Oil Condensation? - Hyundai Forums : Hyundai Forum
post #1 of 9 (permalink) Old 01-14-2011, 05:04 PM Thread Starter
MODERATOR
Previous: '06 Accent GLS Current: '13 Sonic LT 1.4L turbo
Quoted: 19 Post(s)
Unhappy
I was checking the oil in our cars the other day and found something rather unsettling with mine. Pulled the dipstick out and it had clumps of something on the end... Okay... Wiped it off, tried again - same clumps of something that almost looked slushy at the end of the dipstick and a few bubbles of something further up. I wiped the slushy substance between my fingers and it was instantly gone. Tried breathing on the other bubbles on the dipstick and they dissipated as well, turning into a small drop of something watery. Wha??? Was this ice on the thing? FYI, this is Motorcraft 5W20 syn blend that was 1750 mi old.
At the time of the check it was 32F and the car had been sitting overnight when it dropped down to 9F. It was driven the prior day at lower speeds (didn't exceed 50 mph) for a 30 minute round trip in 14F temps so I doubt the engine got warm enough to really take care of any condensation that may have built up.
Here's what I was seeing then:
The next day I took her out and gave her a workout. Checked the oil when warm and it looked fine, no evidence of moisture in it. I haven't seen whatever that was in the above pics return.
Here is what it looked like today when warm:
Is this simply condensation or do I have a greater problem with coolant going places it shouldn't? The oil doesn't look particularly milky to my untrained eye and under the cap looks alright to me.
Can't see much because of the baffle but it still looks pretty clean inside at almost 76k.
I read that a bad PCV valve could cause too much moisture to build up, so I went ahead and ordered one. Back in the day you'd replace these often I guess not anymore. The dealer didn't even have one in stock because the parts guy said they never go bad in these cars. Probably a waste of $13 but whatever...
If it warms up a touch I'll do an early change as a precaution with a different oil and see what happens. It might be worth it to spend the $25 and get an analysis done to see if there are any abnormalities, then let the dealer address that.. What do youse guys think? Ticking time bomb or just keep driving it? :P
hoosieraccent is offline
post #2 of 9 (permalink) Old 01-14-2011, 07:04 PM
Burnitwithfire's Avatar
2010 Accent LE 5spd
Burnitwithfire is an unknown quantity at this point
I've seen this on cars that aren't driven long enough to warm up and burn off contaminants. There's usually quite a bit of crap on the oil cap though. Personally I wouldn't worry about it. Check the oil a few times and if it's bothering you too much then change it.
If you respect the maintenance schedule, it'll be fine.
If your engine ever looks like this, then you can freak out
I hate signatures with pictures.
Burnitwithfire is offline
post #3 of 9 (permalink) Old 01-14-2011, 07:09 PM
ultragod's Avatar
Drives: 2007 Hyundai Accent GS Rides in: 2008 Hyundai Santa Fe G
ultragod is an unknown quantity at this point
Send a message via AIM to ultragod Send a message via MSN to ultragod Send a message via Yahoo to ultragod
QUOTE (burnitwithfire @ Jan 14 2011, 04:04 PM)
Definitely freak out, because the top of your engine fell off.
Your lack of punctuation in your post hurt my brain and I honestly can't tell what it is you are trying to say, so I will assume you are agreeing with me. In that case, thanks!
Enter YOUR car in this month's
and be the envy of your friends, enemies, frenemies, and even total strangers if you win!
ultragod is offline
post #4 of 9 (permalink) Old 01-14-2011, 07:11 PM
2010 Accent LE 5spd
QUOTE (ultragod @ Jan 14 2011, 06:09 PM)
It's a VW, I wouldn't be surprised if it ever happened
post #5 of 9 (permalink) Old 01-14-2011, 08:19 PM
bloodninja's Avatar
2008 Hyundai Accent SE (auto) (sold)
bloodninja is an unknown quantity at this point
lol @ ultragod & subsequent burnitwithfire reply
bloodninja is offline
post #6 of 9 (permalink) Old 01-15-2011, 11:16 AM
hyunnychub's Avatar
2011 Sonata GL, Pony
Quoted: 3 Post(s)
hyunnychub
I've noticed this on all the Hyundais we owned...
Even after a hours highway drive there was still beige stuff in the oil cap, and bubbles/water droplets on the dipstick..
hyunnychub is offline
post #7 of 9 (permalink) Old 01-15-2011, 12:38 PM
bloodninja's Avatar
I've never ever had this happen. Is it possible you're overfilling the oil when you change it? I use full synthetic, if that matters.
post #8 of 9 (permalink) Old 01-15-2011, 09:55 PM Thread Starter
MODERATOR
Quoted: 19 Post(s)
Na, not overfilling, at least not this time. I haven't had to crawl back under there and let out the excess for a few changes now. lol
post #9 of 9 (permalink) Old 01-16-2011, 12:11 AM
Quoted: 1242 Post(s)
QUOTE (bloodninja @ Jan 15 2011, 11:38 AM)
Too many short trips, actual climate around here currently, add some Earth Science 101, and we have classic condensation.. I have seen actual clear water beads on oil cap before...
Best thing to do is let it run, get it good and hot to boil off all the moisture, and let the hot oil flush the engine inside.. I drove mine some 140 mile today over 3 trips running around today...
sbr711 is offline
