Leaking through dash? - Hyundai Forums : Hyundai Forum
post #1 of 10 (permalink) Old 11-18-2012, 09:45 AM Thread Starter
Drives Accent, GMC Sierra, Honda Goldwing, Yamaha FZ6R, Yamaha Roadstar custom
Midnightroadie04 is an unknown quantity at this point
Hello all, Newbie here,
First off - I did a search and found a couple of other threads that are addressing my issue, but none have mentioned their car leaking into the heater fan that i saw.
I have an 08 Accent hatchback, no sunroof. I am having water soaking the passenger floor board and getting into the heater fan. If I park on a side hill it actually drips out of the bottom of the fan motor, and you can hear it being sprayed inside it when going around a corner. Checked the windshield - seal is good, took off the cowling under it and everything was dry - including the filter for the fresh air, so it doesn't appear to be coming down through there. I even poured about 8 gallons of water down the windshield and into the run-off channel at the bottom of the windshield and nothing seemed to get into the fan or leak into car, however, by the time I drove it home 4 hours later, it was in the fan again. Is there some other way to for it to getting to the fan? It's not coming from the door side, as it is usually dry on that side when it first starts getting wet, but rather it stars from the left of the passenger foot well.
Any help would be appreciated.
Midnightroadie04 is offline
post #2 of 10 (permalink) Old 11-18-2012, 09:56 AM
ADMINISTRATOR
Montego's Avatar
Quoted: 97 Post(s)
are you sure that the heater matrix is not leaking? are you loosing engine coolant?
MONTEGO
Montego is online now
post #3 of 10 (permalink) Old 11-18-2012, 12:33 PM
Burnitwithfire's Avatar
2010 Accent LE 5spd
Burnitwithfire is an unknown quantity at this point
If the heater core was leaking there would be a definite coolant smell in the cabin. I'm not sure coolant would make its way to the fan.
I hate signatures with pictures.
Burnitwithfire is offline
post #4 of 10 (permalink) Old 11-18-2012, 12:35 PM
Quoted: 3 Post(s)
And Don't Call Me Shirley is on a distinguished road
Check the condensation drain tube. If it popped off or got clogged by road debris, you can get water in the fan box, eventually overflowing as you describe.
And Don't Call Me Shirley is offline
post #5 of 10 (permalink) Old 11-18-2012, 12:43 PM
boka.split's Avatar
Accent GLS
boka.split
I am loosing engine coolant, but there are no leakings anywhere. Is it normal that it goes about 1/4 of an inch down in a half of a year?
boka.split is offline
post #6 of 10 (permalink) Old 11-18-2012, 09:36 PM
2010 Accent LE 5spd
Any loss isn't normal but a 1/4 of an inch isn't that bad. A compression test on the cooling system would tell you where the leak is.
post #7 of 10 (permalink) Old 11-20-2012, 05:42 AM Thread Starter
Definitelynot coolant. Has no odor or slipperiness. Just weird it could get into the fan housing.
post #8 of 10 (permalink) Old 11-20-2012, 05:45 AM Thread Starter
Condensation drip tube from what and where would I find it? This is a fairly substantial amount of water and puddled in the passenger floorboard once after about 4 days of rain. Also the car was nor being driven but one of those days.
post #9 of 10 (permalink) Old 11-20-2012, 01:50 PM
2007 Accent
FIRSTGEAR is an unknown quantity at this point
Does it still have warrenty? Maybe the dealership can do some troubleshooting for you.
FIRSTGEAR is offline
post #10 of 10 (permalink) Old 11-20-2012, 07:17 PM
Quoted: 3 Post(s)
The drip tube generally goes from the a/c evaporator housing out through the firewall to the open road. I can't recall exact placement in the accent. All air conditioned cars have one. The normal function is to allow condensation from the evaporator coil to drip outside of the car. Some also serve as drains for minor leakage into the air box. Since you were not operating the car, this is clearly not condensation, but it may still be a failure of the drip tube. In USDM cars, the tube usually exits the right side of the air box and passes through the firewall near where the passenger's toes are.
