Using the special tool (09411–11000), install clutch disc to flywheel. When installing the clutch disc, be sure that the surface having the manufactures stamp is towards the pressure plate side.
Install the clutch cover assembly onto the flywheel and install six (6) bolts through the clutch cover into the flywheel.
Diagonally tighten the bolts 15–22 Nm (150–220 kg.cm, 11–15 lb.ft).
Tighten the bolts by one or two turns at a time, in succession, to avoid bending the cover flange..
