Idle Air Control (IAC) Valve - Hyundai Forums : Hyundai Forum
 3Likes
post #1 of 15 (permalink) Old 03-16-2017, 02:34 AM Thread Starter
Quoted: 2 Post(s)
Sasikiran is an unknown quantity at this point
Question Idle Air Control (IAC) Valve
Can someone please share with me the exact location where in idle air control valve is located (Hyundai Sonata sport 2016)? I am experiencing throttling issues in my car. Thank you in advance.
Sasikiran is offline
post #2 of 15 (permalink) Old 03-16-2017, 04:31 AM
AUTOSPARK's Avatar
Hyundai Getz 1.5 CRD (D4FA)
Quoted: 994 Post(s)
I'm not familiar with the newer model Sonata but my guess is your engine will have a "drive by wire" throttle, meaning the throttle valve is electronically controlled as opposed to earlier engines that had a throttle cable linking the pedal to the valve on the engine. Engines with drive by wire throttles generally don't have an idle air control valve. On that type of system the PCM just drives the main throttle valve to regulate idle speed.
AUTOSPARK is offline
post #3 of 15 (permalink) Old 03-16-2017, 07:01 AM Thread Starter
Quoted: 2 Post(s)
Red face
Thank you so much AUTOSPARK for your reply. Yes, my car has an electronic throttle control system. In that case I guess there is no IAC Valve. Hope i could find the error code for the electronic throttle control system. If you have any idea regarding the trouble code please do share it with me.
post #4 of 15 (permalink) Old 03-16-2017, 07:14 AM
solman98's Avatar
Drives 2014 Elantra Sport 2.0 6M 2016 Tucson Sport 1.6T
Quoted: 630 Post(s)
solman98 is an unknown quantity at this point
2016, no warranty?
2014 Elantra Sport 2.0 6M Shimmering Silver. LED interior lights, cargo mat and net. 35/20% tint. LED tag and back up lights. LED fogs. LED headlights, homelink.
2016 Tucson Sport 1.6T 7A Caribbean Blue. Hitch, tint, mudguards, homelink, cargo cover, LED back up and tag lights, power pass seat lumbar installed, LED fogs, aftermarket crossbars for the roof.
solman98 is offline
post #5 of 15 (permalink) Old 03-16-2017, 07:17 AM Thread Starter
Quoted: 2 Post(s)
Originally Posted by solman98 View Post
2016, no warranty?
There is. But still trying to learn here. If you could school me a bit. Thank you.
post #6 of 15 (permalink) Old 03-16-2017, 09:06 AM
Red Raspberry's Avatar
Quoted: 942 Post(s)
About the only thing you can do to an ETC is clean the TB and plate and make sure the connector is seated well.
"Imagine a world in which we are all enlightened by objective truths rather than offended by them." Neil deGrasse Tyson
Red Raspberry is offline
post #7 of 15 (permalink) Old 03-16-2017, 02:52 PM
teedot's Avatar
2015 Sonata GL Previously: '02 Santa Fe GL 5-Speed
Quoted: 98 Post(s)
teedot is an unknown quantity at this point
Take it to the dealer if you are not sure what to do. Warranty is there for a reason....
bobsingh likes this.
teedot is offline
post #8 of 15 (permalink) Old 03-16-2017, 04:30 PM
2015 Sonata Sport 2.4
Quoted: 56 Post(s)
Grady Wilson is an unknown quantity at this point
A word of caution about cleaning a drive by wire throttle body - most electronically controlled throttle bodies can be ruined by manually moving the butterfly.
So if you do try and clean the butterfly and intake, don't move anything inside the throttle body while you are doing the cleaning.
Grady Wilson is offline
post #9 of 15 (permalink) Old 03-16-2017, 05:14 PM
Quoted: 1332 Post(s)
LF does not have an IAC motor,, that be an internal function of PCM to motor driven throttle blade to regulate idle......... same for cruise,,, PCM internal function to motor driven throttle plate and other assorted inputs to maintain vehicle speed.
teedot likes this.
sbr711 is offline
post #10 of 15 (permalink) Old 03-18-2017, 06:52 PM
Quoted: 7 Post(s)
cotorassiel is an unknown quantity at this point
As some people have said before there is no IAC on your sonata, if you are experiencing a rough idle yuo should take the vehicle to a dealership, your concern MAY be related to a dirty Throttle Body, which is not a covered under warranty, this is a maintenance issue, as long as air filters, tires, flushes and oil changes.
Cheers
cotorassiel is offline
