Vent blowing warm air always( when AC and heater is off ) - Hyundai Forums : Hyundai Forum
 14Likes
post #1 of 20 (permalink) Old 07-06-2016, 11:12 AM Thread Starter
bobsingh's Avatar
Quoted: 61 Post(s)
bobsingh is an unknown quantity at this point
Unhappy Vent blowing warm air always( when AC and heater is off )
Hello everyone my name is Bob Singh,Canada. i bought a white 2015 Sonata GLS with 55000 kms on it.
Car works fine but really great on gas in city with AC ( 11-12 liters/100 kms ) .
and my main problem is my AC/heater vents. its nice cool day out and i wanna roll my windows up and use outdoor air ( with AC off and heating knob on cool - Blue side ) but still blow warmer air( the more i turn the temp knob to less cool side more warm air comes out . . i went t dealership and complaint about it but they said Cant duplicate problem. and i replaced cabin air filter too, but still same problem.
PS i don't have automatic temperature climate control option, so its all manual, red and blue setting for heat and cold.
i complaint them may be my heater stuck on heating but no action taken from them,
any suggestion will be highly appreciated.
bobsingh is offline
post #2 of 20 (permalink) Old 07-06-2016, 11:41 AM
introspectron's Avatar
2016 Hyundai Sonata Hybrid Limited Ultimate
Quoted: 89 Post(s)
introspectron is an unknown quantity at this point
Hmm how warm are we talking about here? Here's a few things to keep in mind:
1. Your vents will never blow in completely cool air from the outside, as the outside air is taken in it is mixed with the warm recirculated cabin air before it gets vented, even when set to "Intake" mode. Not sure what the ratio is, but if I had to guess it's probably 65% Recirculated and 35% Exterior. Therefore, depending on the existing cabin temperature, your vent temperature may vary.
2. You don't have a heater in your car. Your car uses engine heat as cabin heat, the more you turn the knob to "warm," the more air is being routed around the engine to warm up before entering the cabin.
3. Even if outside air is cool, your car's vent system ducts may be hot if it was left under the sun for a while before you turned your vents on.
A few things to try:
1. Cool off the interior first before while you use the fan without AC. Open your windows and vent the majority of the hot cabin air out while setting your cabin air system to full fan speed, 100% cool, AC off, and intake mode. This will ensure the duct system is cooled off as well as the interior air it recirculates.
2. Before you set the fan to "off," ensure your knob is turned all the way to "cool," as the temperature setting is independent of the fan.
3. Based on how the system works, you'll never ever get 1:1 outside temperature match. However, if you do everything correctly, you could probably get outside air+5 degrees to vent into the cabin.
Let us know if any of above works. Good luck!
introspectron is offline
post #3 of 20 (permalink) Old 07-06-2016, 12:33 PM
C4RN1's Avatar
Drives 2012 Sonata Turbo 1998 Eclipse GS (420a Turbo w/ 450 whp) SOLD!
Quoted: 137 Post(s)
C4RN1 is an unknown quantity at this point
I had this issue in my Eclipse, the best way to avoid hot/warm air from coming out the vents when you have the system off is to change your air setting to recirculate. If you have the vent open for fresh air it will constantly push air though the system while it's off. Though if you have it on recirculate it won't move any air though the warm system.
I haven't experienced this issue on my Sonata because I always have my AC on.
bobsingh likes this.
C4RN1 is offline
post #4 of 20 (permalink) Old 07-06-2016, 10:00 PM
MattTRIX's Avatar
2015 Sonata Sport 2.4 Coast Blue
Quoted: 184 Post(s)
MattTRIX is an unknown quantity at this point
This seems to be the case for me but only on a hot day like if I'm driving mid afternoon in the sun with ac off.
I don't think much of it as the problem is resolved with a/c on for a few seconds. At first I thought car was overheating but the temp is fine.
Sent from my iPhone using Tapatalk
MattTRIX is offline
post #5 of 20 (permalink) Old 07-06-2016, 10:14 PM
Old's Cool's Avatar
2005 Scion tC; 1988 Toyota Supra; 2009 Hyundai Accent Wheezer 1.6; 96 Subaru Outback (soon)
Quoted: 2919 Post(s)
Old's Cool is an unknown quantity at this point
Sounds like a blend door issue, and the dealer should be able to suss it out. How warm is it? I thought it was always cold in Canada.
Used to be in the old days there was a valve near the firewall that would route part of the coolant through the heater core, in the xummer it would close it off and bypass it so no hot water was getting in the cabin. Now there is no valve, and warm water is alway in the heater core, but they use a diverter called a blend door to send air through the core or bypass it. It sucks dolphins, IMHO. Some blend doors are controlled by a cable, some by an actuator, which is controlled by a knob on the dash (think of your radio's Volume control). Anything controlled electronically can go tips up and cause problems.
I hate the darn things. On older cars I remove the actuator and put what looks like a choke cable on it. You perhaps do not want to do this with your car?
Do you know any satisfying profanity?!
There are two ways to slide easily through life: believe everything, or doubt everything. Both ways save us from thinking-Fred C. Dobbs
<<click...
2009 Accent Hatch
I find it works well enough to get me from one planet to another.
Last edited by Old's Cool; 07-06-2016 at 10:15 PM. Reason: Xummer? What about Xpring and faul?
Old's Cool is offline
post #6 of 20 (permalink) Old 07-15-2016, 03:18 PM
2016 sonata sport
Quoted: 68 Post(s)
deltaolds is on a distinguished road
that is normal, mine does it too, as soon as you turn on ac it starts blowing cold, you can turn on rec mode, and nothing will be blowing out the vents. air will also cool off when you turn the fan on and set temp to cold without using ac.
SGR and bobsingh like this.
deltaolds is offline
post #7 of 20 (permalink) Old 07-18-2016, 11:20 AM
Drives 2016 Sonata Limited Ultimate
Quoted: 49 Post(s)
rweisman is an unknown quantity at this point
I am pretty sure all cars that don't have an Air cooled engine have a "Heater". The heater uses the Engine Cooling System fluid. A heater gets the engine coolant routed through it when heat is called for. The Interior fan blows over that Heater Core to deliver heat to the cabin. The air is not routed around the Engine.
rweisman is offline
post #8 of 20 (permalink) Old 07-26-2016, 01:25 PM Thread Starter
bobsingh's Avatar
Quoted: 61 Post(s)
Lightbulb
Thank you and i appreciate your suggestion:
i tried to do cool off my cabin by rolling windows down, and even A/C too ,
but as soon as A/c loose its coolness and outside air start coming warmer. i have been reading some posts about Air blender door/Valve .
Do you think that could be the reason ?
1. if my temp knob not all the way down to cool(blue) side it blows more warmer and when its close to all the way to cool side, it blow little cooler air but still not as cool as outside air or the air i want (A/C is off).
2. when i turn on my A/c does that air comes with same Heater core way? or heater door close as soon as you turn the air condition on.
sorry to bother you .
bobsingh is offline
post #9 of 20 (permalink) Old 07-26-2016, 01:28 PM Thread Starter
bobsingh's Avatar
Quoted: 61 Post(s)
Lightbulb
Thanks for suggestion,
i want to let the fresh outdoor air in , since air outside is cool and cabin is warmer by sun.
But i will give it a try.
bobsingh is offline
post #10 of 20 (permalink) Old 07-26-2016, 01:29 PM Thread Starter
bobsingh's Avatar
Quoted: 61 Post(s)
Lightbulb
Thanks,
how can i check if my car is not getting over heated, if its not showing on dash display?
bobsingh is offline
