2010 Accent Gs 2-door Front Suspension Issues - Hyundai Forums : Hyundai Forum
post #1 of 20 (permalink) Old 01-13-2011, 12:46 PM Thread Starter
jcmayorgasca
Need your Help !
What can make both front tires worn out unevenly in less than 9000 miles?
Hyundai service department states that the alignment of the car is Ok.
Is maybe a suspension problem?
What can it be?
Please advice.
jcmayorgasca is offline
post #2 of 20 (permalink) Old 01-13-2011, 12:57 PM
ADMINISTRATOR
Montego's Avatar
Quoted: 103 Post(s)
welcome to the forums
l am moving your post over to the accent forum for a better response
MONTEGO
Montego is offline
post #3 of 20 (permalink) Old 01-14-2011, 07:32 AM
omg grip's Avatar
2009 Accent SE
Quoted: 28 Post(s)
omg grip is an unknown quantity at this point
when they say the alignment is ok, it really means that it is within the specified range. its possible that the 2 sides do not match.
they should have given you a printout of the alignment specs if they said they are ok. Otherwise I would think they didnt even bother to check it.
omg grip is offline
post #4 of 20 (permalink) Old 02-28-2011, 09:04 PM
2013 Gen Coupe 2.0T R-Spec
Quoted: 2 Post(s)
Duro5341 is an unknown quantity at this point
Please post alignment print out, if possible
May things can cause this
-Bad alignment
-Lack of rotation - more likely cause
-Bad front struts
-Under / Over inflation
-Driving Habits
-Burnouts....
-Generally Lack of tire maintence is the #1 cause of premature failure
Where are the tires wearing?, that way I can narrow down exactly what happening
Outside edges? center? one shoulder?scalloping? feather edged?
Duro
Duro5341 is offline
post #5 of 20 (permalink) Old 03-01-2011, 12:04 AM
hyunnychub's Avatar
2011 Sonata GL, Pony
Quoted: 3 Post(s)
hyunnychub
i know from fact driving these spiritedly around corners eats the inner edges on the accents
hyunnychub is offline
post #6 of 20 (permalink) Old 03-01-2011, 10:50 AM
jshmata
Same for me. Tires on the front driver side wear out first. The front tires here in NYC take a beating. I am lucky to get 20K miles.
Aggressive rotation schedule and wheel alignment help me. I just switched to the SE wheel and tire sizes and hope to have
better results.
jshmata is offline
post #7 of 20 (permalink) Old 03-02-2011, 09:47 PM
leshka's Avatar
leshka
QUOTE (hyunnychub @ Mar 1 2011, 12:04 AM)
!!! I have an SE (16" wheels) and I also did notice that the inner edges were worn out more then the outer. In fact after ~25,000km front stock tires are almost dead.
leshka is offline
post #8 of 20 (permalink) Old 03-02-2011, 10:19 PM
bloodninja's Avatar
2008 Hyundai Accent SE (auto) (sold)
bloodninja is an unknown quantity at this point
The stock tires wear poorly. I went through the stock Kumho 205/45/16 in 22,000 miles, at less than 2mm per tread.
I've now gone 25,000 miles on my Yokohama AVID TRZ tires, 205/55/16, and they have 7mm of tread left, every tire, every tread. Wearing evenly with only ONE rotation. Yeah... they should last at least another 25,000.
bloodninja is offline
post #9 of 20 (permalink) Old 04-28-2011, 03:08 AM
Drives 2015 Sonata Eco
Quoted: 78 Post(s)
carfreak09 is an unknown quantity at this point
ok folks, I'm now noticing this problem on my car. The driver side front tire is worn almost bald right at the very inner edge of the tire. It looks as if the car is riding on the edge of the tire but there is only a slight pull to the right. The passenger side front tire is not worn in this manner. The steering wheel centers a little to the left of center but will track relatively straight on the highway when there is no crosswinds. Is my alignment off or is there a problem with the tire?? I'm at 16200 miles and the tires have been rotated once. I was about to rotate them again. I'm now wondering whether I should get an alignment done before rotating? I really don't want to spend the money though if this is just a tire issue or the problem won't be fixed by an alignment. Based on the wear pattern, I'd say the camber is off, but the tire honestly looks like its riding square with the road. Can the camber be adjusted on our cars?? The wear is just so bizarre to me because the car is not driving like something is majorly off. The tires still look to have another 15k left in them and I'd like to get that. Advice?
2015 Sonata Eco silver/gray int - roomy, fast ride. Traded at 16k due to DCT issues and uncomfortable drivers seat.
2012 Elantra Touring GLS 5-speed 43200 - 67065 miles. Roomy reliable car. Traded for Sonata.
2010 Hyundai Accent GS Premium auto - traded in 2012 after 57k trouble free miles
carfreak09 is offline
post #10 of 20 (permalink) Old 04-28-2011, 10:34 AM
2010accentse
I just returned from my first alignment appointment. The rear toe is so far out of spec they need to shim the axle. The rear left tire is so out of round, they won't rotate it. I am not happy with this at all. Hopefully Kumho will replace the bad tire. It only has 4035 miles on it. The shims are going to run me 200. I'm not even going to bother with a warranty request, because I lowered it.
2010accentse is offline
