ LED - exLED Bumper Reflectors LED - Bumper Diffuser - Bazooka 8in 100w Sub w/ remote - Megan Racing Lowering Springs
Last edited by Gray229; 10-28-2012 at 08:52 PM. Reason: edit: Hory crap didn't notice this thread was necro'd.
Gray229 is offline
User Tag List
