21 - 40 of 104 Posts
I think it took me under 3-hours, jack-to-jack, including accessory belts, and idler & tensioner, and I think the plugs as well. I could do it again in about half that, easy. I was dreading it a bit - I've done DSMs (got to be near an "expert" at those - could do one in just over 1.5hrs - but that's been a few years!) and 1st-gen MR2s and did not relish a tight-space, cramped fix, and was about to have the Dealer do it for a quoted $380 (no-longer have garage-space all the time). But, once I read the PDF, I figured "what the hey", picked a sunny day, and gave it a shot in the driveway.
This is by-far the easiest FWD/mid-engine timing belt-change EVAR. EV. AR. Easier than a 2.2/2.5 Chrysler in a Daytona. Easier than that funky Pontiac 2.0 OHC split-headed thing they put in the Sunbird/Cavalier.
I would let my Brother do one, it's that easy. Doubly-so with this guide. I'm a bit disappointed that the file is "dead" - but I'm glad I got a copy before it was corrupted.
any saving the photos? Im pretty visual :)
lol. did you see my posts on page 2 of the thread? I extracted the photos from the PDF, uploaded them to imageshack, and reposted the entire DIY with images in 2 posts.
So even though people are having trouble downloading the PDF, at least the info is still here for those that want it.
i need to start gathering parts to do my timing belt. almost at 60k here.
I picked this up off ebay, timing belt and 2 new tensioner pulleys for $43 shipped, direct from the korea lol. Theres another listing that includes the water pump but for 60k I don't need all that nonsense.
ACCENT 1.6 DOHC 00-10 TIMING BELT KIT REAL MANUFACTURER FOR GENUINE PARTS! | eBay
I picked up my other belts from rock auto for $24 shipped. Skipped on the power steering belt for the time being as I am debating disabling the system and looping the lines on the rack...
Just need to get the other fluids for the 60k service and I am ready to tear into it. mainly brake fluid and coolant I methinks.
I wish I'd done the WP at 60K. 75K on my 2008 and it just started dripping. Now I have to go back in.
Did my timing belt job this weekend. Took me about 4-5 hours, not including a 2 hour excursion to go buy a chain wrench and get lunch. I could probably do it much faster next time, some of that time was just figuring out how things come apart. Plus it was my first timing belt change ever on any car so I was taking time to make sure I was doing everything right.
Both my tensioner and idler pulley were leaking fluid/grease, and the idler had some play and a slight grinding noise/feel, so if you do this job, you might as well replace those since you are in there. The kit with the belt and pulleys is only $40 on ebay. The spring on the tensioner may give you some fits putting it back on, its under tension, so you have to do some careful prying to get it to pop back on correctly. Also be careful removing it with the old pulley.
My water pump was not leaking, nor was my camshaft seal. valvecover gasket looks like it was starting to seep just slightly at the rear. I guess that will need to be changed out next time, or maybe sooner. The upper timing belt cover comes off real easy, 4 bolts, nothing in the way so its easy to inspect at any time. Pretty sure you can get a good look at the waterpump with it off too.
I took a few notes of some differences I had from the DIY above. Like the 1 bolt on the motor mount noted as 16mm, mine was 17mm, the lower timing belt cover had 5 bolts on mine (not 3), one being behind the water pump pulley, that was interesting to get out. Once I had it off, I actually cut the hole for the bolt off the cover, to make it easier to get the cover back on behind the pulley (very tight fit) and there was no way in **** I was going to be able to get the bolt back on behind the pulley. The upper cover overlaps the lower cover anyways, and when all the bolts are tightened, everything is nice and snug.
You can see the bolt here.
Strangely enough the 2 parts of the job that took me the most time (aside from running out to get a tool), were dealing with getting the new tensioner pulley installed, and fussing with that lower timing belt cover, lol.
You probably are going to want to use a chain wrench or something similar. Because you do need to use it again to keep the crank from turning when you are re-assembling and need to actually tighten the crank bolt.
Tip for the Belt: I made 3 marks with white-out on the crank pulley and a matching marks on the old belt, and 3 marks on the cam pulley and on the old belt. Once the belt was off, I transferred the marks to the new belt, ensuring during assembly I was getting the correct # of teeth on the belt between each of the pulleys. This makes sure you arent off a tooth or something, which would be bad. When I put the belt on and released the tensioner, all my timing marks matched up perfectly. I must have checked them about 5 times just to make sure.
I think thats what Attfield was trying to do but I dont understand all his markings around the tensioner and idler pulleys.....maybe thats after the belt was rotated a few times?
We just remove the 4 bolt holding pulley to water pump nose and be done with it.. no cutting required, and all the bolts get put back
OOOPs --
1 1/2 hr on a rack with power tools... :)
I thought about removing the pulley...would have made removing the belt cover a lot easier. Figured it might be a pain to get it back on though. Not to worried about the 1 bolt. I wonder why the original DIY suggested not removing the WP pulley...
I realized my ~5 hr estimate also included some other stuff I was doing on the car at the same time, involving removing the bumper cover. I think in the future that 2-3 hrs would be possible given my working conditions :)
For a first time, 5 hrs is not bad for a weekend warrior and it looks like you got everything else right (except for the 1 bolt...lol). I haven't done mine yet not due till maybe next summer but I've already dedicated a whole day to it!!!:eek:
BTW - good job!!!
Ok. Later on in the first week after the belt change, I was getting some whining from the belts when the car was hot. It did not do it the first few days I don't think, I noticed it like 5 days later when I got home from work. I checked the tension on the alternator/wp and A/C belts, basically loosened them, and incrementally tightened them until they stopped slipping/squealing to make sure they weren't too tight. Still have the whine.
I was pretty sure I got the tension right on the timing belt, I released the tensioner to tension the belt, checked the tension per HMA Service instructions (visually, press the belt and inspect how it deflects in relation to that bolt) and everything seemed in order. I also sort of assumed since the tensioner was spring loaded, it roughly puts the correct tension on the belt anyways. tightened up the tensioner bolts and reassembled.
I picked up a tension gauge this week and I guess I need to take everything apart and double check everything. But from what I am finding through google, sometimes different brands of belts and tensioners just make noise. I know the new pulleys are GMB, I dont remember off hand what the belt is but I guess I will see when things are apart again. supposedly all OEM parts:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
fixed the whiny timing belt this weekend. of course you have to take just about everything off to get to the timing belt tensioner. I backed it off just a little bit.
I fired up the car to test it and make sure it was ok before reassembly....without the crank pulley on. So naturally there was nothing holding on the crank sprocket. As I was revving the engine by hand, it started to slide off the crank! I quickly shut off the car, and promptly crapped my pants. I almost lost the motor. What an idiot!
Then I re-assembled everything, and had a large squeal/scrape, and the car didnt want to start. Turns out I must not have tightened the lower most bolt of the timing belt cover all the way, the one right behind the crank pulley, and the pulley was grinding on it. So after slamming the door and screaming a few obscenities, guess what, I had to take EVERYTHING off again to fix that.
I am getting really good at doing this job considering I have done it about 4 times to get everything right (I can probably swap all the belts in an hour now.) But the car runs smooth and quiet now. Thank God.
Yes, you wont be able to get the bolt out.
I just got mine from the local auto parts store, not sure what size it is, it was just the only one they carried.. definitely want to wrap a rag around the pulley before you crank it down, so you don't damage the grooves in the pulley.
