Experiencing random long starts - Hyundai Forums : Hyundai Forum
post #1 of 5 (permalink) Old 06-18-2017, 11:52 AM Thread Starter
2007 Sonata V6 3.3L 2011 Sonata 2.0 Turbo 2011 Elantra 1.8 Sedan Limited
Quoted: 5 Post(s)
kneeprints is an unknown quantity at this point
2011 Elantra Limited 1.8. Has long starts at random. About every day or so.
Suspected fuel pump/pressure but does not happen specifically first thing in the morning or after sitting all day at work. No Check Engine lights either. Car does have almost diesel like sound at idle, but I am told that is normal - i.e, injectors maybe. Cannot identify a pattern/condition that would point to a specific system, so any help appreciated. Symptoms could point to crank/cam position sensor but I see no check engine lights/codes. No pending codes.
kneeprints is offline
post #2 of 5 (permalink) Old 06-18-2017, 01:28 PM
Drives 2001 Elantra GLS 2.0L Auto
Quoted: 328 Post(s)
Usual suspects are fuel pump and/or crankshaft position sensor
Guessing to find out it would require more knowledge about the electrical waveform generated by good and faulty part
Otherwise, maybe a fuel pressure gauge or oscilloscope???
Don't know.
avisitor is offline
post #3 of 5 (permalink) Old 06-18-2017, 06:48 PM
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
Quoted: 73 Post(s)
Does it do an extended crank but doesn't turn over like it's starved for fuel?
If so, mine does that at total random if I try to start it after it sits for 2-3 hours but any shorter and longer and it'll turn right over. I've never quite figured out what causes it and it doesn't happen enough to be a problem. If it starts to stumble and crank long, I just hit the button to abort the launch attempt and push it immediately again. Starts right up...so weird.
Andrew
Titanium Gray / Gray Leather
lovemysantafe is offline
post #4 of 5 (permalink) Old 06-19-2017, 06:21 AM
Drives 2013 Elantra GLS
Quoted: 119 Post(s)
Haul is an unknown quantity at this point
I'm surprised that no one has mentioned the battery yet.
Haul is offline
post #5 of 5 (permalink) Old 06-19-2017, 06:31 AM Thread Starter
Quoted: 5 Post(s)
Really?....I am assuming you are being sarcastic. Or it could be the blinker fluid is too low.
