Short Air Intake - Hyundai Forums : Hyundai Forum
post #1 of 9 (permalink) Old 11-17-2012, 10:10 AM Thread Starter
Quoted: 10 Post(s)
ottawa is on a distinguished road
Short Air Intake
A few questions about Short Air Intakes:
1) Is it worth the money? any gain in Hoursepower and gas mileage?
2) Because it sucks more air, does it tell MAS sensor to use more fuel? and you end up using more fuel than saving
3) People say because in general SAIs are close to MAS sensor, that is why it damages the sensor or make the sensor work weird.
4) SAIs are not as good as cold air intake as it sucks hot air. In this case, does using SAI only in the winter, assuming the temp under the hood will be cooler than summer, make any sense? I do not believe the use of heat shield under the hood in hot summer.
5) Does the brand of SAI matter? I have seen some DIY project where all you need is cone shaped filter and some pipe from hardware store.
ottawa is offline
post #2 of 9 (permalink) Old 11-17-2012, 08:16 PM
24david24's Avatar
2007 Hyundai Accent 5 Speed Hatchback
Quoted: 20 Post(s)
24david24 is an unknown quantity at this point
yes
Ride Of The Month
November 2011
Thanks for your support
24david24 is offline
post #3 of 9 (permalink) Old 11-17-2012, 09:11 PM
Geekdragon's Avatar
Drives 2016 Veloster Rally Edition
Quoted: 23 Post(s)
Geekdragon is an unknown quantity at this point
Primary effect of a Short Ram is that you get a satisfying growl under heavy throttle. Also usually a peculiar humming overtone at all times because of resonance from the intake.
The Accent factory air box already has the benefit of cold air from the fender area, so the warmer air charge from the engine bay is definitely a factor to keep in mind.
I can't really comment on sensor issues, since I haven't encountered any. Performance benefits on these little engines is insignificant. (I dare say next to NIL, with an otherwise factory drivetrain). I didn't notice a big difference in fuel consumption, but then my fuel economy was always pretty poor from short-distance driving.
You're paying for the look, and the sound. A "good" short ram is going to look a bit better. Performance doesn't even enter the equation. With this in mind, trying to rig up an SRI from hardware store parts makes some sense.
I have the Weapon R Dragon intake. It came with extra ducting and hardware to install it in a CAI configuration if desired. It works as advertised -- which is to say I get strange looks from pedestrians when I bury the throttle, the car growls, and they snicker as my econobox still takes too bloody long to pull away. I can't say it was a great return on investment.
Geekdragon is offline
post #4 of 9 (permalink) Old 11-18-2012, 12:16 AM
Quoted: 3 Post(s)
And Don't Call Me Shirley is on a distinguished road
^ +1.
The overwhelming majority of stock intakes in small Asian cars are already fully optimized for power and MPG. The Accent MC is no exception. Only worth changing if you want that sound or that look.
And Don't Call Me Shirley is offline
post #5 of 9 (permalink) Old 11-18-2012, 12:39 AM
Lost100110's Avatar
Accent 08, Custom SRI, 8000K HIDs Retro fit, Mega Raizin Ground, Touren Wheels, Isotta Pedals &
Lost100110 is an unknown quantity at this point
1) the accent done not have a mas it has a map so there's no damage or weird issues...
2) it's a personal choice either for looks or sounds
3) DIY is you cheapest best option to convert from stock and vice versa..
Fine opinion worth the 10$ I spent.
Check out YouTube vids and surf the net, and you be the judge!
Lost100110 is offline
post #6 of 9 (permalink) Old 11-18-2012, 12:54 AM
MODERATOR
Previous: '06 Accent GLS Current: '13 Sonic LT 1.4L turbo
Quoted: 19 Post(s)
The 2006 did have a MAF but that's it for the MC generation. Switched to MAP for 2007.
hoosieraccent is offline
post #7 of 9 (permalink) Old 11-18-2012, 10:41 AM Thread Starter
Quoted: 10 Post(s)
I did not know 2009 did not have the MAS sensor but MAP, I think it stands for Manifold Absolute Pressure. and my scangauge actually reads that. Is MAP located in throttle unit? If so, I assume it would be far away from the cone filter which means less chance to cause a faulty MAP sensor.
ottawa is offline
post #8 of 9 (permalink) Old 11-19-2012, 01:53 PM
omg grip's Avatar
2009 Accent SE
Quoted: 28 Post(s)
omg grip is an unknown quantity at this point
remove intake snorkel (that runs underneath battery tray) from the factory airbox.
add k&n drop-in filter to factory airbox.
congratz you just saved a bunch of money and have nearly all the same effects of a short ram intake. (the sound, no change in fuel economy, barely noticeable change in power, well, except the car breathes a little better at higher rpms). still looks factory under hood as well.
omg grip is offline
post #9 of 9 (permalink) Old 11-21-2012, 04:24 PM
silverflash's Avatar
silverflash
i definitely noticed a huge improvement over stock. i went with the aem/hyundai SRI.
before, it seemed to struggle for air. After, no more.....
2010 Accent Blue
B&M/bushings,16x7 konig lace,pirelli p6 205-50-16
DC Strut bar,bug guard,mud flaps,seat covers. AEM SRI, scoop and 35% tint, oem aluminum fuel door
2007 Nissan Xterra S 4x4 GY Duratrac 265/75R16
silverflash is offline
