- Rim is 6 mm closer to suspension/brakes components. Acceptable for most cars
- Tire will stick out 12 mm farther. Rim will stick out 20 mm farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset
- Will fill out the wheelwell by extra 6 mm. Acceptable for most cars
I would assume yes but I can never determine how close you can go to the "suspension components" on our cars. I would think if you aren't lowered you should be fine. Just remember to grab some hub rings to adapt to our 67.1mm hub. 74.1mm -> 67.1mm
Took my the wheel to a tire shop and verified that it'll fit and mount up fine. I asked about having a new TPMS set up with the wheel. Ultimately, what I'd like to do is have 5 of the same wheel/tire combo and just do a 5 tire rotation to extend tread life as much as possible. The guy behind the counter didn't think you could program 5 sensors to work. Anybody have any idea? If not, guess I'll just roll with 4 and throw my best current tire in the trunk for a spare.
Thanks for the info. I guess I'll spend the 5th wheel/tire money on ARK lowering springs.
Kevin T
