2013 Elantra Tires - Hyundai Forums : Hyundai Forum
post #1 of 14 (permalink) Old 01-17-2013, 11:14 AM Thread Starter
ialeem's Avatar
Hyundai Elantra GL 2013
ialeem is an unknown quantity at this point
2013 Elantra Tires
Hi everyone,
My tire size is 205/55/R16. I'm wondering if 215/60/16 tires would fit on the 2013 Elantra GL?
ialeem is offline
post #2 of 14 (permalink) Old 01-17-2013, 11:28 AM
northey87's Avatar
Yes and no. Yes they will fit but the diameter will be 5% larger meaning that when your speedo shows 60mph your actually going 63mph. Most all tire place recamend that you stay within 3% of the stock diameter. A 215/55 16 is 1.5% larger, and a 215/50 16 is 1.5% smaller. I would stick with one of those or the stock size.
"The Mouse"
Mods
northey87 is offline
post #3 of 14 (permalink) Old 01-17-2013, 11:44 AM Thread Starter
ialeem's Avatar
Great, thanks!
Also, will any 16'' rims fit on my car? Or is there something else to look out for?
ialeem is offline
post #4 of 14 (permalink) Old 01-17-2013, 12:09 PM
OkieRich's Avatar
2017 Elantra Ultimate 2.0 2016 Tucson Ultimate 1.6T
Quoted: 2154 Post(s)
In a word, NO! Rims must have the correct bolt hole configuration. They must also fall within the correct "offset" parameters. See that itty-bitty hole in the center of the wheel? Any wheel you buy must have a center hole large enough to fit over the center hub of your rotors. Do your research. A little knowledge beforehand sure pays dividends in the end...to say nothing about less headaches.
There's a ton of info in this forum about what you are wanting to do. And the members will help you, as well. My best advice: Research, research, research.
Okie Rich
<- NEW MEMBERS: Please enter your "location, model, etc." on your profile.
OkieRich is offline
post #5 of 14 (permalink) Old 01-17-2013, 12:46 PM Thread Starter
ialeem's Avatar
Thanks Rich.
I even called the dealer for more information on the rims so that if I'm buying them aftermarket I can get the right ones. All they knew was to get 5 bolt 16'' ones, and buy from the dealer to avoid mismatch issues.
They couldn't tell me any other details about the offset.
If anyone knows what the other parameters are for the 2013 Elantra rims, please share.
ialeem is offline
post #6 of 14 (permalink) Old 01-17-2013, 12:58 PM
OkieRich's Avatar
Dealer is stupid. Stay away from buying his wheels. Rediculous markup. Go to Discount Tire, look on Tire Rack, or other websites...
Posted by a fellow forum member (apologies to the author):
OEM wheel info:
Steel 16x6.5 offset +46 (~23lbs)
Aluminum 16x6.5 offset +46
Aluminum 17x6.5 offset +46 (~22lbs)
Bolt pattern 5x114.3mm (5x4.5in)
Center hub is 67.1mm
Wheel calculators:
http://www.miata.net/garage/tirecalc.html
http://www.1010tires.com/tiresizecalculator.asp
http://www.rimsntires.com/rt_specs.jsp
http://www.willtheyfit.com/
Okie Rich
OkieRich is offline
post #7 of 14 (permalink) Old 01-17-2013, 01:04 PM
2017 Elantra Limited
Quoted: 6 Post(s)
jc6971 is an unknown quantity at this point
tire rack.com
jc6971 is offline
post #8 of 14 (permalink) Old 01-17-2013, 01:22 PM
guidget's Avatar
2013 Elantra
Quoted: 4 Post(s)
guidget is an unknown quantity at this point
Originally Posted by ialeem View Post
Hi everyone,
Just curious, why would you go with a 60 sidewall? You'd be safe with a 215/50r16. It'd give you a wider tire and about the same sidewall as your 55.
guidget is offline
post #9 of 14 (permalink) Old 01-17-2013, 02:55 PM
TurboLed's Avatar
Drives Elantra GT GL 2013
Quoted: 53 Post(s)
Originally Posted by OkieRich View Post
OEM wheel info:
Where did you get these infos? I was looking for the GT wheels specs...
TurboLed is offline
post #10 of 14 (permalink) Old 01-17-2013, 03:40 PM
Aaron.H
Guest
Posts: n/a
Quoted: Post(s)
OEM wheel info:
Wheel calculators:
Tire size calculator
Tire Size Calculator - tire & wheel plus sizing
Online Wheel & Tyre Fitment calculator. Offset, Tyre stretch and Rolling Radius calculator
I can confirm those specs are correct
And OP. try PMC tires, bought my winters on steelies mounted and balanced and shipped for $906.... A local place in Winnipeg will run me between 12-1400 pending where I would have bought from... But also try like tire rack and discount tires like others mentioned
