I'm new to this forum everyone. I want to know if anyone has changed their motor mounts and if so which parts did they use I want to change all of them. In addition, I would like to know which one were harder to change and if anyone knows of a guide as reference. Thanks in advance
The mounts are very easy to replace. It's important to use your torque wrench with correct settings. Keep in mind that the specs are not the same for all mounts. <br />
<br />
You might need to use a jack with a block of wood to help align the engine for this. Replace one at a time. Bottom ones are easy, front and back middle of the engine Bay. Side ones aren't much more difficult.
For a guide, all you should need is the repair manual. If you can't find it, pm me and I'll help you out. Take a good look at your mounts. It's a very straight forward job, you should be able to see what's going on.
@williakz - There are two motor mounts that are cracked the original problem was vibration in the pedals while idling and at speeds of 65MPH. I performed a wheel balance and tire rotation but then at that point I noticed the motor mounts were cracked. @zero_gravity - Thanks for the information.
